Crown CCT3207W(Vestel 17MB08P-5 chasis) stuck in standby
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    #41
    Re: Crown CCT3207W(Vestel 17MB08P-5 chasis) stuck in standby
    Originally posted by dick_barton
    Looking at the position of the holes both diodes in that package are required to be working. I've tried to draw it on your photo. It need to be replaced.
    Ok, today I will try to buy another Shottky with minimum 2x5A/60V. Seriously, this vestel bastards are absolute idiots. Using doble shottky without balancing means that the load on the one of the skottky will be higher than on the other. This is design, prone to faults.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • televizora
      ghettomodmaster
      • Nov 2016
      • 957
      #42
      OK, I bought MBR20100CT, so practically I doubled the rating of the previous Shottky. MBR20100CT is 20A(10A per leg), when the original Shottky is rated 10A(5A per leg). When the volgate of the original shottky is 60V, I am planning to replace it with shottky with 100V rating.
      Is this good enough?
      • dick_barton
        • Aug 2015
        • 6643
        • Wales
        #43
        If it's higher rated then that should be fine but make sure the pin out is the same as in post #32
        Looking at the specifications for the MBR20100CT you need an insulation mounting kit and some silicone grease or equivalent to mount it without it shorting to the heatsink.
        • televizora
          ghettomodmaster
          • Nov 2016
          • 957
          #44
          Yes, I bought insulation mounting kits. Two kinds of em. One of the pads is silicone rubber, the other is mica. Which is better?
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            #45
            I've used both types. What is important is that after you mount the diode you check with your ohm meter that there is no connection between the middle leg to the heatsink.
            • televizora
              ghettomodmaster
              • Nov 2016
              • 957
              #46
              Maybe I found out the reason for the short circuit in the shottky. The thermal grease between the radiator and the shottky, and the transistors and the radiator has dried up. The only thing left is a white residue, which looks like a dust.
              • televizora
                ghettomodmaster
                • Nov 2016
                • 957
                #47
                So, the TV is now in working condition. The problem was indeed the shottky diode.
                Before registering here, I googled all the problems with this power supplies and none of the results mentioned anything about the problem with the Shottky diode on the secondary of the main transformer.
                You have a BIG thank you! from me. Indeed, you helped me so much in the resolving of this issue.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #48
                  Glad to see you have it working again.
                  • ReeceyBurger123
                    Never Give Up !
                    • May 2014
                    • 7325
                    • Britain
                    #49
                    Good work both you.
                    • televizora
                      ghettomodmaster
                      • Nov 2016
                      • 957
                      #50
                      I'm requesting an action from a moderator. Please, change the title of the topic - add the following text "Solved - Q829"
                      Unfortunately, I can't do it myself, because I cannot edit the first(mine) post in the topic.
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #51
                        Anyone reading through this thread will see your answer to the repair so you don't need to alter the title.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          #52
                          Message Topcat hes on spot and will sort it.
                            master hoarder
                            • May 2008
                            • 12175
                            #53
                            Nice, great to hear you got the TV working again.
                            Vestel TV sets are know around here (on BCN) for blown/burned/shorted output rectifiers (sometimes not even schottkys but regular fast-recovery diodes!).
                            The one mistake they most often do is install regular diodes in parallel, expecting the current handling capability to increase. But without any thermal coupling, one of the diodes will always run hotter than the other, causing a runaway, and eventually burning out.
                            So yeah, if you see a Vestel set with no power, maybe you can score yourself another TV for cheap and fix it.
                            • televizora
                              ghettomodmaster
                              • Nov 2016
                              • 957
                              #54
                              Originally posted by momaka
                              The one mistake they most often do is install regular diodes in parallel, expecting the current handling capability to increase. But without any thermal coupling, one of the diodes will always run hotter than the other, causing a runaway, and eventually burning out.)
                              I really don't understand why the hell they would install 2 regular diodes in parallel, instead of one with double current capacity.
                              The PSU I have yesterday repaired also has 2 diodes in parallel
                              Perhaps the make their TV's only to survive the warranty period. This is why they make such a stupid(and maybe deliberate) mistakes.
                              The usual practice for me is to replace faulty components with a components with higher ratings - current&voltage, but not capacitance, because this may lead to unexpected consequences, because the design of some signal circuits may count on certain capacitance and ESR to function properly.
                              p.s I really hope that my english is not so terrific and is understandable
                              • dick_barton
                                • Aug 2015
                                • 6643
                                • Wales
                                #55
                                If they use two individual diodes then do what ReeceyBurger123 says and thermally glue them together so they run at the same temperature.
                                • televizora
                                  ghettomodmaster
                                  • Nov 2016
                                  • 957
                                  #56
                                  If something happens, I will replace both diodes with one double Shottky on heatsink.
                                    master hoarder
                                    • May 2008
                                    • 12175
                                    #57
                                    Because... this is Vestel.
                                    The world economy has to keep going.
                                    How else would we have constant economic growth?
                                    Actually, increasing the capacitance on the output of a power supplies is usually okay in most cases. I've done it many times. Only one particular brand of computer power supply become unstable. Just don't change the value of small caps near chips, as those could be used for timing or certain filtering - those are the only caps I don't experiment with new values.
                                    It is fine. I had no problems understanding you at all.
                                    That won't help much. The epoxy cases of diodes are not very good thermal conductors. You are better off soldering their leads very close together with thick copper wire.
                                    But even that still won't be the same as having two diodes manufactured on the same die together. That's why in PC power supplies, for example, even if there are two rectifiers in parallel and attached to the same heatsink (back to back), you still won't get twice the current rating. Typically 1.5 times the individual current rating is about as good as it gets.
                                    Exactly!
                                    That will be so much better. And you will get improved efficiency, so that means less heat inside the TV, and you capacitors will live longer.
                                    • lepak06
                                      TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                      by lepak06
                                      Hello
                                      I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                      The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                      Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                      All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                      But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                      01-12-2023, 01:43 AM
                                    • toty79
                                      Hisense LTDN50K220WSEU stuck in standby
                                      by toty79
                                      Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                      As per Hisense tv title LTDN50K220WSEU stuck in standby
                                      PSU rsag.820.5687 HLL 4855WF
                                      Main rsag 7.820.5842
                                      I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                      05-01-2022, 04:39 PM
                                    • lego1234567
                                      LG 32LB1R - stuck in standby mode
                                      by lego1234567
                                      Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                      What could be the problem ? Thanks...
                                      01-21-2024, 03:39 AM
                                    • Stunt
                                      Hp Laptop Stuck on Hp protected by hp sure start screen
                                      by Stunt
                                      Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                      I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                      I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                      Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                      screen that's it and stuck there. I left it until the following day and i still...
                                      09-02-2025, 01:51 PM
                                    • Rusenga
                                      Samsung UA39EH5003R Stuck on standby
                                      by Rusenga
                                      Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                      Connector CNM803:
                                      TV ON
                                      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                      TV OFF
                                      Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                      09-18-2021, 11:51 AM
