Eeprom dump thread!
This is a sticky topic.
  • RAZ777
    • Feb 2022
    • 18
    #1141
    Re: Eeprom dump thread!
    I have a toshiba 40l3653db with flashing green light, found this forum & thread searching google unsucessfully for firmware.
    Can anyone help, point me to any appropiate firmware?
    Its the vestel 17MB110 main board, screen is VES400UNDS-2D-N12.
    Thank you.
    • mnjoao
      • Feb 2022
      • 14
      • portugal
      #1142
      good afternoon, I have a polaroid TV tql40f4pr006 with the main board HK-T RT2957P63 panel V400HJ6-PE1-P7-12V for which the eprom dump was needed.
      thanks
      • luzmina
        • May 2015
        • 17
        • US
        #1143
        Hi, I need the bin file for Magnavox 55ME314V/F7 A4GR1MMA, panel U4DR0XH. I have the DUMP file but is corrupted, I am using the BIN file for the DS3 but I got inverted picture. Thanks
        • lotas
          • Jan 2016
          • 4530
          • Russia
          #1144
          Post your non-working dump here, I'll try to fix it.
          • luzmina
            • May 2015
            • 17
            • US
            #1145
            Here it is. Thanks
            • lotas
              • Jan 2016
              • 4530
              • Russia
              #1146
              Here it is. Thanks
              Try this Dump.
              • luzmina
                • May 2015
                • 17
                • US
                #1147
                The fixed file works!!! but the picture is still inverted, same as when using the 55ME314V/F7 DS3 file, Thanks
                • lotas
                  • Jan 2016
                  • 4530
                  • Russia
                  #1148
                  Here you need to try to enter the service mode through the remote control (you need to know exactly what code to dial on the remote control) and change the "mirror" item to ON or OFF.
                  • mnjoao
                    • Feb 2022
                    • 14
                    • portugal
                    #1149
                    good afternoon, along with the dump that works
                    thanks
                    • mnjoao
                      • Feb 2022
                      • 14
                      • portugal
                      #1150
                      thanks
                      • Storyteller12
                        • Jun 2020
                        • 624
                        Originally posted by Cantv
                        Hello , some one can share with me the EEPROM DUMP FOR Samsung tv UN60H7150 . Thank you in Advance .
                        I tried to read the eeprom for you but was unable to. Tv does work and has no problems at all.
                        For some reason this eeprom wont read. I tried a few others and they all read no problem.
                        Is there a trick to reading this one?
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          #1152
                          Firmware needed please for a polaroid p43d300fp
                          lcd panel VES430UNDA-2D NI2
                          MAINBOARD 17MB110P 23397404
                          • yokoono
                            • Apr 2010
                            • 479
                            #1153
                            For me in the archive is mb110 not 110p. If you want you can try.
                            https://files.fm/u/ve6hh359y
                            • vinceroger69
                              • Mar 2012
                              • 6714
                              #1154
                              Thankyou i will give it a try is it best too remove the ic and programe it that way using a ch341a
                              Edit just downlaoded the file i tried to extract it says no archive is either unknown format or damaged i have tried downlaoding it twice
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #1155
                                Changed to a diffrent pc downloaded files ok if using a ch341a which files do add? i have never really used a ch341a before thanks
                                • yokoono
                                  • Apr 2010
                                  • 479
                                  #1156
                                  I checked. The archive is good. Use another unzipped or newer version. Installation is done from the stick not with CH341.
                                  Do you know the installation procedure for Vestel electronics?
                                  • vinceroger69
                                    • Mar 2012
                                    • 6714
                                    #1157
                                    I picked two sets up yesterday for free both seem too have firmware issues, i have just ordered remotes for both sets so cant try the firmware until remote comes.
                                    please can you explaine the update procedure step by step and i will give it ago i have 1gb and 2gb usb memory sticks so hope that will be ok. Thankyou for your help.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #1158
                                      • yokoono
                                        • Apr 2010
                                        • 479
                                        #1159
                                        You need the remote control for installation. The installation is done with the OK key.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #1160
                                          Hopefully remote will come either today or tomorrow, what format do i need too wipe usb stick with and could you please tell me the procedure i will print if off for future refrence thanks.
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
