Eeprom dump thread!
This is a sticky topic.
  • dinche_ze
    • Feb 2020
    • 16
    • Bosnia Hercegovina
    #701
    Re: Eeprom dump thread!
    vox led tv dump need u10, u12
    led32783
    mainb: 17mb82s
    panel: VES315WNDB-02
    • ktgohdt125
      • Jun 2010
      • 10
      #702
      does anyone have Eeprom files for Philips 48PFA4609/98 Firmware
      I was saving a copy of the working EEPROM .bin files to post over here but the files which were only reading a 64kb size, re-read and re-save another copy still 64kb size, after that, I proceed to erase the file and reprogram back using the files save previously, the tv seems not responding any more!!
      so, anyone has this particular model dump files??
      ps. normally how big is the size of the dump files from a working tv??
      • arizanotlari
        • Nov 2014
        • 158
        • Turkiye
        #703
        led32783
        mainb: 17mb82s
        https://yadi.sk/d/_X9A0UGQ2Cqe1g
        https://www.badcaps.net
        • dinche_ze
          • Feb 2020
          • 16
          #704
          thanks, I will try
          • spaljo
            • Jan 2020
            • Ireland
            #705
            Is it possible that noone have Eeprom files for philips 49PUS6162 would like to save my tv
            • dinche_ze
              • Feb 2020
              • 16
              #706
              Originally posted by arizanotlari
              Thanks, but its not working god, the picture od upside down and Graphics is low,
              • arizanotlari
                • Nov 2014
                • 158
                • Turkiye
                #707
                Panel files : https://yadi.sk/d/xO8YaifqoCqtgw
                extract pq folder to usb.
                access to service menu and select "usb operations"
                restart tv and check picture.
                • dinche_ze
                  • Feb 2020
                  • 16
                  #708
                  the file is damaged, can not opet
                  • RRice25541
                    • Nov 2015
                    • 47
                    Insignia NS-37D20SNA14
                    looking for an eeprom dump or a firmware update file for this tv
                    • arizanotlari
                      • Nov 2014
                      • 158
                      • Turkiye
                      #710
                      Update winrar.
                      • Kidface
                        • Feb 2019
                        • Uk
                        #711
                        Originally posted by cheeky2
                        Just had a Blaupunkt 43/134M-GB-11B-FEGUX-UK with main board TP.MS6486.PB711 and screen LC430DUY-SHA1
                        It required firmware which can be requested from here:
                        http://www.umc-poland.com/datasheet/...-11b-fegux-uk/
                        Use email to request it:
                        poland@blaupunkt-europe.com
                        Its 297MB in size so unable to upload here!
                        However looking at one of the files the 'UMC_KMODE.txt' contains details as to what is enabled ie PVR which is currently disabled so by changing these I have now enabled the PVR options on the TV. It works well now
                        Attached is the original file and modified one to enable the PVR options.
                        I would suggest if you wish to use the PVR that you use the 297MB file that UMC send you just substitute the 'UMC_KMODE.txt' file with the one in the modded folder.
                        The original and modded files are attached.
                        See attached pictures of PVR working
                        Hi, do you still got this firmware? On the UMC website the link is broken, couldn't download it
                        Can you upload it to afile sharing site? or do you have a working link?
                        Thanks!
                        • ahd540
                          • Nov 2019
                          • maroc
                          #712
                          merci bien mon ami a vos efforts: maladroit:
                          • NMA78
                            • Feb 2020
                            • France
                            #713
                            Originally posted by ducky29
                            Sent him a firmware and it worked correctly.
                            Thank you tremors!
                            Hello, I'm having the exact same problem with my Toshiba 24w1334g. Would it be possible for you to send me the firmware so I can get it working ?
                            Thanks for your help.
                            • jellytot
                              • Mar 2015
                              • 42
                              • Ireland
                              #714
                              Try this! and if you could let us know if it worked for you ...
