Eeprom dump thread!
This is a sticky topic.
  • lotas
    • Jan 2016
    • 4855
    • Russia
    #1121
    Re: Eeprom dump thread!
    It will be necessary to wait for a while, if possible, the core of dumps is badly damaged.
    • dodysallam
      • Jan 2022
      • 7
      • egypt
      #1122
      Ok try to find flash to this main board
      • asas
        • Oct 2013
        • Portugal
        #1123
        I need this file (http://www.dl.toshiba.com/dtv/NA/GB/EN/32W1333DG.html) to try wake to my Toshiba 32W1333DG (LED flashes red/green), but the Toshiba site is down!
        I need it to try to flash the TV via USB.
        Can anyone help?
        Thank you very much.
        UPDATE:
        The TV is working again!!
        I found the firmware here:
        https://www.elektroda.pl/rtvforum/topic3777677.html
        https://www.elektroda.pl/rtvforum/do...php?id=1076150
        And followed this instructions:
        https://www.badcaps.net/forum/showthread.php?t=52483
        "To install: Download the Zip folder and extract all the files on them to a Fat32 formatted Usb stick. After that insert the Usb into the LOWWER of the Usb ports on the Tv with the Tv ON and hold "ok" on the remote and the firmware upgrade will start."
        I did it slight differently: I put the USB stick on the LOWWER port, but with the TV OFF! After that i pressed the OK on the remote and plugged the power cord (that was the only way it start reading the USB stick!) after that the power LED start flashing red/green faster and in the end the TV waked up!!
        • gedmiri
          • Dec 2021
          • România
          #1124
          tv orion 32
          Hello! i need usb software for
          orion 32 or 17rds
          chassis 17mb211
          panel ves315wnds-2d-n14
          23411971
          sn 7889081 700399
          thank you in advance
          • lotas
            • Jan 2016
            • 4855
            • Russia
            #1125
            Originally posted by dodysallam
            Pleas I want dump for seiki model se32hy27 main tp.ms3393.p85 think for help
            Try everything Dump restored.
            • jeff260z
              • Jun 2014
              I'm looking for a dump for a Legend model: LE3233B
              Main board is TP.MS3393.PB851
              Panel is HW320WX2-206
              • lotas
                • Jan 2016
                • 4855
                • Russia
                #1127
                Post your non-working dump here, I'll fix it for you.
                • fixmypc
                  • Feb 2018
                  • Portugal
                  #1128
                  Hello everyone
                  Iam looking for a dump to this board:
                  TP-MT5522S-PC822
                  Its for a 50 inches, brand Silver Led TV.
                  My issue is that i cant get out of the android secure mode.
                  Thank all
                  https://obrazki.elektroda.pl/9371162300_1642626178.jpg
                  • sherif zayda
                    • Mar 2021
                    • cairo
                    #1129
                    Hisense LEDN46T28GP RSAG7.820.2121Re: Eeprom dump thread!
                    Hello everyone please dump
                    Hisense LEDN46T28NGP RSAG7.820.2121
                    25L3206
                    Last edited by sherif zayda; 02-03-2022, 10:04 AM. Reason: Hisense LEDN46T28NGP RSAG7.820.2121Re: Eeprom dump thread!
                    • lotas
                      • Jan 2016
                      • 4855
                      • Russia
                      #1130
                      Re: Hisense LEDN46T28GP RSAG7.820.2121Re: Eeprom dump thread!
                      Originally posted by sherif zayda
                      hello everyone please dump
                      hisense ledn46t28ngp rsag7.820.2121
                      25l3206
                      thanks
                      dump hisense ledn46t28gp rsag7.820.2121
                      • sherif zayda
                        • Mar 2021
                        • cairo
                        #1131
                        Thank you, I downloaded the flash and the screen turned on and everything is perfect except the sound does not work because I changed the screen model to version ledn40t26gp
                        The correct version is ledn46t28ngp
                        And I think it was the cause of the sound
                        And I want to see you cut off the sound and thank you for your presence
                        • lotas
                          • Jan 2016
                          • 4855
                          • Russia
                          #1132
                          Post your non-working dump ledn46t28ngp here, I'll fix it for you.
                          • sherif zayda
                            • Mar 2021
                            • cairo
                            #1133
                            I do not read it to damage the flash, as it is not felt by the programmer rt809h
                            And I tried it on another programmer, big prog, and the other one does not feel it, and the flash is clearly damaged
                            And thank you for your interest
                            • cheeky2
                              • Dec 2012
                              • 339
                              • uk
                              #1134
                              Well the answer would be to remove the flash ic and programme a new one in its place. Surely if you reprogrammed the existing one then you would have made a copy of the original one? If you didn't then it's always good practice to make a backup of everything on the original TV before doing any work on it. For this exact reason if you make a mistake you can remedy anything you have already done afterwards to try and resolve the issues with the TV.
                              Get a new flash ic and programme it up beforehand and not using the incircuit programming of your programmers to do so. That way eliminating any issues with it determining what flash ic it's voltages etc. Manually select the flash ic to ensure correct specs of flash ic are used.
                              • jeff260z
                                • Jun 2014
                                Thanks. I've been trying to read the eeprom but I keep getting all zeros from asprogrammer.
                                I'm using a CH341A and trying to read the chip while still on the board. I've tried to read the eeprom from two different tv's and am getting zeros every time. I'll keep trying to figure things out.
                                • Rajnhl
                                  • Oct 2018
                                  • 94
                                  • India
                                  #1136
                                  try with shorting crystal attached to main ic
                                  or programmer is not supplieng enough power to eeprom
                                  • lotas
                                    • Jan 2016
                                    • 4855
                                    • Russia
                                    #1137
                                    It should be like this at the beginning of the dump, unsolder the flash and try to read data from it.
                                    • RAZ777
                                      • Feb 2022
                                      • 18
                                      • uk
                                      #1138
                                      I have a toshiba 40l3653db with flashing green light, found this forum & thread searching google unsucessfully for firmware.
                                      Can anyone help, point me to any appropiate firmware?
                                      Its the vestel 17MB110 main board, screen is VES400UNDS-2D-N12.
                                      Thank you.
                                      • mnjoao
                                        • Feb 2022
                                        • 14
                                        • portugal
                                        #1139
                                        good afternoon, I have a polaroid TV tql40f4pr006 with the main board HK-T RT2957P63 panel V400HJ6-PE1-P7-12V for which the eprom dump was needed.
                                        thanks
                                        • luzmina
                                          • May 2015
                                          • 17
                                          • US
                                          #1140
                                          Hi, I need the bin file for Magnavox 55ME314V/F7 A4GR1MMA, panel U4DR0XH. I have the DUMP file but is corrupted, I am using the BIN file for the DS3 but I got inverted picture. Thanks
