T420xw01 v5 t-con, help!
  • finntricky
    • Jan 2014
    • 449
    Hi guys, i have this t-con board from an old TECKNIKA LCD42 - 207.
    as you can see i have a voltage reg that has melted, and cant see any markings on it to give me an idea as to what it is, postion Q303
    so my question is, does anyone know what it is, or any ideas, the tv is working with back lights, but no pic,
    thanks guys.
  • finntricky
    • Jan 2014
    • 449
    Re: T420xw01 v5 t-con, help!
    trying these again
      I do not know what the P/N is but it is not IC but Q = Transistor or MOSFET.
      • finntricky
        • Jan 2014
        • 449
        yes, you are correct, silly me, this is the first time i have seen anything melt on a T-CON,
        first thought was a fuse that was the problem, but no, its this Q303.
        ive search google for pics, in the hope i could blow it up big enough to see some markings, but no joy as yet
        • Alastair E
          Chief Womble
          • Mar 2013
          • 1963
          • U.K.
          Easier to just replace the thing complete...
          TELEFIX
          • ReeceyBurger123
            Never Give Up !
            • May 2014
            • 7325
            • Britain
            +1 Dont forget to recap the Psu at the same time lol if not the set will be returned in a few months.
            • finntricky
              • Jan 2014
              • 449
              already sorted the PSU to get the tv going in the first place, so this t-con is a second problem, does a telly this old warrent spending £22 for a T-CON, i don't think so, and the customer ain't gonna like the bill,
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                What's the full part numbers on the TCON
                • dick_barton
                  • Aug 2015
                  • 6642
                  • Wales
                  I use this site whenever possible because the prices are good but delivery is generally a week or so from placing your order.
                  They have one for £12.99 + postage
                  http://cheapspares15.mysimplestore.c...-control-board
                  • finntricky
                    • Jan 2014
                    • 449
                    thanks dick, just ordered it, works out £5 cheaper than ebay,
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      Glad to help.
                      • finntricky
                        • Jan 2014
                        • 449
                        Quick update, got the T-CON today and fitted, thats the good news,
                        now the bad news, on turning the tv to see the result, poof a puff of smoke and burning smell from main board, but cant find anything burnt, well its now going in the scrap, its just not worth spending money on something this old.
                        THAT'S THE END OF THIS PROBLEM.
                        • x_orange90_x
                          TCL 50S535 bad tcon or panel issue?
                          by x_orange90_x
                          Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                          03-29-2025, 11:02 PM
                        • advant
                          by advant
                          02-03-2020, 12:25 AM
                        • Hakuu
                          by Hakuu
                          Hi There,
                          More Details
                          TV Model - LG OLED77G1PUA
                          07-12-2023, 02:37 PM
                        • Daren87
                          Sony 8K XBR-75Z8H White Screen Vertical Bars Tcon Code. Help Needed🙏
                          by Daren87
                          I've recently been given a Sony 8k Z8H. It's got a white screen with two vertical black bars. At times it's given me the 5 blink Tcon code. Testing voltage on the Tcon I can see some low or missing voltage. I've done a basic visual check of cables and the COF. Not seeing anything obvious. The original Tcon seemed to have good caps until turning it over. On the bottom I found maybe 10 caps with both sides of the caps shorting to ground. I thought ok these caps and likely other components on the Tcon are shorted so let's try a replacement Tcon. I just received the...
                          08-13-2023, 03:25 PM
                        • alltvrepairs
                          Lg TCon test pins for screen test
                          by alltvrepairs
                          i have a 65 Panasonic TX-65HX710E using vestel 17MB170 main and Lg tcon.
                          Few drops of water fell probably near COF and have no display. Tried removing tabs but no.part of display present as if tcon fuse open. However 12v is present and tcon can be felt warm enough that supplies are present. Backlight and sound ok.
                          Anyone knows if this TCon 6870c-0805A has any special test pins for rgb test?
                          Appreciate your help....
                          06-13-2025, 06:33 AM
