Eeprom dump thread!
This is a sticky topic.
  • Steve007iii
    • Aug 2021
    • Costa Rica
    #1001
    Re: Eeprom dump thread!
    i need firmware for RCA 32
    Board: TP.MS3393.PB855
    • lotas
      • Jan 2016
      • 4859
      • Russia
      #1002
      What's the problem with the TV?
      Post your non-working firmware dump here.
      • Steve007iii
        • Aug 2021
        • Costa Rica
        #1003
        TV starts normally when put in Smart mode TV shows this ...
        TP.MS3393.PB855
        I need the firmware if anyone has them please
        ⚠ This Firmware is damaged ⚠
        Non-working firmware dump: https://www.mediafire.com/file/pm7ri...6S-SM.BIN/file
        32 inches
        modelo: RCA32A16S-SM
        • lotas
          • Jan 2016
          • 4859
          • Russia
          #1004
          Your software is fine, I cut off the eeprom now try to write it down
          if it fails, replace the SPI Flash with a new one.
          • lotas
            • Jan 2016
            • 4859
            • Russia
            #1005
            TP.MS3393.PB855
            32 inches
            Does the TV itself support Smart?
            He then had to have NAND or EMMC memory.
            • Steve007iii
              • Aug 2021
              • Costa Rica
              #1006
              NAND GODDAMN!!!
              it also has an android subsystem
              Not everything is lost
              someone in this forum was asking for this firmware for this board, there it is tested and working
              Originally posted by javox
              hola , me prodran ayudar con el firware de la pantalla cobia TP.MS3393.PB855 se los agradecere mucho. salu2
              Originally posted by aquilesy
              Hi, please your help, I need eprom dump for TV RCA Model RC4001-A board Nro TP.MS3393.PB855
              32 inches
              Model: RCA32A16S-SM
              https://www.mediafire.com/file/5r88m...nches.rar/file
              • lotas
                • Jan 2016
                • 4859
                • Russia
                #1007
                The firmware on your TP.MS3393.PB855 is ok, you need to look for the usb firmware on the android module or somehow enter recovery and do a reset.
                • medoali
                  • Jul 2020
                  • cairo
                  #1008
                  i hope some one can help
                  i need dump for Soniq L32V12A 32" LCD
                  thanks
                  • medoali
                    • Jul 2020
                    • cairo
                    #1009
                    thanks
                    main board ST306PT-T7
                    • giosat
                      • Jul 2021
                      • 5
                      • italia
                      #1010
                      Ciao
                      Tv lg47le5308
                      Main. Eax61766102(0)
                      Pannello lc470EUH
                      • Öğretmen27
                        • Oct 2019
                        • 36
                        • TÜRKİYE
                        #1011
                        Zenon ZN-AHD-5016 software
                        Zenon ZN-AHD-5016 software is needed. 25L12835F used. Fault: The device is stuck in the text zenon. There are all voltages.
                        Mainboard: GM8210-AHD-16CH
                        Flash ıc: 25L12835F
                        • zanskis
                          • Mar 2016
                          • Lithuania
                          #1012
                          hi.
                          i need emmc dump
                          sony
                          kd-49xe8096
                          main
                          1-981-326-12
                          (173633712)
                          GN3TR
                          thank you
                          The TV turns on and shows only the SONY logo.
                          I found
                          KD-55XF7596
                          KD-43XF7596
                          nothing changes, after resetting it needs to be refreshed via usb, and again only the SONY logo
                          • shuma66
                            • Aug 2021
                            • Egypt
                            #1013
                            Originally posted by Snazzysmith
                            Sorry didn't make notes on board number.
                            Please I need LG 42LB5RT eprom firmware
                            • shuma66
                              • Aug 2021
                              • Egypt
                              #1014
                              ٍٍSony BRAVIA® KDL-40EX500
                              System Software Update (version 1.514)
                              May Be Useful and Help
                              • cheeky2
                                • Dec 2012
                                • 339
                                • uk
                                #1015
                                Originally posted by bboykes
                                hi anyone got digihome 40272sm eeprom Vestel 17IPS71
                                You give the model of the power supply without giving any details of your screen or your main board. Unlikely anyone would be able to help you with the lack of information supplied.
                                • shuma66
                                  • Aug 2021
                                  • Egypt
                                  #1016
                                  Thank you
                                  • Shotgun25
                                    • Feb 2014
                                    • 90
                                    JVC LT-50C550
                                    UK model 55" TV
                                    Screen - V500HJI-PE8
                                    PSU - TV5001-ZC02-01
                                    Main - MSDV3255-ZC01-01
                                    TCON/Panel - Innolux V500HJI-XRME1 / V500HJI-PE8
                                    NAND - Toshiba TC58NVG1S3HTA00
                                    From a working TV that had LED backlight strips replaced.
                                    No password, 2 part rar.
                                    • Retrocomputer
                                      • Aug 2012
                                      • 47
                                      • Italy
                                      #1018
                                      Hi! I need the dumps for a cheap Trevi TV.
                                      Model DTV-2522CI
                                      Main HK-7050-CI-V3.04-B
                                      Panel M215HW01
                                      Don't actually care if it's Trevi branded or not, I just care if it works for watching TV.
                                      Thank you
                                      Davide
                                      • lotas
                                        • Jan 2016
                                        • 4859
                                        • Russia
                                        #1019
                                        Originally posted by retrocomputer
                                        hi! I need the dumps for a cheap trevi tv.
                                        Model dtv-2522ci
                                        main hk-7050-ci-v3.04-b
                                        panel m215hw01
                                        don't actually care if it's trevi branded or not, i just care if it works for watching tv.
                                        Thank you
                                        davide
                                        Токаї ltl-1902e hk-7050-ci-v3.04-b
                                        • Retrocomputer
                                          • Aug 2012
                                          • 47
                                          • Italy
                                          #1020
                                          First of all, thank you so much!!
                                          There's just one thing bothering me... The dumps you sent me are from a 19" TV, whereas mine has a 22" panel. Is it ok anyway?
                                          Thank you
                                          Davide