                              • NMA78
                                • Feb 2020
                                • France
                                #715
                                Thank you very much. In fact it is not working, I tried to flash it with simply putting the .bin in the USB and the led stayed black, nothing happened. Then I tried renaming it mb90_en.bin and placing the mboot.bin and the usb_auto_update_A1.txt with it. The led starts blinking but the process never ends (> 20 mn or so).
                                Is there anything I should do to make it work better ?
                                Thanks you very much for your help
                                • yokoono
                                  • Apr 2010
                                  • 481
                                  #716
                                  This soft is for programmer not for stick.
                                  • sdfy
                                    • Apr 2019
                                    • Ukaine
                                    #717
                                    Hi Everyone,
                                    Does anyone have the dump for a
                                    Metz 49X79
                                    IC6022 25Q16
                                    • ducky29
                                      • Dec 2015
                                      • 370
                                      • Europe
                                      #718
                                      Pls pm me
                                      • Rajnhl
                                        • Oct 2018
                                        • 94
                                        • India
                                        #719
                                        http://www.dl.toshiba.com/dtv/NA/GB/EN/24W1334G.html
                                        try this
                                        • Jovica123
                                          • Oct 2017
                                          • 75
                                          • N/A
                                          #720
                                          Does anyone have NAND for sony kdl-32r415b ?
                                          Thank you.
                                          • AlexGsmMaster
                                            Eizo CS2740 eeprom dump, search.
                                            by AlexGsmMaster
                                            Good day to all, I have a big problem. I can't find the eeprom dump for the Eizo CS2740 monitor. The device doesn't turn on, the indicator just lights up. It responded to connecting to the PC once. The update process started with the standard program and then disconnected from the computer. The computer doesn't detect it anymore. If anyone has an eeprom dump, please share.
                                            Yesterday, 03:24 PM
                                          • (0)_(0)
                                            Looking for a HP Photosmart C4280 EEPROM dump
                                            by (0)_(0)
                                            Hello, This might be a long shot, but I'm looking for an EEPROM dump for a HP Photosmart C4280 All-in-one printer.
                                            The printer seems to be in cartridge alignment mode. Sometimes it print the alignment page and then hangs during the scanning step, sometimes it hangs during the printing process and sometimes it hangs during the boot process. If I let it idle for a while then it flashes the back-light of the top screen and there's a letter E. Bottom screen is asking me to restart it to no avail. I have to remove the power cable from the printer for a couple of minutes to make it work...
                                            02-17-2022, 09:09 PM
                                          • my2k2
                                            Harman Kardon AVR 171, Request for IC1504 (24C32) eeprom dump file
                                            by my2k2
                                            Good day to every one,
                                            I have AVR 171 the IC1504 (24C32) eeprom is corrupted not able to read.
                                            Does anybody have an eeprom dump file? I really appreciate any help.
                                            Thanks in advance.
                                            07-01-2024, 09:04 PM
                                          • Whale linguini
                                            p14s Gen 2 thunderbolt eeprom dump
                                            by Whale linguini
                                            P14s Gen 2
                                            HT4B0/HP4B0/HT5B1/HT4B2
                                            NM-D352 Rev 1.0
                                            sn PF-35P15W
                                            Requesting thunderbolt dump
                                            also attached is the tbt dump. I extracted the bin from the cap file and modified it, not sure if it's correct. also didnt work....
                                            09-03-2024, 01:56 PM
                                          • Ancient1
                                            Before I dump this Panel...
                                            by Ancient1
                                            Hi
                                            I was working all day on a 42" with no backlight = Driver is bad . LED Tester. Image exists
                                            As I was reassembling, I discovered faults on the screen ( used the LED Tester to power the strips).
                                            Right distribution board, 2 Flexs, near them:
                                            The one near the center has 1" line on screen. Pressing on the board-side or Panel side of the Flex bonding place results in some change, I sensed heating one time, but main fault line remains
                                            The other, pressing on the Panel to the Chassey and the lines disappears 99.99%
                                            I...
                                            10-23-2022, 11:07 AM
