Eeprom dump thread!
This is a sticky topic.
  • anmol
    • Mar 2012
    • 73
    • India
    #801
    Re: Eeprom dump thread!
    HV490QUB-B05
    DUMP PLS.
    • ans
      • Dec 2014
      • syria
      #802
      Hi, if possible, I need a Dumb Dump. Please help, my group. Thank you. A new screen is not necessary for you to work. Thank you
      dell-se2216h-monitor
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        #803
        Originally posted by skyx
        Thank you very much .. but for Philips 17MB82 file (panel)?
        What is VES code?
        https://www.badcaps.net
        • pocketwatch62
          • 74
          • US
          #804
          Hello all,
          Does anyone have a dump for a Element?
          Model----ELEFW248
          serial #----F75BM
          MAIN BOARD--- TP.MS3553.PA671------------ELEFW248 F7B5M Main---H17051233
          UF1 on the board.
          THANKS
          • LUXMAN
            • Mar 2014
            • Italia
            #805
            hi someone have a firmware for a SANSUI tvc2510
            • psycho_sev
              • Nov 2019
              • england
              #806
              Please can anyone help, i need serial flash (25Q32FVSIG) for technika
              model 22E21B-FHD
              board T.MSD306.80
              panel M215HGE-L21
              • lsizquierdo
                • Nov 2015
                • 6
                • Cuba
                #807
                I have a plasma which the standby led is in red without response, the model LG 42PN4500-UA I need the dump of the 8mb spi if someone could provide it. These are the photos of the pcbs with their respective modelsD
                • Range
                  • Aug 2020
                  • portugal
                  #808
                  good presiso of firmware for tv
                  Blaupunkt "32" B32A173TCFHD - Mainboard t.msd309.9B 10345 could someone help me
                  • dragometin
                    • Aug 2016
                    • 20
                    • France
                    #809
                    Model: Crown ALCD1509SGB
                    MainBoard: B.SPC81B-1 9245
                    Screen: LP156WH1-TLA1
                    Model: Grundig 22VLE4520BF
                    MainBoard: VTY190R-23
                    Screen: T215HVN01
                    • Rajnhl
                      • Oct 2018
                      • 94
                      • India
                      #810
                      Toshiba_32PT200ZE DUMP
                      PANEL LTA320HN03
                      TCON DUMP included
                      • Range
                        • Aug 2020
                        • portugal
                        #811
                        Blaupunkt "32" REF: B32A173TCFHD -
                        Model code: 32 / 173I-GB-5B-FHBKU-EU
                        Customer code: BA320173BFBKUE340
                        could someone help me turn on the led but it turns red
                        • Rajnhl
                          • Oct 2018
                          • 94
                          • India
                          #812
                          model number is different but board is same.backup before flashing.
                          if it starts and turn off immediately check power supply for bad capacitors.
                          • baluka3
                            • Aug 2020
                            • Hungary
                            #813
                            Hi!
                            Can you send me this firmware? Download link does not work
                            Thanks!
                            Originally posted by cheeky2
                            Just had a Blaupunkt 43/134M-GB-11B-FEGUX-UK with main board TP.MS6486.PB711 and screen LC430DUY-SHA1
                            It required firmware which can be requested from here:
                            http://www.umc-poland.com/datasheet/...-11b-fegux-uk/
                            Use email to request it:
                            poland@blaupunkt-europe.com
                            Its 297MB in size so unable to upload here!
                            However looking at one of the files the 'UMC_KMODE.txt' contains details as to what is enabled ie PVR which is currently disabled so by changing these I have now enabled the PVR options on the TV. It works well now
                            Attached is the original file and modified one to enable the PVR options.
                            I would suggest if you wish to use the PVR that you use the 297MB file that UMC send you just substitute the 'UMC_KMODE.txt' file with the one in the modded folder.
                            The original and modded files are attached.
                            See attached pictures of PVR working
                            • JeffJ
                              • Apr 2012
                              • 189
                              Anyone have a dump from a LG 32LH500B / LG 32LH520B ?
                              • cheeky2
                                • Dec 2012
                                • 336
                                • uk
                                #815
                                Originally posted by baluka3
                                Hi!
                                Thanks!
                                Why have I put the following here in the details???
                                Use a better web translator for translation to your language.
                                • ans
                                  • Dec 2014
                                  • syria
                                  #816
                                  Welcome to the EEPROM SE2216HV Main Board 790JW1300601R00
                                  Dell
                                  https://www.4shared.com/get/JS_pneAR...4_E2216HV.html
                                  • Farasa
                                    • Jul 2016
                                    • 47
                                    • South-Africa
                                    #817
                                    Hi all
                                    I'm looking for firmware for a logic 46 inch lcd tv..stuck on standby
                                    Chassis number:Rsag7.820.2164
                                    Panel. :Lta460hm05
                                    Thanks in advance
                                    • Farasa
                                      • Jul 2016
                                      • 47
                                      • South-Africa
                                      #818
                                      Hi anyone available
                                      • Rajnhl
                                        • Oct 2018
                                        • 94
                                        • India
                                        #819
                                        Originally posted by Farasa
                                        Hi anyone available
                                        There are 3 files try one by one.if you have any programmer try to read dump from your tv then write one of any file from my zip file.then again write your dump some time this helps.
                                        • jose almeida tavares
                                          • May 2011
                                          • 8
                                          #820
                                          Finlux fl5031uswk chassis 17mb120
                                          Hell. This tv not work. the front led, flash one time when the tv is conected in ac and not work. i need the data for memory dump. the pael is ves500qndc-2d-n12.
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
                                          • jimha
                                            LG 34UC99 EEPROM dump
                                            by jimha
                                            Hi ,
                                            I'm looking for a dump to repair my screen
                                            12-09-2024, 03:52 PM
