Eeprom dump thread!
This is a sticky topic.
  • MF ELETTRONICA
    • Jun 2024
    • 41
    • italia
    #1801
    ho il programmatore t56 e uso xgprog
    • MF ELETTRONICA
      • Jun 2024
      • 41
      • italia
      #1802
      I have the t56 programmer and I use xgprog
      • lotas
        • Jan 2016
        • 4668
        • Russia
        #1803
        It’s clear, as dump was considered, click on status reg. and you will see in the window where there will be checkmarks, that’s what your spi flash is currently set to.
        • MF ELETTRONICA
          • Jun 2024
          • 41
          • italia
          #1804
          hi lotas i found the problem is in the nand the tv flashes and does not turn on if i send you the dump of my nand can you see if you fix it? thanks
          • MF ELETTRONICA
            • Jun 2024
            • 41
            • italia
            #1805
            http://www.mfelettronicasestri.it/DEADfile/MT29F4G08ABAEAWP@TSOP48.rar
            I attach the link to the nand file if you can take a look thanks
            • MF ELETTRONICA
              • Jun 2024
              • 41
              • italia
              #1806
              i left link above nand can you check it out Lotas? thanks
              • lotas
                • Jan 2016
                • 4668
                • Russia
                #1807
                I don't have access to this resource, please upload it to another file hosting service.​
                • MF ELETTRONICA
                  • Jun 2024
                  • 41
                  • italia
                  #1808
                  yes do it like this copy link and open page and paste link you will see that it works otherwise send me your email
                  • MF ELETTRONICA
                    • Jun 2024
                    • 41
                    • italia
                    #1809
                    if you open a new page and paste the copied link it works
                    • lotas
                      • Jan 2016
                      • 4668
                      • Russia
                      #1810
                      Ok, it worked.
                      • lotas
                        • Jan 2016
                        • 4668
                        • Russia
                        #1811
                        Try it, clear it from bit errors...https://drive.google.com/file/d/1utt...-rVkhZ3E9/view
                        • MF ELETTRONICA
                          • Jun 2024
                          • 41
                          • italia
                          #1812
                          I tried lotas but it doesn't work.... only thing is I didn't clean the bits.... sorry how do I clean it from the bits??? but I think it doesn't work
                          • MF ELETTRONICA
                            • Jun 2024
                            • 41
                            • italia
                            #1813
                            lotas can you give me a hand? please
                            • lotas
                              • Jan 2016
                              • 4668
                              • Russia
                              #1814
                              How can I help, what do I need?​
                              • MF ELETTRONICA
                                • Jun 2024
                                • 41
                                • italia
                                #1815
                                Originariamente pubblicato da MF ELETTRONICA Visualizza post
                                ciao lotas ho scoperto che il problema è nella nand la tv lampeggia e non si accende se ti mando il dump della mia nand puoi vedere se lo risolvi? grazie
                                Provalo, puliscilo dagli errori di bit...
                                ho provato questo file che mi hai inviato credo lo hai modificato? ma non funziona non ricordi?
                                English ???
                                • MF ELETTRONICA
                                  • Jun 2024
                                  • 41
                                  • italia
                                  #1816
                                  https://drive.google.com/file/d/1utt...-rVkhZ3E9/view​
                                  I tried this file you sent me I think you modified it? but it doesn't work, don't you remember?
                                  • lotas
                                    • Jan 2016
                                    • 4668
                                    • Russia
                                    #1817
                                    Yes, I remember everything, I cleared dump nand for bit errors (ECC), it didn't work for you either, now how can I help?
                                    I also have firmware for recovery via usb, but VES315WNDS panel, but you have a different panel.
                                    • MF ELETTRONICA
                                      • Jun 2024
                                      • 41
                                      • italia
                                      #1818
                                      so there is nothing you can do? I thought you could act on the ignition issue... I tried another one with the same card, the TV turns on but it looks bad and upside down
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4367
                                        • Italy - Milan
                                        #1819
                                        Hei.. this is an eprom dump thread.. can.you.open.a.separate thread?
                                        • MF ELETTRONICA
                                          • Jun 2024
                                          • 41
                                          • italia
                                          #1820
                                          sorry and how do I do I don't know how to open it
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            07-26-2025, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
