Samsung ue48h6400 horizontal lines
  • Rob0904
    • Dec 2016
    • 57
    • Uk
    #41
    Re: Samsung ue48h6400 horizontal lines
    Svc said 143hrs but that might be from when I reset it, but not thru the service menu.
    Lines are still here...
    • Diah
      • Feb 2013
      • 6358
      you have with 3D normal view with out line.. from my point its not panel fault. its much likely with IC1001 MB had issue with low frequency. download the last version firmware to force the TV to reslash it . if this not help try to put pressure on the Main Board where the big IC1001 if the line disappear.
      • Rob0904
        • Dec 2016
        • 57
        • Uk
        #43
        I will have a mess with 3d and the boards. Tv is on auto update so all up to date. Or should I try manually downloading?
        • Rob0904
          • Dec 2016
          • 57
          • Uk
          #44
          Just tried switching between 2d and 3d definitely no lines in 3d mode. I will try a manual update and if no luck I will flex the board.
          • Diah
            • Feb 2013
            • 6358
            Originally posted by ReeceyBurger123
            BS Ive had it where a horizontal tab driver caused equally spaced lines on an Led set also alot of other panels in the same way mainly samsung ones dont spend another penny on it OP it will need a new panel or the failed edge driver remove.
            don't act here look like lion pissing to narrow its revere. ... read and learn.. this is digital world ---- its like ocean no one can swim at it alone neither me. so calm down and leave this habited ... okay..
            looking forward to yours update.
            • Rob0904
              • Dec 2016
              • 57
              • Uk
              #46
              I've got the latest firmware already installed, is there any way to downgrade and then reinstall the latest version?
              • Diah
                • Feb 2013
                • 6358
                could you test to change the picture size to display as 4:3 not other format if the line there too ... ! you can also test all picture format
                • Rob0904
                  • Dec 2016
                  • 57
                  • Uk
                  #48
                  I have tried that, lines are still there on all screen size. I haven't had chance to mess with the main board
                  • Diah
                    • Feb 2013
                    • 6358
                    are you sure before you replace the T-CON and at your test that you didn't harm the LVDS socket ... as yours set 120Hz so it should be art of 4ch. take look on attach
                    • Rob0904
                      • Dec 2016
                      • 57
                      • Uk
                      #50
                      The lines haven't changed at all from before and after the lvds clean and reseat. they didn't change when I replaced the tcon. I haven't had the back off the tvs to test pressure on the ic1001, but will try to get time over the weekend.
                      • vinceroger69
                        • Mar 2012
                        • 6714
                        #51
                        certainly a odd fault that you have lines in 2d but not 3d mode
                        • Rob0904
                          • Dec 2016
                          • 57
                          • Uk
                          #52
                          I know hahaha it's not unwatchable but I find myself looking for the lines...
                          • vinceroger69
                            • Mar 2012
                            • 6714
                            #53
                            yes i had a tv once i repaired with 1 dead pixel drove me crazy lol as i new it was there no one else seemed to notice it at first until i pointed it out
                            • Rob0904
                              • Dec 2016
                              • 57
                              • Uk
                              #54
                              Haha yeah that's how I am. Too tight to splash out on a new TV tho...
                              • vinceroger69
                                • Mar 2012
                                • 6714
                                #55
                                luckily that wasnt my set with the dead pixel it was one i repaired the psu on for someone i tend to use them for a few days myself to make sure the tv functions as it should etc no overheating faults etc.
                                • Diah
                                  • Feb 2013
                                  • 6358
                                  yes you are right. but such fault go always to bad connection ( include cold solder point) almost now only the main IC on MB did this fault. if as he said LVDS are good.
                                  maybe the time now to take the MB to the kitchen oven
                                  • Rob0904
                                    • Dec 2016
                                    • 57
                                    • Uk
                                    #57
                                    Haha I could do that but the misses wouldn't be to impressed if I finished the tv off. I could order a replacement lvds cable to test that.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #58
                                      maybe worth trying a lvds lead if very cheap not sure what mainboards go for in this set but its a very big risk if dosnt fix the issue but i guess you could re sell it on.
