LG 42LW4500-LB Need help with repair of PSU
http://www.badcaps.net/forum/showthread.php?t=24809 -
Re: LG 42LW4500-LB Need help with repair of PSU
So you telling me i need to coonect the man
Inboard and everything else and try to pit on 230vac try to set on tv and after thst i need to look for bad part ? I will try to remove the surge protection and i will check the board under voltage again if the voltage will go after because now i have voltage only on main gray filter cap i will replace the surge protection with cable for testComment
I need service manual for board scheme :/Comment
The mainboard is a common fault. Just saying its a possibility. All you need is to to heat up the large heatsink with a hair-dryer on highest heat for 2 minutes and turn on. Let me know if it doesnt work, then we can move on to psuComment
So far I asked you to provide simple DCV reading of the PWR-ON pin on post 26 but insisting on replacing the MOV. WHY? THE DAM THING IS NOT BAD! GET IT!
I WASTED MY TIME ON THIS THREAD WHEN YOU CANNOT EVEN FOLLOW THE INSTRUCTION!Never stop learning
Someone needs a chill pillComment
Well what do you think?
Post 39: "Where I can found the power switch ? It will be good if you have some scheme for this board ."
Post 42 "I will try to remove the surge protection" still try to deal with MOV after all the explanation?
We are over 40 posts now an still no answer on the PWR-ON signal pin. If there is no PWR-ON form main board then the Main board will have to be checked, but at this we do not know if we have that signal or not. May be after he finds the Power switch?Last edited by budm; 11-29-2016, 10:40 AM.Never stop learning
I just remove the surge protection and TV starts LCD shine i also hear click of rele so maybe i will try to do this with this surge protection again .. and chill man I know Iam dumbass maybe but i made progress and it starts shine before it do nothing just turn off imidietlyWell what do you think?
We are over 40 posts now an still no answer on the PWR-ON signal pin. If there is no PWR-ON form main board then the Main board will have to be checked, but at this we do not know if we have that signal or not. May be after he finds the Power switch?Comment
Well, you are not making any sense since as explained, the MOV is connected in parallel with the cap which you have measured 230VAC between the cap's legs, the MOV has nothing to do with the TV functioning, more likely you have disturbed bad connections or connectors that may not be seated properly or loose mounting screws holding the board to make the GND connection to the chassis, etc..Attached Filesif you find these attachements useful please consider making a small donation to the site
I really think this person is toying with our good intention....Sometimes not all threads are real.....I detect a mischief maker here.....Just can't follow a simple instruction...then go and do something that makes no sense and ...voila...it comes ON....Sheeeeesh....Anyway budm....you certainly have the virtue of patience....I would have given up a long time ago.....just reading this post makes my head ache......Thanks.Comment
Is this guy for real. No offence . Mate you have been given some very clear instructions and only measuring low voltage instead you are opting to measure the higher more dangerous voltages. Personally I think you would be better off putting the cover back on and take it to someone who knows at least where the power switch is and how to do basic troubleshooting. Just because the power supply is on one board does not mean it automatically runs all the time. It requires other voltages and signals from other boards to allow all the different, voltage rails to turn on. Bud M has given you excellent advice. Measure the PS on voltage between ground and the ps on pin of power supply. If you don't feel confident just hook up Jumper clips to ground and a component off the ps on pin. Put your metre on dc not ac. Do you have a picture of your metre? Willing to help more but not if there is a risk of endangering your life. Even your electrotechnical teacher (as you put it) would dissuade you from touching it , unless of course this is some kind of joke , then you are just wasting people's time.Comment
by dj8452000I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
by nmbbMachine: Autoclave.
Brand/Model: SANYO MLS-3780
Manual: (Sorry search option not working on this PDF)
Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number... -
by Use2bavolvoI am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting... -
by trex66My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...3 Photos
by Sofian75I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
I fixed some of them and some I ve made things worse by blowing components.
Every time while taking measurements with my multimeter.
Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
So my question is are there things I should not do with my multimeter?
Or measurements I should do only with the charger and battery unplugged?... - Loading...
