Lg 50pk790
  • sordids999
    • May 2013
    • 2161
    • uk
    Re: Lg 50pk790
    Posting pictures of the back of your tv showing the boards with clear pictures may help you more with fixing your problem
    • Hamie
      • Apr 2014
      • 1383
      Re: Lg 50pk790
      Did you get test patterns or not?
      • Missy
        • Nov 2016
        • 14
        Re: Lg 50pk790
        No test patterbs
        • Packard93
          • Jul 2016
          • 81
          Re: Lg 50pk790
          when you say lights u are u refering to the screen?
          • Packard93
            • Jul 2016
            • 81
            Re: Lg 50pk790
            I believe you need a new power supply cause if u see a screen briefly upon turn tv on then your inverter is working
            • Packard93
              • Jul 2016
              • 81
              Re: Lg 50pk790
              did tv work perfectly before this happen . Was pic clear before this event.
              • Packard93
                • Jul 2016
                • 81
                Re: Lg 50pk790
                Hey. It may sound funny but try resetting your TV by turning it off,unplugging it, and holding the on/off button on the tv itself WHILE the tv is still unplugged for thirty seconds.
                • Hamie
                  • Apr 2014
                  • 1383
                  Re: Lg 50pk790
                  This is a plasma
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    #29
                    Re: Lg 50pk790
                    +1.....Post #21
                    • Missy
                      • Nov 2016
                      • 14
                      #30
                      Re: Lg 50pk790
                      Picture was perfect before. I literally turned it on one morning and there was no picture and the sound was what I can only describe as satanic (lol) for a few seconds then nothing. No picture or sound. I cannot find a psu anywhere, they all seem to be out of stock. I take it LG's are rubbish lol
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        #31
                        Re: Lg 50pk790
                        Is there a label on the rear screen panel giving the voltages and have you measured those voltages?
                        • sordids999
                          • May 2013
                          • 2161
                          • uk
                          #32
                          Re: Lg 50pk790
                          Originally posted by Missy
                          Ok changed the little main board but the problem still persists. Please help as I can do without buying a new tv just before Xmas.
                          Are we talking psu board fault?
                          Did you do what hamie said on the test patterns ?
                          because i noticed on your posts he advised you how to test but you replied you tried another main board ?
                          • ReeceyBurger123
                            Never Give Up !
                            • May 2014
                            • 7325
                            • Britain
                            #33
                            Re: Lg 50pk790
                            +1 just not listening throwing parts at it, ugh.
                            • GRANDGG
                              LG 42lw4500 flashing red light , wight light , 2 clicks
                              by GRANDGG
                              Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                              05-09-2025, 12:27 PM
                            • davidk35
                              Lenovo ThinkBook 15 G2 ITL, some little signs of life
                              by davidk35
                              So i got above mentioned laptop. Which shows only some little signs of life.
                              When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                              What ive already done:
                              -Flashed both bios chips 16 and 8 mb.
                              -Tried adding another stick of ram
                              -Check if backlight is faulty.
                              So any ideas?
                              Thank you
                              09-03-2025, 06:34 AM
                            • KYBOSH
                              Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                              by KYBOSH
                              I picked this one up today.
                              Previous owner says no signs of life.
                              TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                              Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                              The TV model is QN65LS03BAFXZA - version: CB06
                              The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                              I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                              Will keep you all...
                              04-05-2025, 08:32 PM
                            • Hondaman
                              Firefox is now SATANIC
                              by Hondaman
                              Now that I have your attention:
                              In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                              I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                              I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                              03-05-2025, 04:41 PM
                            • Noah Glasse
                              LG 50PK590 - three clicks and steady red light, won't turn on.
                              by Noah Glasse
                              I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                              I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                              02-24-2025, 07:23 AM
