LG 42LW4500-LB Need help with repair of PSU
    Re: LG 42LW4500-LB Need help with repair of PSU
    BTW, I cannot read the PCBA P/N as printed on the barcode sticker to look for more info about the board.
      Are these P/N printed on your board?
      Is this the EXACT matched of your board?
      LG EAY62169801 (EAX62865401/8)
      Pictures provided by shopjimmy.
      • UndeadLuke
        • Nov 2016
        • 25
        • Czech Republic
        Yes
        • UndeadLuke
          • Nov 2016
          • 25
          • Czech Republic
          Yes
          • UndeadLuke
            • Nov 2016
            • 25
            • Czech Republic
            The black thing right to geay capacitor on main is what because it got damaged and no fuse after this part
              OK, so far you do have standby Voltage otherwise based on Post #1 "Hi guys today my TV stops working (it woudnt turn on only led shine so the power goes into it)"
              Looking the board layout, you will not have any DCV between the two legs on any of the filter caps C612~C614 until you have > 2VDC at the 'PWR-ON' pin of the connector P201 to turn on the power relay RL101 to supply the 230VAC to the bridge rectifier BD101.
              So check and see if you have DCV at 'PWR-ON' pin or not when the power switch is activated.
                That is MOV VA101 and it does not look like it is damaged, if it has been activated it would have blown the main AC fuse.
                NTC TH501 is for the inrush current limiter for the STANDBY power supply section.
                NTC TH101 is for the inrush current limiter for the MAIN power supply section.
                • syaoran123
                  • Jun 2014
                  • 178
                  How do you know the power supply is faulty? I would test the fuses first to see if theyre ok.
                  • UndeadLuke
                    • Nov 2016
                    • 25
                    • Czech Republic
                    #29
                    Its faulty .. I checked all fuses and they are OK .. all of them
                    • UndeadLuke
                      • Nov 2016
                      • 25
                      • Czech Republic
                      #30
                      All fuses are Okey main AC fuse is before this little b*tch I want to know what is it and what i can replace it iam agry of it as I sed I had no voltage after the part I will mark it on anotherpost I cant get no voltage on the relay so relay cant switch the voltage to diodes when you press power button it will imidietly turn off TV so i cant turn it on i think the marked part is definetly bad please tell me what it is and what can i replace with it :/
                      • UndeadLuke
                        • Nov 2016
                        • 25
                        • Czech Republic
                        #31
                        the red marked one
                          I do not understand which part is bad TH501, TH101?
                            the red marked one
                            That is MOV and it is NOT BAD, if it is activated the main fuse would have blown, it is for surge protection and it is not needed for the TV to function.
                            You should be able to read 230VAC between the two legs of that MOV because it is basically connected in parallel with that grey line filter cap which are connected between Line and Neutral.
                            You are looking at the wrong section.
                            There is NOTHING WRONG with that MOV!
                            http://www.mouser.com/ProductDetail/...IfAz8bpg%3D%3D
                              Read post 26 again and report the reading.
                              • syaoran123
                                • Jun 2014
                                • 178
                                I am not convinced unless you support your claim. Do you even know how to test a fuse? Have you tried heating the mainboard with a hair-dryer?
                                  The main board has to send the PWR-ON to turn on the relay, no command signal = no relay action.
                                  You have to follow the instruction.
                                  • UndeadLuke
                                    • Nov 2016
                                    • 25
                                    • Czech Republic
                                    #37
                                    I know how test fuse .. if beeps its good ... i tryed it and all of them are Ok heating ? man this is not bad chip
                                    • UndeadLuke
                                      • Nov 2016
                                      • 25
                                      • Czech Republic
                                      #38
                                      I really dont understand you opinions because why I dont have no power on main power circuit ? I think the relay turns on when I press power button but i dont have any power on my primary circuit market like 1 on board. also no power after this red market part so firt gray cap is with power but the second one is without because it looks like the part got damaged like when you damaged fuse . its surge protection i know but when surge protection fails like fuse and got damaged you will have no power after it ? Isnt that true ? and yes I will follow the instructions .
