where you see the first topic watch a little up the "New Topic +" button.. bye..
Eeprom dump thread!
This is a sticky topic.
I need this dump of eMMC, too. But the link is broken, cloud you generate a new link? Thanks
Here is a working dump of eMMC (Samsung) on Sony KD-55XG8596 1-983-791-12.
https://drive.google.com/file/d/18X5...nclLW870i/viewComment
Hi all I am looking for a dump for a ves550undl -2d -n11 panel.The original board is 17MB211 but it is dead now I have two options to put 17MB82 or 17MB140 (I don't have 211) Both boards need software as the colors are polarized and the picture is inverted .I prefer to put 140 which is from 48 inch TV with panel ves4800unds -2d -n12. I modified the dump with vestel panel editor, but the picture is purple and there is no red color. Apparently it wants an exact dump I will be glad for your helpComment
Samsung Model Code: UN40MU6300FXZA
Version No: FA01
Attached Filesif you find these attachements useful please consider making a small donation to the site
TryAttached Filesif you find these attachements useful please consider making a small donation to the site
Hello everyone, I appreciate you allowing me to interact with this great community. I come to you to request the necessary firmware for a VIOS TV4817 screen, so far I have seen that they published it for version 4814 but it seems to me that they are not compatible, the memory of my screen is a HX1717 25Q32CSIG flash memory AP0Q138 I would appreciate your help to carry out this work☺Comment
What's the problem with your firmware? What is your motherboard number, what is the processor, panel number, you can post your own, not working dump here.Hello everyone, I appreciate you allowing me to interact with this great community. I come to you to request the necessary firmware for a VIOS TV4817 screen, so far I have seen that they published it for version 4814 but it seems to me that they are not compatible, the memory of my screen is a HX1717 25Q32CSIG flash memory AP0Q138 I would appreciate your help to carry out this work☺Comment
I think the problem is the firmware since the TV shows stand-by LEDs but does not turn on either with a button or with a control.
I'm not sure I know exactly what the data you mention are but on the plate I can see the following information:
- LD.M3553.A
On the panel is the following code:
- 15Y_L48GF11BMB7S4LV0.6
and I have no information about the processor or possible damaged firmware
T-CON IC601(W25X40BV) - it does not play any role in rebooting, you need to program EEPROM/FLASH - IC801(W25Q40BV) IC802(S24C256C)
Try programming two chips at once with this set, just save your original dumps.Attached Filesif you find these attachements useful please consider making a small donation to the site
Thanks for your patience, yes I have that motherboard, I was able to extract the following bin file from the non-working flash, I would really appreciate it if you could help me take a look at itAttached Filesif you find these attachements useful please consider making a small donation to the site
The kernel and software in your dump are fine, try recording your dump with the NVM removed.Attached Filesif you find these attachements useful please consider making a small donation to the site
Hello, can someone check the dump or has the original , thank you
Samsung UE55MU6170UXZG KANT_M_BUILT_IN BN41-02568B BN94-12486N
It responds to remote on and off, but does not turn on 12V power for pmic.Attached Filesif you find these attachements useful please consider making a small donation to the site
Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
07-26-2025, 03:24 PM -
by jorpecHi, all
I need the dump/firmware for this tv, it was on a boot loop, i dont have the original corrupted dump because i used a pen drive with a firmware that solved the boot loop, initially it seemed it was ok but the tv has no sound
Thanks10-17-2025, 03:51 AM -
by my2k2Good day to every one,
I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
Does anybody have an eeprom dump file? I really appreciate any help.
Thanks in advance.-
07-01-2024, 09:04 PM -
by (0)_(0)Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...02-17-2022, 09:09 PM -
P14s Gen 2
HT4B0/HP4B0/HT5B1/HT4B2
NM-D352 Rev 1.0
sn PF-35P15W
Requesting thunderbolt dump
also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....-
Channel: BIOS Requests ONLY!
- Loading...
