Lg 50pk790
  • Missy
    • Nov 2016
    • 14
    Lg 50pk790
    My tv (model in thread title) has all of a sudden lost picture and sound. I'm quite compitant fixing pcb's etc as I worked in electronics but I have no testing equipment 😔😔. There are no sign signs of blown caps or resistors etc.
    It was fine last night, there she been no signs of anything suspicious building up problems. It literally turned on and there's was no picture, the sound could only Be described as satanic talking (lol) for a few seconds then nothing.
    I can turn the tv on and the standby light goes from red to blue, it goes bright like it's going to the logo but nothing. It goes dark and it clicks back to red, I hear the clicks when it goes on and off.
    Is it the psu or the main board? I've repaired lots of Samsung LCD's but never a plasma.
    Thanks in advance
    Sarah x
  • Hamie
    • Apr 2014
    • 1383
    Re: Lg 50pk790
    So to clarify, the screen lights up for a second then goes back to standby?
    • Missy
      • Nov 2016
      • 14
      Re: Lg 50pk790
      It lights up brighter, like it's turning on then it goes dark again but the tv is still on. I then press the standby button and it clicks ok like its going off.
      • Hamie
        • Apr 2014
        • 1383
        Re: Lg 50pk790
        Probably mainboard.
        You can run test patterns on this model with mainboard disconnected.
        On the control board look for 2 holes marked ext_auto_gen. Alternatively 2 holes beside r51 and r52.
        Connect the 2 holes with a piece of wire (paperclip etc)
        Finally disconnect the LVDS cable.
        Turn on the tv.
        • Missy
          • Nov 2016
          • 14
          Re: Lg 50pk790
          What would I be looking for?
          • Hamie
            • Apr 2014
            • 1383
            Re: Lg 50pk790
            If you correctly have the jumperwire in place you should have clear test patterns on screen.
            • Missy
              • Nov 2016
              • 14
              Re: Lg 50pk790
              And if that's there then what's it likely to be? If it's not there then what's the problem?
              • Hamie
                • Apr 2014
                • 1383
                Re: Lg 50pk790
                If you have test patterns you have a faulty mainboard.
                If not you have a fault somewhere else.
                • Missy
                  • Nov 2016
                  • 14
                  Re: Lg 50pk790
                  Ok thank you.
                  • Missy
                    • Nov 2016
                    • 14
                    Re: Lg 50pk790
                    Ok changed the little main board but the problem still persists. Please help as I can do without buying a new tv just before Xmas.
                    Are we talking psu board fault?
                    • Missy
                      • Nov 2016
                      • 14
                      Re: Lg 50pk790
                      Ok think someone on another site told me the wrong boards. I was told to replace main board and he showed me the little one with the square surface mounted chip. But now I'm thinking he meant the one with the hdmi ports on yes???
                      • Packard93
                        • Jul 2016
                        • 81
                        Re: Lg 50pk790
                        hmm It could be inverter or power supply.
                        • Packard93
                          • Jul 2016
                          • 81
                          Re: Lg 50pk790
                          really should get a cheap multimeter
                          • Packard93
                            • Jul 2016
                            • 81
                            Re: Lg 50pk790
                            Give me a description of everything that happens as you turn on the set
                            • Missy
                              • Nov 2016
                              • 14
                              Re: Lg 50pk790
                              I'm thinking psu, that was my gut instinct but he said replace that.
                              • Packard93
                                • Jul 2016
                                • 81
                                Re: Lg 50pk790
                                yes the mainboard is hdmi port .
                                • Missy
                                  • Nov 2016
                                  • 14
                                  Re: Lg 50pk790
                                  OMG! Lol thank you x
                                  • Packard93
                                    • Jul 2016
                                    • 81
                                    Re: Lg 50pk790
                                    Search bing for your model and look under video Look for video that has your issue to resolve your problem. Lots info other there fo fix this tv. I guarantee you can fix it .
                                    • Missy
                                      • Nov 2016
                                      • 14
                                      Re: Lg 50pk790
                                      Ok I turn it on either by the tv button or the remote and it turns on, clicks as normal and lights up like it's going to go to the logo page But then goes black. The standby button lights up blue as if on and fades in and and out then goes black. If I turn it off it does go red to standby.
                                      • Missy
                                        • Nov 2016
                                        • 14
                                        Re: Lg 50pk790
                                        I have googled before here and it's either sound not working or picture not both.
                                        • GRANDGG
                                          LG 42lw4500 flashing red light , wight light , 2 clicks
                                          by GRANDGG
                                          Hi i have an issue with LG 42lw4500 wich after pressing the power button flashes red then goes solid white light 2 clicks and nothing , the weird thing is SOMETIMES if i leave the tv plugged in it would come on and fuction normally (i should mention that vertical rectangle going from the bottom to the top of the screen have some red dot artafacts it only appear in somthing like the tv input menu and any input i give like vga , but not in the system menu , i thought i should mention this , i cannot confirme if the tv had this issue when it was up and running in its previous owner . ) when checking...
                                          05-09-2025, 12:27 PM
                                        • davidk35
                                          Lenovo ThinkBook 15 G2 ITL, some little signs of life
                                          by davidk35
                                          So i got above mentioned laptop. Which shows only some little signs of life.
                                          When i turn it on, 3 buttons lit up and stays like that forever (ESC, Caps Lock and Num Lock), they dont blink, they are just lit all the time. Fan does not spin, and there isnt any heat from CPU.
                                          What ive already done:
                                          -Flashed both bios chips 16 and 8 mb.
                                          -Tried adding another stick of ram
                                          -Check if backlight is faulty.
                                          So any ideas?
                                          Thank you
                                          09-03-2025, 06:34 AM
                                        • KYBOSH
                                          Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                          by KYBOSH
                                          I picked this one up today.
                                          Previous owner says no signs of life.
                                          TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                          Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                          The TV model is QN65LS03BAFXZA - version: CB06
                                          The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                          I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                          Will keep you all...
                                          04-05-2025, 08:32 PM
                                        • Hondaman
                                          Firefox is now SATANIC
                                          by Hondaman
                                          Now that I have your attention:
                                          In the last few days, it looks like Firefox has changed their software terms so they are now evil and WILL sell your data.
                                          I already use Palemoon for Win7 sometimes. Looks like I'll be switching to librewolf as well, as Youtuber Louis Rossman suggests. Palemoon still supports Win7, but sometimes pages don't work properly. The Google Chrome browser might also still work for Win7.
                                          I will have no choice but to upgrade my Firefox, so that I can copy dozens of tabs into a document or spreadsheet, or go through the history to...
                                          03-05-2025, 04:41 PM
                                        • Noah Glasse
                                          LG 50PK590 - three clicks and steady red light, won't turn on.
                                          by Noah Glasse
                                          I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                          I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                          02-24-2025, 07:23 AM
