Mechanic from Norfolk trying to keep his old tv alive
I've lurked around for a while and read up so much my head hurts and now I have a couple of questions.
Symptoms:
Tv starts and shows logo. Sometimes the backlights will stay on for around 10 seconds but mostly around 2-3 seconds.
I've done the flashlight test and can see the screen and menus etc.
What I've done so far...
With a flashlight I've gone through the menus and reset to factory settings. No fix.
Stripped the set and looked for a bad led. All work fine and there's nothing obviously wrong. Reading up on here a tech doe say this set won't shut down for one bad led anyway.
The psu is looking suspect after the above tests as this has the led driver built in. Well on top anyway.
Now these are £70+ and getting old so I read up many threads and seen there's a common issue with the LED ic chip.
Can you get these? Probably not. I did reflow the solder on the chip legs using an air solder station. No fix.
Now there's a thread on here that I will edit a link to shortly - https://www.badcaps.net/forum/showthread.php?t=44340 that states the driver board can be removed? With some work the leds can be driven direct at a lower voltage. Can anyone give me some guidance on this including pictures if possible?
Another member states the fitting of a 10k resistor fitted to pin 16 then to ground fixes this issue? Again guidance would be much appreciated.
I'm not an electronics tech expert. I'm a mechanic but I can solder, follow tracks and figure out the basics fairly readily.
I've repaired PS4 HDMI ic problems before etc.
Please can someone who knows the know help me out?
Symptoms:
