Crown CCT3207W(Vestel 17MB08P-5 chasis) stuck in standby
  • televizora
    ghettomodmaster
    • Nov 2016
    • 957
    • Bulgaria
    Re: Crown CCT3207W(Vestel 17MB08P-5 chasis) stuck in standby
    Originally posted by dick_barton
    What mosfet was that (Q??) and can you read the marking on the smd resistor.
    Q813 and Q814. The resistor between the two legs is 103 - 10K.
    Useful conversions. I don't "speak" imperial. Please use metric, if you want to address me.
    1km=1000m=100000cm, 1inch=2.54cm, 1mile=1609.344meters, 1ft=30.48cm 1gal(US)=3.785liters, 1lb=453grams, 1oz=28.34grams
    • dick_barton
      • Aug 2015
      • 6643
      • Wales
      So as shown in the circuit. The problem does not appear to be to do with the mosfets.
      I'm out of idea's but still believe that the voltage to IC807 is too low.
      Perhaps others on the Forum can offer some advice at this point.
      • televizora
        ghettomodmaster
        • Nov 2016
        • 957
        • Bulgaria
        Maybe I need a scope to check the signal on the IC807. Perhaps the IC that controls the MOSFETS has gone out of commission.
        Something is definitely wrong. Some backfeed prevents the PSU from starting then.
        It's abnormal not to have any voltages when the PSU is in ON state, except the StandBy.
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          Unless you have an isolation probe for your scope to check waveforms on the HOT (mains live) side of the power supply, you will damage both your scope, power supply and yourself.
          • televizora
            ghettomodmaster
            • Nov 2016
            • 957
            • Bulgaria
            Indeed, I need a isolation probe. But how else I could diagnose the problem?
            • dick_barton
              • Aug 2015
              • 6643
              • Wales
              #26
              You could at the moment with the power supply disconnected, use your multi-meter in diode mode and check all the diodes, transistors and mosfets to begin with.
              • televizora
                ghettomodmaster
                • Nov 2016
                • 957
                • Bulgaria
                #27
                I did this before posting here. No short circuits. The reason I registered here is to ask for help, because I can't find obvious signs of malfunction, except the fact that all the voltages, except the standby are missing.
                The only short I have is on the secondary side of the TR805, on Q829, which is normal, considering the fact that all the pins of the Q829 are somehow connected to the leads of the transformer itself. The inductors and transformers are simple wires for the direct current. When it comes to the direct current, the inductor characterizes itself only with it's ohmic resistance(active resistance)
                The whole story is that a working TV set suddenly stopped working - turned itself off, after this moment, the only thing that kept working is the red standby light on the front panel. There wasn't any kind of warning or sign that something goes wrong.
                • dick_barton
                  • Aug 2015
                  • 6643
                  • Wales
                  #28
                  Q829 may present a short between base and emitter but I would lift it out and check to be certain that it's OK.
                  • televizora
                    ghettomodmaster
                    • Nov 2016
                    • 957
                    • Bulgaria
                    #29
                    Q829 is stps10l60cfp which is Schottky rectifier.
                    • dick_barton
                      • Aug 2015
                      • 6643
                      • Wales
                      #30
                      Do you have a schematic that matches your board. Even if it's a diode you could lift it out and check it with your meter.
                      • televizora
                        ghettomodmaster
                        • Nov 2016
                        • 957
                        • Bulgaria
                        #31
                        Yes. I did so. Seems like is 2 coupled Schottky diodes in one package. Also - seems like one of the diodes has short circuited. Two of the pins have 0 Ohms resistance between them in both directions. I really wasn't expecting short circuit on the secondary side of the transformer.
                        If you see the schematic, they use only one of the PN junctions of the transistor(effectively using it as a single DIODE if I am reading this properly). The third trace is not connected to the third pin of the transistor, there is a blank space in the trace to the collector of the Q829.
                        I can replace the Schottky with any regular Schottky in the same package, right?
                        I have STPS1545C in stock. It's rated 45V, the original is rated 60V. Is this gonna be a problem?
                        I also gonna need isolation pad, because the back side of the STPS1545C package is metal and is directly connected to the Cathode.
                        Is this a Schottky, as I think?
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          #32
                          I would not since the one you suggest is lower rated than the one that's already faulty. I would expect the STPS1545C to also fail. Which pins were shorted together?
                          They are available from mouser.com
                          • televizora
                            ghettomodmaster
                            • Nov 2016
                            • 957
                            • Bulgaria
                            #33
                            The left and the middle pin are shorted together(A1 and K).(when we look at the front side of the shottky).
                            First of all - IS this a shottky, as I think? Please, look at the photo I have uploaded.
                            The second one - I think that the problem is perhaps overheating. Because I dont see any voltage on the secondary, that could exceed 33V
                            The third - Am I correct in my conclusion about the transistor used as diode?
                            And the last of all..I will have to find this shottky in my local stores or TME. Mouser is too far away from me. So I will have to wait a very long time for the delivery.
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #34
                              The short circuit diode will stop the secondary voltages coming up.
                              The 33V is for the tuner and is low current and would not have caused the problem.
                              I would be patient and try and locate the correct part. Use Ebay and have it sent to you. It would be a pity to end up with more problems than you already have.
                              Parts do fail for a number of reasons. It could be heat, it could be a short circuit that caused it to fail, it may be operating at its maximum rating.
                              The STPS10L60CFP is a Schottky diode
                              • televizora
                                ghettomodmaster
                                • Nov 2016
                                • 957
                                • Bulgaria
                                #35
                                So, you confirm that the electronic component on the photo I uploaded is a double shottky diode? And as we saw, it shortcircuited on the side, which is used, not on the side, where the trace is not completed.
