Eeprom dump thread!
This is a sticky topic.
    Re: Eeprom dump thread!
    thank you very much
    big work
      I have a couple of questions I hope someone might answer. Can the eeprom be read and written too while still on the board or does it have to be removed from the board? Also what blank eeprom chip numbers do we need to keep to be able to program them? Thanks so much for any advice....
      David
        Can anyone point me in the right direction for a uk bush 32" led tv with DVD player built in, firmware for USB update if possible please model LED32DVDW intermittent operation have to unplug and plug back in for it to operate again with the remote thank you
          Vizio V0370M Dump
          Submitted by ayhan yılmaz
          VIZIO VO370M
          Main board:3637-0502-0150(0G)
          Panel LC370WU
          FLASH:MX25L3205D
          U18
            Good afternoon,
            i hope i write in correct section.
            My blaupunkt tv refuses to power on despite all voltages are present.
            So i think i can be a firmware brick!
            i'm wondering if it exists a way to re upload the firmware using usb port by using a specif key press in tv buttons or using remote control ?
            Many thanks to anyone that can explain me how to do if it is possible.
            Otherwise i plan to dismount the eeprom to flash it outside so that i need the eeprom dump.
            Firmware for this TV:
            main board is t.msd309.btu87 (4k tv)
            and panel display innolux v390dk1-ls
            see pictures for more details. about my tv set.
            Thank you for your help.
              Here are good, tested working eeproms for a few Samsung TVs. Enjoy.
                Hi all, I am looking for an eeprom dump for a JVC LT-32C350
                Panel: LC320DXJ-SFE1
                Main Board: MS308C1-ZC01-01
                Any help would be appreciated
                  Hi all, here is the firmware for the JVC that I was asking for.
                    Hi PROTOTYPE-1, Here you go.
                      Thank you very much mjhera
                        hi i'm looking for a dump for vestel 17mb95m , panel is ves390unda 01
                        the tv is quadro,i tried a few dumps ,but i get only blinking led,one from finlux turns the backlight on,but nothing else...i put a new 25l1606 chip so i'm not sure if i need to flash something else on the chip except for dump?someone mentioned nand flash also?
                          I am after an eeprom dump for Toshiba 40L3453DB with mainboard 17MB95 and the panel is a VES400UNDS-2D-R7. The closest to working was with UPG20 files but screen was upside down and remote was no longer recognised. Many thanks.
                            Merci beaucoup, mon ami
                              Hy folks,
                              my first contribute to this thread:
                              Blaupunkt B32SHE56TC (known also as 32/56i-gb-1b-hbkup-de)
                              Mainboard: T.MSD309.B21B, display: LC320WXN SC B1
                              Eprom: 25Q32
                              Cheers, Janos
                                Blaupunkt BLA-39_68I-GB-1B-FHBKU-DE
                                Display: V390HJ1-L01
                                Chip: GD25Q32
                                Sorry, I can't gather more data on this device, because only the motherboard came to me.
                                Cheers, Janos
                                  17mb140
                                    I need the dump for coby ledtv3226 please.
                                    panel Samsung LTA320AN01
                                    best regards
                                      here it is for Samsung and lg panel
                                        ledtv3226 coby
                                          Hello, anyone have the dump for:
                                          Blaupunkt 40/148i-GB-5B-FHBKUP-EU
                                          Chassis: TP.MSD309.BP85
                                          Model: B40A148TCFHD
                                          Product code: BA40I148BFBKPE061
                                          Label on LED screen:
                                          Model: 0040CA001
                                          LSC400HM06
                                          Regards
                                          EDIT:
                                          While searching and try out multiple ROMs i find one compatible with the model:
                                          Code:
                                          40/133I-WB-5B-FHBKUP-EU
                                          B40A133TCFHD
                                          BS40I133BFBKPE061
                                          MATRYCA  LSC400HM06
                                          PG TP.MSD309.BP85
                                          PAMIĘĆ 25Q32
                                          Not exactly equal at references but very similar, it works without problems so far.
                                          I will keep testing for a day or two and i will confirm
