This one starts up and runs okay, but the backlight cuts off after between 2 and 10 seconds (almost like it fades out; it's not an abrupt thing). I see inverter boards, so this one is a CCFL-backlit model. The question is, what is the easiest way to find out which inverter (if any) is bad or if we have a backlights problem?
Backlight cuts out on LG 55LD520 55" LCD
Tags: None
Re: Backlight cuts out on LG 55LD520 55" LCD
Easiest way is diagnose it using the forum to help with methods shown in 100's of other threads.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
https://www.facebook.com/Telford-Tel...7894576335359/Comment
Fixed itself!
In an interesting turn of events, this thing somehow managed to fix itself. Between my angry glares and inspecting of the inverter board, I turned the set back on and was not able to get it to fail. I wanted to take some pictures to see if I could see dim spots that could reveal a bad backlight, but was surprised when it didn't turn off. Eventually, I cleaned it and then put it all back together and ran it for close to 20 hours. No more problems.
I guess only time will tell if it remains fixed. Fingers crossed!Comment
This could be due to a cracked solder joint on the power supply which could be making temporary contact due to moving the tv around.Comment
It's back!
Sure enough! It is back to having the same issue again. How confident are you in bad solder joints on the power supply versus the inverter board(s)?Comment
Some Measurements from the power supply
I took another crack at it and got some measurements on the connection from the power supply to the master inverter. Here's what I came up with:
ERR - starts at around 3.5, drops to 1.3 after the thing finishes booting up
PDIM #1 - stays at 2.7
INV-ON - holds steady at 3.4
ADIM - 0 volts
24V - holds steady at around 24.8
Given that the power supply is giving consistent power to the inverter, is it reasonable to assume that the inverter is where the problem lies? Backlights don't exhibit intermittent failure, right?
Now, the question is finding which inverter is giving the problem.Comment
What does the Bl on signal do when it fails ?Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
RL-ON = Relay on, same as PS-ON or PWR ON.
It should have command pin for the Backlights ON/OFF. The cables are blocking the view of the connector on the power supply board that goes to the inverter board so we cannot see the pin labels.Never stop learning
BL-On = Inv-OnTELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
ah ha! (2)
possible lead
I had a conversation with a parts supplier and he had a hot tip - he thought that a cold solder joint on the mainboard could be causing this problem and recommended a reflow. Has anybody else heard of a backlight cutout issue being caused by a cold solder joint on the mainboard?Comment
No point in guessing the fault, we need you to diagnose and test it. Check what Bl on does when it fails and Bl error.Please Do Not PM My Page Asking For Help Badcaps Is The Place For Advise, Page Linked For Business Reasons Only. Anyone Doing So Will Be Banned Instantly !
No news
I tried the dryer trick on this one also by individually heating each board for a few minutes with the dryer before powering it up, but had no luck or change of any kind.
I did get a better look at the problem though (which manifests almost instantly now, so there is no way to get a test pattern up). The interesting thing is that when it first turns on, it displays at full brightness for a split second before becoming really dim and then ultimately turning off. This might be part of the normal startup routine, (I can't remember for sure anymore) but if it's not, it may provide a valuable troubleshooting clue. Unfortunately, I'm just not very experienced when it comes to electronics repair, so it's tough for me to say.Comment
Maybe he's on to something
I've been researching this a bit more and found a handy troubleshooting video that seems like it could be a good reference. The only problem is that the transformers are a little bit different. What points would need to be tested on this board to see which one (if any) has a higher voltage draw? Also, would the standard chassi ground be the reference point for testing this as well?Comment
Check the power supply board visually and look for cracked solder joints on the power supply. I still think you have an issue with a bad solder joint. Especially if the TV started miraculously working for a bit and then went back to the same issue. If you had a shorted diode or resistor or some sort of other issue like that, the tv wouldn't all of a sudden start working again.
Cracked solder joints occur due to heat stress. So look at anything on a heat sink/near a heat sink, transformers, or anything on high voltage lines. I have seen connectors get cracked solder joints, look at those as well.
If you keep turning the set on and off say about 10 times, do you see any difference?
Also to rule out your main board, bypass the power supply with BL-on and PS-on to 5 volt.Comment
Power supply not the culprit
Bad luck; feel better!
Phew, we're just having the worst of luck with this thing. The first inverter board I ordered was the wrong one ("Rev:6" instead of "Rev:4", which are identical boards, but Rev6 has a slightly different connector that connects to the inverter right above it) and the second one was the correct one, but the seller sent me a "Rev:6" anyway, so I arranged for an exchange. Unfortunately, the replacement was also a "Rev:6", so now I'm in the process of getting that one exchanged for the correct one once again.
While we're waiting for that, does anybody have any lamp troubleshooting tips (just in case those are the issue) now that we've ruled out a power supply board?Comment
by triplefourthis tv is throwing me for a loop. do samsung tvs no longer have the backlight self test feature built into the power supply?
according to how ive diagnosed in the past, this would almost always be a bad power supply. replacement power supply was cheap like 20$ from ebay. but still i get not even... -
by DanPokaI bought this p2210f dell monitor to fix. Schematic is the same as p2210.
Behaviour is that monitors comes on but then backlight switches off almost instantly. If I look with flashlight I can still find the "No signal message". So definitely a backlight issue. Trying to advance the issue I proved that the protection circuit is switching off the backlight by shorting out C3 and resistor to disable the INL chip then re enable by removing the short.
This is where it gets interesting. When I disassembled the monitor to solder leads on c3 capacitor I noticed the backlight flickered...-
by Comp_ProHello all,
Am trying to figure out this backlight issue with this A1990 Macbook Pro.
Tests performed:
There is no backlight even with a good screen.
Backlight IC is receiving the correct support voltages.
Fuse F8400 ok
Current sense resistor R8400 ok
Backlight IC is receiving 3.3V on enable pin.
Backlight IC receiving voltage from PPBUS_G3H, aprox 12.5V.
Backlight IC receiving 5V from PP5V_G3S
Backlight IC BKLT_SCL and BKLT_SDA both measure 0.545V diode mode to ground
I2C_BKLT_SCL and I2C_BKLT_SDA both measure... -
by cheebsterHello, got an iPad Pro A2378 12.9 5th gen with no backlight. Got another test unit without screen, tested the screen, still no backlight with the test unit.
Figured out the backlight on the screen was bad, ordred a new backlight from mobilesentrix, *carefully replaced it* without damaging the lcd, oh well.
Final result, issue is still there, the screen has no back lights. So i'm back to square one, with 3 hours less and 100$ out, issue still on the screen.
The panel is still ok, i can see the apple in the middle of the screen when it kicks in, just no backlight.
Anyone... -
by canadaboy25Hi all,
I've got an LG Flatron 24EN33TA with a backlight issue. The problem began with the monitor not powering up after sitting for a long time (overnight or during the day throughout work). When I would wake the computer up, the backlight would flick on for a second then go out. Sometimes it would take many tries to get it to come on. Once the monitor came on, it worked flawlessly until another long duration of being powered off.
I thought the problem would be bad caps but I checked both of the caps on the board and they are fine. I also tried powering the monitor from...-
- Loading...
