Standby light only LG LG42LB5500
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Picked this unit up cheap and thought it would be an easy repair, (Panel looks fine and undamaged) unsure of history only going on the words of the seller. Seller says he had a power cut and the TV never came out of standby after that.
    So, the TV powers onto standby only and will go no further my first thoughts the Mainboard has become corrupt, just wondering if anyone has any advice to throw out there. Will add better pics ASAP, but the Mainboard, PSU and Panel numbers are as follows:
    MB
    MZM4526-64029 MT EBT62973012
    LD44B EAX65361503 (1.0)
    DISPLAY
    LC420DUE (FG)(A6)
    PSU
    EAX65423701 (2.0)
    LGP3942-14PL1
    Thanks in advance.
  • vinceroger69
    • Mar 2012
    • 6714
    Re: Standby light only LG LG42LB5500
    maybe you can dissconnect the mainboard and test the voltages are all there ie 12v and 24v etc that way it will rule out a bad psu
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      To test Psu unplug Mb and it turns on then test voltages let us know.
      • StephenU
        • Dec 2013
        • 230
        • United Kingdom
        Thanks guys, much appreciated. will let you know the outcome.
        • Andrew F. Ali
          • Jan 2014
          • 2450
          • Trinidad & Tobago
          You have a Main Bd issue......Replace the Main Bd.....that will solve your problem.
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            When plugged in and checked output from psu I only get the 3.5v, no 12v or 24v
            • ReeceyBurger123
              Never Give Up !
              • May 2014
              • 7325
              • Britain
              It might require you to force it on normally they dont on these Lg Leds, do what Vince says.
                if there is no PS-ON signal from the main board to turn on the power supply/LED driver board then there will be no switched 12V/24V.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Hang on bud Ive had this same set thinking about it Led fault but I thought it was in standby but unplugging the Mb would bring the Smp up. But could be different also shown in a video of mine.
                  • StephenU
                    • Dec 2013
                    • 230
                    • United Kingdom
                    Hi budm I've shorted the PWR-ON to 3.5v rail on the connecter of the PSU and the PSU gave me the 12v and 24v. I'm thinking mainboard issue.??
                      If you can force on the power supply then the power supply is OK.
                      You should report the DCV reading of the pins of the connector of the power supply board that goes to the main board, make sure to give the pin names and floow by the DCV reading so we can see what are missing.
                      • Andrew F. Ali
                        • Jan 2014
                        • 2450
                        • Trinidad & Tobago
                        Originally posted by andrew f. Ali
                        you have a main bd issue......replace the main bd.....that will solve your problem.
                        +1
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          Originally posted by Andrew F. Ali
                          +1
                          Lol plus 1 your own comment, also I agree replace mb. But he could try a new flash Ic or reflowing it.
                          • Andrew F. Ali
                            • Jan 2014
                            • 2450
                            • Trinidad & Tobago
                            Originally posted by reeceyburger123
                            lol plus 1 your own comment, also i agree replace mb. But he could try a new flash ic or reflowing it.
                            • Diah
                              • Feb 2013
                              • 6392
                              why do you have Oven at home ??
                              use it for this MB , low coast just little smell at backing 10 minute 220 degree
                              • ReeceyBurger123
                                Never Give Up !
                                • May 2014
                                • 7325
                                • Britain
                                Oven is for food not pcbs.
                                • StephenU
                                  • Dec 2013
                                  • 230
                                  • United Kingdom
                                  Thanks to all for there input and help, managed to pick up a new MB and problem solved.
                                  • ReeceyBurger123
                                    Never Give Up !
                                    • May 2014
                                    • 7325
                                    • Britain
                                    Awesome, also turn the backlight down and add a heatsink to that cpu !
                                    • StephenU
                                      • Dec 2013
                                      • 230
                                      • United Kingdom
                                      Done, thanks again.
                                      • ReeceyBurger123
                                        Never Give Up !
                                        • May 2014
                                        • 7325
                                        • Britain
                                        Awesome work
                                        • Michael Long
                                          No Standby Light on Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          by Michael Long
                                          I had a Dead Samsung UN65MU6300FXZA with Mainboard BN94-12440E
                                          Dead / No Power / No Standby Light results after power company had three
                                          consecutive power outages on/off/on/off/on/off after which TV was rendered unresponsive.
                                          After exploring the issue found Mainboard was the fault. Then with research on this site determined IC1604 was the suspect. The IC1604 is a surface mounted device (SMD) EEPROM, Winbond Model 25Q40CLSIP. A read on this EEPROM came back with all FF FF FF FF FF in all registers blank and empty of data. I had a spare mainboard with intact IC1604 and utilized...
                                          09-13-2022, 06:55 AM
                                        • ChristianBr01
                                          LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
                                          by ChristianBr01
                                          I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
                                          The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
                                          What I already found is that the 12.8V are not an the connector to the main board connector to the power...
                                          04-23-2025, 01:48 AM
                                        • stylishconsultant
                                          un60j620dafxza - Samsung No Display Problem
                                          by stylishconsultant
                                          Hi All,
                                          Need help.
                                          I have a samsung un60j620dafxza led tv. When I plug it in it has no display, no sounds, and no standby lights.
                                          So I opened the tv and disconnected the power to the mainboard and the backlight powered up. This according to many people says that this is a mainboard
                                          problem. I checked the voltage coming from the stb and I read 1.3 volts on pins 1,3,5 and 7 which are low volts instead of 13 volts which i think the lcd panel
                                          might be drawing too much power from the power supply that it prevents the right voltage going to the mainboard....
                                          09-04-2024, 03:26 AM
                                        • AleMonti
                                          LG 55EG910V - no power and no standby light
                                          by AleMonti
                                          I'm trying to troubleshoot and repair this old LG OLED curved TV, model 55EG910V.
                                          I did some basic troubleshooting and reviewed most related posts here, but I wasn't able to isolate the issue.
                                          The TV shut itself off during playback and never came back to life - the standby light remains off. My dad claims that it has happened a few times in the past but the issue resolved itself after some time. Not this one.
                                          After checking the basics I did the following:
                                          • I measured all voltages and as expected the only active supply is the 3.5V standby. It
                                          11-04-2024, 05:02 PM
                                        • Kaar3l
                                          Samsung QLED QE65Q7FNAT only standby light
                                          by Kaar3l
                                          TV: Samsung QLED QE65Q7FNAT
                                          PSU: BN4400940A
                                          MB: BN94-12832K
                                          I got the tv in spring 2024. At that time it started, then ran 60 sec and poweroff. Seemed like reboot issue. I didn't have time and room to check it in summer so I plugged it in and now the standby light is on. I press button on remote, standby light goes off and tries to start?. No picture or backlight on LCD. I thought about removing diodes like in this thread: https://www.badcaps.net/forum/troubl...sung-qled-q60r...
                                          09-24-2024, 01:35 PM
