Tv turns on. Can see the backlight cut on and get no picture. Thought the power supply was good too so ordered the main board figuring that was the issue.. got the new board in and still no picture. I double checked by trying to open the menu and nothing happens.. help please?
Samsung ln32d450g1d No picture after changing main board.
Re: Samsung ln32d450g1d No picture after changing main board.
can you post some pictures of the boards used in your tv also have you tested any voltages yet on the psu?
How long roughly is the backlight on for a couple of seconds? if so this could possibly be be a faulty invertor or ccflLast edited by vinceroger69; 10-29-2016, 11:36 AM. -
the backlight stays on all the time no issue there.. Just the picture seems to not come up. I tested all the voltages that i could read off the board and they seemed to be just fine. *should also mention that it blinks 5 times when it's turned on*Last edited by jdoncouse; 10-29-2016, 12:49 PM.Comment
ok theres one more board under the metal cover the ribbon cable on the mainboard goes to it thats the tcon board theres a fuse we need to see what voltage you get on each side of the fuse.Last edited by vinceroger69; 10-29-2016, 12:52 PM.Comment
Is the mainboard for that exact Lcd and not just any random one ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Yes i got the correct one. went by the model number on the old one.. i'll have to get some time to get to the tcon *i didn't even think about it because i couldn't find the part on any parts stores* I'm gonna guess its one of the tcons that are ribbon cabled to the panel? i'll test it when i get the chance tonightComment
no its seperate from the lcd maybe if its a common failure is why you dont see them listed but yes remove the shield etc take a picture of it and note the board number and and also test the fuse too
http://www.partandproducts.net/sa35tforln1.htmlLast edited by vinceroger69; 10-29-2016, 02:10 PM.Comment
Unfortunantly it's what i feared.. it's a tcon that's ribboned to the panel.. i checked the fuse which is rated 125v 3a and it's getting only 12v to 13v.
Just bought the service manual and i now have check points i can use. Sadly i think that maybe the main is ok now and it's the tcon.. i'll check points though and see what i can find.Last edited by jdoncouse; 10-29-2016, 03:58 PM.Comment
"i checked the fuse which is rated 125v 3a and it's getting only 12v to 13v." The Voltage rating of the fuse is not what the Applied Voltage to the circuit is, it is the MAX Voltage the fuse can be use safely, so you do have 12VDC for running the T-CON, 125V to the T-CON board would have produce nice smoke.
Try having one ribbon able between the T-CON and the LCD panel connected one at a time to see if you get the picture on half of the screen or not, make sure to put the cables back in place properly.Never stop learning
thanks.. i'll mess with it and see.. It's actually one huge ribbon cable that attaches to the bottem of the panel from the tcon.. i wonder if i have gotten a bad main board then??Comment
Can we see the pictures of the whole backside of the TV?
It sounds like you have one of those LCD panel with tab bonding board on the bottom edge of the LCD panel which will be bad news if someone clean the panel improperly.Last edited by budm; 10-29-2016, 06:52 PM.Never stop learning
ive never myself saw a bonded tcon to a panel on a 32 in set i have saw it loads of times on smaller models is there a white sticker on the metal tv chassis that tells you what panel is used in the tv as it may give us some idea of voltages etc to testComment
I believe that there is a tcon board under the cover since googling does come up with it.
PRODUCT DESCRIPTION
Samsung T-con board
Model: LN32D450G1D
Part: 35-D013932Willing to help but I'm no expert.Comment
Thats what i found too in post 7 but i beleive hes saying its fixed to the panel i guess untill we see the pictures we wont know i think budm maybe rite when he says it maybe tab bond damage as the tcons on the bottom of the panel.I believe that there is a tcon board under the cover since googling does come up with it.
PRODUCT DESCRIPTION
Samsung T-con board
Model: LN32D450G1D
Part: 35-D013932Last edited by vinceroger69; 10-30-2016, 10:09 AM.Comment
Based on post 3 pictures, the tab bond is on the bottom edge of the panel, he wil need to get the metal cover off to see if the Tcon is under the cover or it is one of those panel with integrated Tcon. I cannot read the panel model number to verify.Last edited by budm; 10-30-2016, 12:53 PM.Never stop learning
This specification for the Samsung Galaxy Book 2 Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Galaxy Book 2 boardview and Galaxy Book 2 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...09-07-2024, 05:50 AM
by TR103Hi, I have a Samsung UE50TU with:
- it keeps rebooting
- without cable between mainboard and lcd panel and with a jumpered... -
by Asraf AtbHi everyone,
I disconnected the main board from the PSU, and the backlight turned on, which seems to confirm the main board is the issue....1 Photo -
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by JSin21Hoping someone here could possibly help. I have a few questions in regards to compatibility with main boards. But I'll give a quick short run down on what's going on first;
I have Samsung Smart TV UA65MU6100WXXY version DA01
Now years ago it started intermittently playing up after a lighting strike. Lighting hit the block of units i was living in at the time. Ever since that night the TV started having a mind of its own, It would randomly turn itself off or on, and all inputs stopped responding like HDMI, aerial, but USB still worked. Anyway, over the next few months...4 Photos - Loading...