                                p.s Will any double shottky with rating of minimum 5Amps at 60V will suffice?
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  #36
                                  Yes, it is a double Schottky diode as show in the image post #32
                                  If the middle and left pin are in use then it is faulty because you have a short circuit.
                                  Are you certain the right pin is not connected to anything???? Can you post a picture of the underside where it is soldered into the board.
                                  • televizora
                                    ghettomodmaster
                                    • Nov 2016
                                    • 957
                                    • Bulgaria
                                    #37
                                    Yes, it is a double Scottky diode as show in the image post #32
                                    So I am correct that they used transistor as a diode? Why the hell this turkish brainiacs didn't just use simple diode?
                                    And - Will any shottky with the rating of minimum 60V@5A will suffice?
                                    p.s. Do you think that the side, which is in use can be in working condition, but unused side - fried?
                                    On the schematic - it is not connected to anything. On the board - both anodes are connected to the TR805!
                                    This is why on the schematic the cathode of the transistor is not connected! They have used both of the diodes, connecting them to the TR806!
                                    • dick_barton
                                      • Aug 2015
                                      • 6643
                                      • Wales
                                      #38
                                      If you post a picture of the underside of the board and mark the diode solder connections then that would help.
                                      It needs to be a clear and sharp picture. I do not know the answer because I cannot tell without the board in front of me or at least a good picture of the board.
                                      • televizora
                                        ghettomodmaster
                                        • Nov 2016
                                        • 957
                                        • Bulgaria
                                        #39
                                        If you post a picture of the underside of the board and mark the diode solder connections then that would help. .
                                        Okay! Here we go. This is as good as I can get. Just my phone sucks, when it comes to taking photos on artificial light.
                                        p.s better try with the second picture - 71.
                                        • dick_barton
                                          • Aug 2015
                                          • 6643
                                          • Wales
                                          #40
                                          Looking at the position of the holes both diodes in that package are required to be working. I've tried to draw it on your photo. It need to be replaced.
                                          • lepak06
                                            TV LED 4K Selecline 65S18 ( T.MS3458.U801) stuck in Standby mode
                                            by lepak06
                                            Hello
                                            I have an TV Led 4K Selecline 65s18 with mainboard T.MS3458.U801
                                            The TV is faulty with stuck in Standby RED LED. Can't power the TV.
                                            Before this problem , the TV stuck the picture with artefact , i unplug the AC cable and since the tv is stuck in standby .
                                            All voltage are OK on PSU and main board for regulator. I tried flash firmware 25Q64 with many dumps
                                            But the voltage on power button is 0.6V not 3.3V. When i press power button the voltage up to 0V. I tried to add 5V with Power Supply on 5V_STB and 3.3V on Power...
                                            01-12-2023, 01:43 AM
                                          • toty79
                                            Hisense LTDN50K220WSEU stuck in standby
                                            by toty79
                                            Hello to all friends of the forum and well found, here I am asking for your help and sorry for my translated English.
                                            As per Hisense tv title LTDN50K220WSEU stuck in standby
                                            PSU rsag.820.5687 HLL 4855WF
                                            Main rsag 7.820.5842
                                            I enclose the psu diagram, after the first routine checks I find myself with a regular standby voltage of 3.3v blue light on steady when the power button is pressed nothing happens, psu disassembled and bench checked ... forced ignition by sending a signal 3 , 3v on the SW and PWM2 pins the psu turns on and delivers all the voltages...
                                            05-01-2022, 04:39 PM
                                          • lego1234567
                                            LG 32LB1R - stuck in standby mode
                                            by lego1234567
                                            Hi. I have the following problem with my TV. After connecting to mains, the standby led (red) turns on, but TV is not responding to remote control or buttons on TV. After some measurements, I found out that +5 V standby voltage is present, but I dont have ON/OFF signal coming in to turn PSU on. It stays at zero volts. After looking at the schematic of the mainboard, I should get ON/OFF signal coming in at the R1402 resistor, but it stays around +3,5 V. So I removed it and I was able to turn on TV with buttons on TV, but not with remote control.
                                            What could be the problem ? Thanks...
                                            01-21-2024, 03:39 AM
                                          • Stunt
                                            Hp Laptop Stuck on Hp protected by hp sure start screen
                                            by Stunt
                                            Hi guys i've got an Hp laptop Zbook 17 g5 Stuck on Hp protected by hp sure start screen.
                                            I have tried almost every bios available on various platforms about this laptop but the problem is still the same.
                                            I even successfully build my own bios using the one from the Hp website but the problem the laptop still getting stuck there.
                                            Even if i try to press Esc key nothing happens. I tried f10 it doesn't go to bios still stuck there i just saw entering setup menu on the bottom left corner of the
                                            screen that's it and stuck there. I left it until the following day and i still...
                                            09-02-2025, 01:51 PM
                                          • Rusenga
                                            Samsung UA39EH5003R Stuck on standby
                                            by Rusenga
                                            Hi techs, I have a Samsung ua39eh5003r which switches on and then goes to standby. I have to wait for a day or two for the tv to switch on again, all the time it is stuck on standby. I have checked the voltages on the power supply board on both occasions when it is on and off and these are my findings:
                                            Connector CNM803:
                                            TV ON
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.96v; Pin6(BLU_ON/OFF)- 4.41v; Pin8,9,10- grnd; Pin11,12,13- 5.16v; Pin14(Power ON/OFF)- 3.3v
                                            TV OFF
                                            Pin1,3,4,5(Vamp),7(Vamp)- 12.6V; Pin2(PWM_DIM)- 0.06v; Pin6(BLU_ON/OFF)-...
                                            09-18-2021, 11:51 AM
