Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4830
    • Russia
    #1841
    Originally posted by hazi12
    Hello, can someone check the dump or has the original , thank you
    Samsung UE55MU6170UXZG KANT_M_BUILT_IN BN41-02568B BN94-12486N
    It responds to remote on and off, but does not turn on 12V power for pmic.
    Dump is ok.​
    • hazi12
      • Jun 2015
      • 13
      • Czech Republic
      #1842
      Originally posted by lotas
      Dump is ok.​
      Thank you Lotas, is it possible that the failure was caused by the Emmc firmware?
      • lotas
        • Jan 2016
        • 4830
        • Russia
        #1843
        Yes, everything is possible, have the usb and hdmi ports been checked for short, low resistance relative to gnd?
        • hazi12
          • Jun 2015
          • 13
          • Czech Republic
          #1844
          Yes usb and hdmi ports fine, dc converters too, not found from the same board original firmware emmc nor w25Q40.
          • Drexter
            • 10
            #1845
            Hello everyone, could someone help me check the bin file for a Samsung UN75MU6103. Ver. FB03. or if you have a working backup, would be greatly appreciated. The Standby led is turned off, still if joystick is pressed or powerd on by remote, it flashes, but nothing happens. All voltages are present and there is no short circuit on the board. Thanks in advance!.
            • maxri
              • May 2023
              • 7
              • Italy
              #1846
              Hi. I have a Samsung UE49MU6220KXZT that won't turn on. No led and no response to commands.
              Can someone check the dump or has the original , thank you
              Board BN41-02568A BN94-12571E
              Thank you.
              • lotas
                • Jan 2016
                • 4830
                • Russia
                #1847
                Thank you.
                I can check, but I don't see your dump.
                • Drexter
                  • 10
                  #1848
                  Sorry I thought I uploaded it. Here it is. Thanks a lot!!
                  • maxri
                    • May 2023
                    • 7
                    • Italy
                    #1849
                    Sorry... i forgot the file...
                    • lotas
                      • Jan 2016
                      • 4830
                      • Russia
                      #1850
                      Try it, don’t forget about status register (0x88, 0x42).
                      • lotas
                        • Jan 2016
                        • 4830
                        • Russia
                        #1851
                        Your dump is ok, working, the problem is different.
                        • Drexter
                          • 10
                          #1852
                          Thank you very much I appreciate it!
                          • maxri
                            • May 2023
                            • 7
                            • Italy
                            #1853
                            Try it, don't forget about status register (0x88, 0x42).
                            With this file the led is now red and flashes when sending commands. The tv still doesn't turn on.
                            The processor heats up even if the tv doesn't seem to do anything.
                            I read the post about the registers and I hope I programmed the chip well.
                            Thanks anyway for your support.​
                            • maxri
                              • May 2023
                              • 7
                              • Italy
                              #1854
                              hello, I would like to try again to solve the problem of my Samsung TV (UE49MU6220KXZT).
                              I have a Xggeku T48 programmer, can you confirm that with this device the programming of the bin file and the registers happens all at once?
                              Or is it necessary to repeat a second time for the status register?
                              Can someone provide another bin file to try?
                              Thanks.​
                              • dadopo
                                • Jan 2025
                                • 7
                                • Italia
                                #1855
                                Good morning, I would need a good dump file for my samsung ue40mu6400uxzt, I attach the original dump.
                                Thanks in advance to anyone who can help me​
                                • lotas
                                  • Jan 2016
                                  • 4830
                                  • Russia
                                  #1856
                                  Try your good dump file for your TV.
                                  Don't forget to set and write the status register (0x88, 0x42) after writing the corrected dump.
                                  • dadopo
                                    • Jan 2025
                                    • 7
                                    • Italia
                                    #1857
                                    Thank you for your time, but where I change the status register I attach images of my programming software, thanks again
                                    • lotas
                                      • Jan 2016
                                      • 4830
                                      • Russia
                                      #1858
                                      Like this.
                                      • dadopo
                                        • Jan 2025
                                        • 7
                                        • Italia
                                        #1859
                                        Thanks, I tried now the led lights up, flashes 3 times and then turns off, I have to check the mosfets on the board, thanks for everything
                                        • max-power
                                          • Mar 2023
                                          • 6
                                          I Have two EEPROM files, both are from Haier 55'' 4K TV of the same model 55E5500U with the same main board T.MS3458.U801 but with differents Samsung panel.
                                          Both have been tested and worked
                                          Should fix the the infamous aging mode ( color rolling Red, Blue, White etc...), it did work on mine. I did use a brand new EEPROM though ( Digikey # GD25Q64CSIGR )
                                          Even if they use the same board, both are not intercheageable ( I try ) something weird, on one, its says: 55E5500U panel:LSC550FN08 but have a sticker underneth saying LSC550FN08 and the other one list a Samsung panel LCS550FN05 but list a BOE panel HV550QUB-N81 on the sticker underneth, so who know?
