Vizio VO370M-C Vertical Lines
  • KoenigsTiger
    • Jan 2017
    • 25
    Hey Everyone
    I have colored vertical lines on my LCD Vizio-oh. The sticker on the TV says 2009... They seem to alternate colors and brightness, they move on the screen, not just fixed in one spot. All inputs have the same symptoms. Sound is fine.
    About 6 months ago the screen got a bit darker, so I turned up the brightness. It worked fine till recently.
    The vertical lines showed up. Few days ago it would work for an hour then the lines appeared. The next day I turned on the TV the lines showed up right away, but after 15 min or so they were gone and TV worked for the evening. Next day lines are here to stay. I had the TV on for about an hour, no changes.
    I did a visual CAP check on power and logic board, none are popped or leaking...
    I pulled the connectors for the T-CON board. When I pull one connector from T-CON the corresponding side of the screen goes blank, vise versa for the other connector. When I pull the connector feeding the T-Con the whole screen does blank...
    I tried the compressed air over the T-Con, to cool it. I did not invert the compressed air can to have the freezing white stuff hit the board. I am not sure what part I need to spay???
    I checked the T-Con fuse continuity is good.
    Should I be checking the voltage on the T-Con somewhere??
    Would a factory reset help?
    I would really appreciate all the help!!!
    Thank you very much
    Gene
  • petehall347
    • Jan 2015
    • 4423
    • United Kingdom
    Re: Vizio VO370M-C Vertical Lines
    start at u1 and work your way through if needed ...
    • KoenigsTiger
      • Jan 2017
      • 25
      Hi Pete,
      Thank you for the lightening fast reply
      I'm just a nooby... I never fixed a TV before.
      U1 thats on the T-Con board? What should the voltage be?
      Thank you,
      Gene
      • petehall347
        • Jan 2015
        • 4423
        • United Kingdom
        i meant cool that one first ..
        sorry i am fairly new too really .. just being logical .
        • KoenigsTiger
          • Jan 2017
          • 25
          I see U2. Do you mean the large chip in the middle? UC1?
          The T-Con board has a blue LED on it. The LED turns on as soon as the TV is turned on, after approx 10 seconds the blue light turns off.
          What does that mean?
          • petehall347
            • Jan 2015
            • 4423
            • United Kingdom
            big one is uc1 ...
            this could well be a different problem ..
            hopefully someone with more knowledge will turn up soon .
            • KoenigsTiger
              • Jan 2017
              • 25
              Yep, I don't see U1.
              • petehall347
                • Jan 2015
                • 4423
                • United Kingdom
                8 legs
                  Try having one ribbon cable between the LCD panel and the T-con board connected one at a time to see what you get on the screen, you MUST BE REAL CAREFUL when you put the cables in place.
                  I am leaning toward bad panel.
                  • KoenigsTiger
                    • Jan 2017
                    • 25
                    Gotcha, thanks, I see the U1 now.
                    I tried cooling a bit, didn't make any difference. How long should I be cooling it for? I even inverted the can of compressed air to get the liquid hit it. Should I just take the whole thing outside it out side, its -22*C?
                    • KoenigsTiger
                      • Jan 2017
                      • 25
                      Should I be disconnecting the ribbon cables while TV is on or off?
                      I disconnected them while TV off, and the side for corresponding side goes blank.
                      Anyone know what the blue LED light is on the T-Con for?
                        TV unplugged when making pluging/unpluging the cables.
                        So with just one ribbon cable between the T-CON and the LCD panel one at a time, you do not see good clear image on half of the screen?
                        • KoenigsTiger
                          • Jan 2017
                          • 25
                          Oops, I had the TV plugged in, but turned OFF.
                          Ribbon cable disconnected; side of screen completely white.
                          Ribbon cable connected side, same as before.
                            BTW, is that the picture of your T-con board or from the web?
                            Next, test the DCV on the test points of the T-CON board, check:
                            VCOM, VGH, VGL, VCC, VCC1.8.
                            What is the designator for the LED on the T-CON board?
                            Your picture is too blur, I found board on SJ which is pretty close to your board but I do not see the SMD LED any where.
                            http://assets.shopjimmy.com/media/ca...-1565a-top.jpg
                            • KoenigsTiger
                              • Jan 2017
                              • 25
                              Yep, that's my actual t-Con.
                              LED designation is LD2
                              Sorry, iPhone4 quality....
                              • KoenigsTiger
                                • Jan 2017
                                • 25
                                Blue LED is illuminated for about 10 sec after TV is turned on.
                                • KoenigsTiger
                                  • Jan 2017
                                  • 25
                                  Ld2
                                    OK, the board version from shopjimmy does not have the LED installed.
                                    I really do not know what the LED indicator is for.
                                    • KoenigsTiger
                                      • Jan 2017
                                      • 25
                                      Odd, Jimmy's T-Con is missing a bunch of parts compared to mine. Part number seems to be the same...
                                        That Blank PCB P/N 6870C-0247A can be stuff in many ways to make a bunch of different PCBA (PCB Assembly) for many LCD panels.
                                        The P/N of the PCBA should be some where on the board, may on the back side of the board.
                                        http://assets.shopjimmy.com/media/ca...65a-bottom.jpg
                                        • Stanley1843
                                          by Stanley1843
                                          Hello, I have a screen in where sometimes when I open it pop-up vertical multicolor lines (I would say the most of them are green). If I tun off and turn on the screen the lines dissapear or if I leave open the screen after approximately five minutes the lines gone. I measured the below voltages on the main PCB and on the T-CON board and the voltages are the same when it doesnโ€™t display the vertical lines and when it displays the vertical lines. Also, I cleaned all the connectors very good with IPA. I moved back and forth the connectors and the COF tabs but the vertical lines didn't displayed...
                                          06-29-2024, 11:54 AM
                                        • brad2157
                                          Vizio E70-E3 Two white vertical lines
                                          by brad2157
                                          I picked up a Vizio E70-E3 for free that shows Vizio logo and then goes to a black screen. Original owner said he started having wifi issues and then he tried to reset the TV and that's when it wouldn't boot up any longer after his reset attempt. I picked up a replacement main board from eBay that matches the same model # board as the original from the TV.
                                          Original main board - Shows Vizio logo when TV powers on, then goes to black screen. Doesn't boot up. No screen issues with any lines on start up Vizio logo.
                                          Replacement main board - Boots up fine, but starting...
                                          12-13-2021, 05:11 PM
                                        • howardc64
                                          Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                                          by howardc64
                                          Failure Symptom
                                          No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                                          Where is the short?
                                          Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                                          Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                                          05-27-2025, 02:56 PM
                                        • Daren87
                                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed๐Ÿ™
                                          by Daren87
                                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                                          08-13-2023, 03:25 PM
                                        • gpo23
                                          Sony KDL-40V3000 - Vertical lines
                                          by gpo23
                                          i order a t-con because i had bad colors on my SONY KDL-40V3000 :
                                          With the new t-con the color are good but there are vertical lines on all the screen :
                                          I've tried the old t-con and it returned to the initial issue (bad colors but no vertical lines)
                                          Is there a way to fix the vertical lines on the new t-con ?
                                          Thank you for your help
                                          gpo23...
                                          10-04-2023, 09:11 AM
