Just for a laugh
  • finntricky
    • Jan 2014
    • 449
    Just for a laugh
    picked this JVC vestal tele up to night, turns on but no picture, but you get sound,
    well done the normal checks and then decided to remove the screen to do the dud LED's.
    this is what i found,
    one of the leds even worked, and its bright RED, LOL
    just had to share this repair that has failed.
    anyone else come across anything like this before ?
  • jondoe
    • Nov 2016
    • 547
    Re: Just for a laugh
    Mistakes have been made....
    • Diah
      • Feb 2013
      • 6594
      ho did that , of sure learn this over here to bridge the defective one with diode or on you tube
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        That's not a repair , thats Vestel right from the factory!
          Someone went inside the screen and put in the wrong LED, must be one of those DIY repair man.
          • R_J
            • 9624
            Just add a Green and a Blue led accross it
            • RukyCon
              A Fake Rubycon
              • Jan 2017
              • 816
              whoever repaired it clearly used LEDs they had lying around at the time
              I'm not a expert, I'm just doing my best.
              • kc8adu
                • Nov 2003
                • 8832
                • U.S.A!
                and i thought mfj soldering was bad.
                • odgaf
                  • Apr 2015
                  • 36
                  vestels patented advanced soldering blob passive heatsinks dissipate heat from failing LEDS prolonging the life of your tv set for at least 3 months
                  showcased by the LED on the left, while the led on the right is a factory kogan
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Brilliant. I wonder what the repair cost was on that one.
                    • RukyCon
                      A Fake Rubycon
                      • Jan 2017
                      • 816
                      the old LEDs look like 1Watt SMD LEDs with diffuser lens
                      • Dumah Brazorf
                        • Jun 2013
                        • 179
                        • Italy
                        You all not understand. It gives warmer images, perfect pair with a happily running fireplace during winter holidays.
                        • llonen
                          • Sep 2014
                          • 495
                          • hampshire
                          Quality job there
                          • SLK001
                            • May 2014
                            • 264
                            I've done this when I needed to verify the operation of the LED power supply (and I didn't yet have the correct LED). I, however, used leaded WHITE LEDs. I don't imagine that a red LED will work (for very long) due to both the much higher current and the voltage.
                            • Pipolups
                              Corsair K70 LUX RGB dying LEDs
                              by Pipolups
                              Hi there !
                              I'm having an issue for several weeks with my quite old K70 LUX RGB keyboard. I haven't used it for few months, and once I setup up again my desktop computer, I got several dead LEDs on that keyboard. I tried the Corsair troubleshooting thing (disabling options in iCUE, ...) but nothing changed so I conclude that for some reason some LEDs went in retirement...😅
                              Decision taken to change these LEDs as I have access to desoldering iron and binocular magnifier, I wrote a ticket to tech support, hopping to obtain the LEDs reference and... They refused to tell me 🙄...
                              10-08-2024, 11:58 AM
                            • THE GTC
                              Insignia NS-37D20SNA14 intermittent LEDs
                              by THE GTC
                              So I use this TV daily as a second monitor for my PC or my Playstation - at one point a few months back I tried to fix the problem - but in the process, I figured out something that works so I haven't posted this for awhile. It is an annoying trick to have to do though, so I decided to post about it to see if anyone could spot what's wrong. It baffles me because it works on it's own half the time.
                              When I first got this TV, I was told it wouldn't turn on, and of course I did the flashlight test, and the image was there. Also, the red LED on the front indicated that it had power (it...
                              11-03-2020, 02:40 AM
                            • pni
                              Backlight panel diffuser melt by backlight leds broken
                              by pni
                              Hi guys, I changed my backlight to a 5g in Samsung but the broken leds burned the thick plastic panel . I give the photo. Do you think if I try to rotate the panel, with the botton on the top I have a good image? Becacause now how u can see, on the light color I sse the leds because of the burned on the plastic diffuser....
                              10-12-2025, 12:08 AM
                            • VitalComputing
                              Replacing Mode Indicator LEDs
                              by VitalComputing
                              I have what should be a simple job but is causing me issues. There are three LEDs (yellow, green and red) on the indicator panel of a solar PWM controller and these have broken off. I need to replace them but I am unsure of the voltage drop across these. I don't want to replace with random LEDs in case they blow.
                              I took one of the LEDs out of circuit, put 19V across it with a 500 ohm resistor in series and there is a drop of about 13V across the LED, and this seems to increase as I increase the input voltage.
                              I thought I could just put a resistor...
                              09-17-2023, 04:43 PM
                            • jimbofz
                              just a quick question do all qled leds appear blue when fault finding ?
                              by jimbofz
                              i have replaced many leds strips that have changed blue when they are worn
                              and the new replacements are perfect white
                              but when fault finding do quantum leds always look blue?
                              08-28-2024, 06:51 AM