                                      • UndeadLuke
                                        • Nov 2016
                                        • 25
                                        • Czech Republic
                                        #39
                                        Where I can found the power switch ? It will be good if you have some scheme for this board .
                                          The MOV is connected across the power line after the fuse, it will heavily conduct and causes the main AC fuse to blow, like I said it is not need to for the TV to function! You can even remove it! you just will not have surge protection. It is not connected in SERIES like a fuse, it is connected in parallel with incoming AC.
                                          Look up and learn what the MOV is for and how it is used then you will understand.
                                          You think the relay is turned on, how did you figure that out? it has DCV on the relay coil when the power switch is activated and the Voltage is there and did not drop out.
                                          Did you even verify that you do have DCV at the PWR-ON pin as I asked.
                                          It sounds like you are skipping in learning the basic as to how the component functions.
                                          • dj8452000
                                            How To Test a P-channel Trench Mosfet Using A Multimeter In Diode Mode
                                            by dj8452000
                                            I am new to electronics and I'm understanding most of what I'm reading but I have a mosfet on my board that I've identified as a P-channel Trench Mosfet. I haven't a clue how to test this and what I should expect to see with the multimeter probes. I am hoping someone with years more experience than myself can help me understand how to use a multimeter to read this. Please look at the drawing I have attached to this and can you try to explain to me what I should be doing with my multimeter in diode mode and what results I should expect from a good mosfet?...
                                            02-18-2025, 08:28 AM
                                          • nmbb
                                            Can not find Model/Value of Thermistor.
                                            by nmbb
                                            Machine: Autoclave.
                                            Brand/Model: SANYO MLS-3780
                                            Manual: (Sorry search option not working on this PDF)
                                            Hello guys, this autoclave running with 2 thermistors already connected TH1 and TH3(on CN1,CN2 sockets). One for the water temperture and second one for chamber temperature. But there is another emtpy socket for optional third thermistor CN2 wich is for TH2 for object temperature. I wanna add the third thermistor TH2 to CN2 socket. But i can't figure what model/brand/value i need to use. In manual document, there is no info about TH1 and TH3 model number...
                                            06-02-2022, 05:55 PM
                                          • Use2bavolvo
                                            Magic chef oven - thermistor ref voltage issue
                                            by Use2bavolvo
                                            I am having an issue with my wall oven temperature control is ~180f out of spec. The thermistor is measuring correctly but I noticed the ref voltage appears to be off. With the thermistor wires attached it's reading ~3.4vdc with the thermistor disconnected it's around I9.8vdc. my understanding is the temp is read off the resistance from the thermistor which leads me to believe the issue is with the ref voltage.
                                            Another observation is the temp setting and readout at lower temps is way off meaning the oven thinks room temp is 300f and bake relay doesn't engage unless temp setting...
                                            01-19-2023, 01:32 AM
                                          • trex66
                                            Craftsman 82345 Multimeter broke!
                                            by trex66
                                            My daily carry just stopped working only me. Started last week with the voltage flickering. Found one lead was broken and I ordered new ones. New leads didn't change anything, it displays “-1” on all settings but on continuity will give the tone when touching. Checked battery and found the fuse blown. Replaced fuse but same results. Cleaned the dial and led display and its parts. Board looks nice and clean no burned or broken components. Nothing traumatic happened to this multimeter I put it aside when I found the lead broken and didn't touch it until I got the neAnyone have any ideas what's...
                                            03-04-2025, 04:26 PM
                                          • Sofian75
                                            Things not to do with a multimeter?
                                            by Sofian75
                                            I started to learn laptop repair a few weeks ago, since then I ve ordered several dead laptops to try to fix them and learn.
                                            I fixed some of them and some I ve made things worse by blowing components.
                                            Every time while taking measurements with my multimeter.
                                            Yesterday I was working on a dell laptop motherboard, I was checking the charge IC for short in diode mode and it killed the chip.
                                            So my question is are there things I should not do with my multimeter?
                                            Or measurements I should do only with the charger and battery unplugged?...
                                            06-27-2024, 05:13 AM
