Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    Here is the Firmware that I pulled of a replacement board BN41-02528A BN94-10804K for Samsung UE70KU6000 7-" 6 Series TV (for backup) . Its an SPI NOR flash , pulled using a CH341A Chip programmer
      Need help guys! Need dump files for TCL LED 42B2500F
      Thank you in advance..
      attached is the non working dump
      Never stop LEARNING because life never stops TEACHING!
        Write the name of the motherboard and processor.
          Peace be upon you, please, I want a damper for a Samsung device
          Motherboards
          MT8226-EMMA BN-41-00974B
          the device name :LE40A559P4F
          May Allah reward you a thousand good.
          Danb take off
            Hello, I need firmware and good advice. Please.
            Techwood / jacket
            Board 17MB55
            Panel 1405
            Model TD22LED 13-3
            The TV remains on standby, the red light on the front flashes, the Vcc 3.3v, 5v, 12v, 24v, 1.2v voltages are present. The NT72567 microcontroller heats up to 50°C.
            Advice: do I need to reload the U114 and U115 serial flash or do I have to try the recovery software by USB drive. Could you get them for me.
              here is the mainboard of TCL 42B2500F . thanks in advance
                Done, try it.
                  thank you very much,
                    Done, try it.
                    the no working dump and your fixed dump is identical.. i use winmerge to compare both files.. anyway thanks.. i already got a working bin file for TCL LED42B2500F and TV now is working fine, i'll share the working bin to you guys..
                      I'm sorry, I mixed up dumps. Here is a worker.
                        Thanks.. gonna save that for future use..
                          The problem was in your dump at the address: 0xD3157 - change 6E to 2E.
                            Hello everyone, I need a firmware and good advice. Please.
                            Techwood / vestel
                            Card 17MB55
                            Panel 1405
                            Model TD22LED 13-3 22 inch screen
                            The television remains on standby, the red light on the front flashes, the Vcc 3.3v, 5v, 12v, 24v, 1.2v voltages are present. The NT72567 microcontroller heats up to 50°C.
                            Should I reload the U114 and U115 series flash or should I try the recovery software by USB key. Do you have the DUMPs, Could you give them to me.
                              Hi guys, I need dump for vestel 17mb82s panel VES430UNDL-2D-N12
                                Starlight t.eme380.61 d12535
                                HALO
                                GOOD DAY
                                i need a STARLIGHT LED TV MODEL: SL23V5000 LED BIOS
                                T.EME380.61 D12535
                                THANKS
                                i ll waithing your help
                                  Post your non-working dump here, I'll fix it.
                                  Hi!
                                  Can you please try to fix my Non-working dump from an "OK TV" (don't remember model) with MB TP.MS3663.PB818 ?
                                  Thanks.
                                    Originally posted by dimis7 View Post
                                    Hi!
                                    Thanks.
                                    try
                                      try
                                      I will check later today and let you know.
                                      BTW the model of tv is ODL 32631H-SB EL
                                      Thank you!
                                        try
                                        My friend lotas! I have great news!
                                        Your modified firmware is working perfectly!
                                        Thank you so much!
                                        So for future reference:
                                        TV MAKER: OK
                                        MODEL: ODL 32631H-SB EL
                                        M/B: TP.MS3663S.PB818
                                        Working Firmware: Download from post #1286 above
                                          Ok, congratulations.