                                      • Rob0904
                                        • Dec 2016
                                        • 57
                                        • Uk
                                        #59
                                        Lvds cables on eBay are around £10 or mainboard £30ish.
                                        • vinceroger69
                                          • Mar 2012
                                          • 6714
                                          #60
                                          not bad prices then maybe worth trying just make sure if you get a mainboard you match all the numbers etc and your lcd panel number
                                          • Ihandyrepair
                                            Samsung QN70Q6DTA Ghost or horizontal lines after tape fix horizontal line
                                            by Ihandyrepair
                                            Hi guys
                                            I just started fixing 4k TV few months ago. so I am still learning a lot
                                            I got this tv from friend complaint is ghosting or horizontal lines on image.
                                            never saw the original symptom but I took the tv back home. the funny part is that after bringing to home, the tv worked fine no issue for 3 weeks.
                                            then it started to show the ghosting white image.
                                            I started using the tape method, but this tv does not have a T con board and it has only 1 ribbon cable from main board to the tv panel.
                                            it has 3 thin small boards at the bottom of the...
                                            12-05-2022, 04:18 PM
                                          • Rubenlily
                                            Samsung QE50Q67TAU - horizontal lines
                                            by Rubenlily
                                            First of all I'm new here. While looking I found this amazing forum and I'm very happy I did. Now for my problem:
                                            I picked up a Samsung UHD QLED QE50Q67TAU from 2021 for $50 knowing it was defective. The seller said it had black lines and that it could get stuck in boot randomly.
                                            I've tried a new power cable, hard reset, opening up and jiggling all cables, pressing everywhere to see if I get a reaction but I've gotten nothing. I've tried the tape method but I've only managed to get the lines worse.
                                            I'm no expert but I've done the tape...
                                            08-16-2023, 01:12 PM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA vertical bars/horizontal lines
                                            by x_orange90_x
                                            I posted about this previously but didn't get any response, and I have some troubleshooted a bit so I have more info.
                                            The screen is full of horizontal "gaps" or lines that distort the picture badly, and after about 10 seconds of powering it on the screen starts to fill with red vertical bars that take on the horizontal pattern. After the screen filled with the red bars, they instantly vanished and then slowly started to reappear. I initially thought it was tab bonding failure, but after getting down to them and pressing each one I find zero change in the picture. I went...
                                            09-04-2023, 12:09 PM
                                          • arctor
                                            samsung 50tu8070u black display with horizontal green lines, sound and backlight ok
                                            by arctor
                                            hi guy my friend gives me this tv a 50tu8070u that has no picture at all, sound ok, backlights ok. i tought it was a bad panel, but the tv has many horizzontal lines green, i tried with the tape method but nothing change, only the green lines disappear but still no picture. You that have more good than me, do you think it s a panel or can be the main board, because my friend wants buy a new main board....but the tv respond to the remote control, have sound only no picture so i think it s a panel problem that is so broken that i cant fix with tape...or i wrong if someone can help me thanks, i give...
                                            04-26-2025, 05:22 AM
                                          • x_orange90_x
                                            Samsung UN46C8000XFXZA Horizontal lines
                                            by x_orange90_x
                                            I just acquired this 3D LED yesterday and it has horizontal lines on a little more than half of the screen. When I first turn it on it has thin black lines going across that makes the image look serrated, and then shortly after patterns of thicker red lines fade in. If I turn it off and right back on it will reset to just the black lines and the red will again fade onto the screen.
                                            I initially thought tab bonds, but flexing the bezel makes no difference, and the fact the image sort of resets after cycling power is different. I haven't opened it up yet to actually test applying...
                                            07-15-2023, 05:06 AM
