Eeprom dump thread!
This is a sticky topic.
  • cheeky2
    • Dec 2012
    • 337
    • uk
    #1641
    Looking for Blaupunkt 32/133-WB-5B2-HBKUP-EU flash ic UF11 dump
    Model ref:B32A133TCHD
    Main: TP.MSD309.BP85 C12415
    Screen: LC320DXJ SFE1
    I have the dump for the lsc320an02 screen but unsuitable.
    • lotas
      • Jan 2016
      • 4598
      • Russia
      #1642
      Hello, I sent you a link to the dump you asked for in a private message. You could also try to fix your non-working dump
      • cheeky2
        • Dec 2012
        • 337
        • uk
        #1643
        Thanks for the above file
        Looking for Bush 24/207FDVD-S flash ic UF11 dump
        Main: T.MSD309.B66B
        Screen: BOER236WU1
        I have the dump for the Bush 24/207F attached but would like to get the DVD going as well for it.
        Attached is the corrupted dump and the Bush 24/207F both with the same screen
        • vinceroger69
          • Mar 2012
          • 6714
          • uk
          #1644
          Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen could this be a firmware fault
          Edit, please ignore above, the set has one failed led on one strip.
          • lotas
            • Jan 2016
            • 4598
            • Russia
            #1645
            Hi i have a polaroid p40led14 using the 17ips20 power board the 17mbb2s mainboard and a ves400unds 2d r06 lcd the issue i have is it will come out of standby but nothing on screen i have tested the leds they stay lit a 122v on led tester could this be a firmware fault
            Edit, please ignore the set has one failed led strip.
            Anything is possible, first you need to check whether 12 volts is supplied to the t-con board (whether the fuse is live) or whether this happened after an incorrect update (another panel).
            • vinceroger69
              • Mar 2012
              • 6714
              • uk
              #1646
              Thanks lotas i will remember too check that next time, not sure if youve seen my edit above the set had one failed led on one strip when taking the tv apart found the set had been dropped as loads of plastic cracked etc so i have stripped the tv for parts (was a free set anyway)
              • imran333
                • Apr 2012
                • 48
                • uk
                #1647
                Need emmc dump for XBR-65X850D or for 55” version, board number is 1-980-832-11, this is USA board and Europe and UK board has same board number but board is slightly different and the dump didn’t work so really need the correct one, I don’t mind looking after the person with the dump
                • ivblgrpet
                  • Jan 2024
                  #1648
                  Hi!
                  TV Toshiba 55U6763DG
                  Main: Vestel 17mb120
                  SPI: MX25L1606E
                  Problem: Do not turn on, flashing red/green standby, Unable to make USB update.
                  ​Can you check and repair (if it needs to be repaired) this SPI dump.
                  Thanks!
                  • lotas
                    • Jan 2016
                    • 4598
                    • Russia
                    #1649
                    Originally posted by ivblgrpet
                    Hi!
                    SPI: MX25L1606E
                    Thanks!
                    Try this dump.​
                    • ivblgrpet
                      • Jan 2024
                      #1650
                      Try this dump.​
                      Thank you for very fast reply. I'll try it on monday and report results.
                      • ivblgrpet
                        • Jan 2024
                        #1651
                        Try this dump.​
                        Unfortunately this dump didn't help. Same problem remains. Thank you anyway. Maybe or probably problem is not in MX25L1606E.
                        CH341A is my only tool for programming. I have the UART log. Maybe you can identificate the problem with the help of this log?
                        • lotas
                          • Jan 2016
                          • 4598
                          • Russia
                          #1652
                          You have a problem with NAND flash.
                          • ivblgrpet
                            • Jan 2024
                            #1653
                            Ok, thank you
                            • totof
                              • Feb 2017
                              • 157
                              • france
                              #1654
                              hi, i am looking for the eeprom for my Samsung UE40MU6405 -BN41-02568B / BN94-12398F.
                              The tv doesn't power on (power led always off). Backlight on when moherboard disconnected.
                              Non-working dump here.
                              Thanks​
                              • lotas
                                • Jan 2016
                                • 4598
                                • Russia
                                #1655
                                Thanks​
                                There is no need to search, other people's dumps will not help you, just restore your own one. Try it.
                                • lotas
                                  • Jan 2016
                                  • 4598
                                  • Russia
                                  #1656
                                  Try it.
                                  It doesn't work, what also doesn't work?
                                  • totof
                                    • Feb 2017
                                    • 157
                                    • france
                                    #1657
                                    Hello.
                                    I have just tried now and it works very well now.
                                    Thank you lotas :-)
                                    • lotas
                                      • Jan 2016
                                      • 4598
                                      • Russia
                                      #1658
                                      Hello.
                                      Thank you lotas :-)
                                      Well, great that it works!
                                      • StephenU
                                        • Dec 2013
                                        • 230
                                        #1659
Name:	Toshiba update via USB.jpg
                                        Tv stuck on Toshiba Splash screen.
                                        Guys here is the Software provided by Toshiba. ## Can someone help as I keep getting - Error: PHP Max Post Size has been exceeded. when trying to upload zip file, thanks ##
                                        Toshiba: 55T6863DB
                                        Mainboard: 17MB130S - 23495635
                                        Panel number: VES550QNYL-2D-N01​
                                          SMDFlea commented
                                          Editing a comment
                                          Splitting the attachment might fix that
                                      • StephenU
                                        • Dec 2013
                                        • 230
                                        #1660
                                        ok will try that now, Thanks
                                        • AlexGsmMaster
                                          Eizo CS2740 eeprom dump, search.
                                          by AlexGsmMaster
                                          Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                          07-26-2025, 03:24 PM
                                        • (0)_(0)
                                          Looking for a HP Photosmart C4280 EEPROM dump
                                          by (0)_(0)
                                          Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                          The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                          02-17-2022, 09:09 PM
                                        • my2k2
                                          Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                          by my2k2
                                          Good day to every one,
                                          I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                          Does anybody have an eeprom dump file? I really appreciate any help.
                                          Thanks in advance.
                                          07-01-2024, 09:04 PM
                                        • Whale linguini
                                          p14s Gen 2 thunderbolt eeprom dump
                                          by Whale linguini
                                          P14s Gen 2
                                          HT4B0/HP4B0/HT5B1/HT4B2
                                          NM-D352 Rev 1.0
                                          sn PF-35P15W
                                          Requesting thunderbolt dump
                                          also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                          09-03-2024, 01:56 PM
                                        • Ancient1
                                          Before I dump this Panel...
                                          by Ancient1
                                          Hi
                                          I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                          As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                          Right distribution board, 2 Flexs, near them:
                                          The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                          The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                          I...
                                          10-23-2022, 11:07 AM
