Vizio e500i-b1 no turn on standby light fades out in 5 sec.
  • x_orange90_x
    Vizio E550i-A0 no power, no standby light
    by x_orange90_x
    I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
    11-20-2023, 09:49 AM
  • p-top
    Vizio, E60u-D3, no standby light, no ps_on
    by p-top
    Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
    main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
    PS voltages
    1 VSNS -2mV
    2-5 LED-OUT -2mV
    6-10 GND -2mV
    11 +16VS 16.29V
    12 AC-DET 3.929V
    13PS-ON -3mV
    14 +16VS 16.29V
    15 +16VS 16.29V...
    11-27-2023, 10:44 AM
  • ChristianBr01
    LED TV Samsung The Frame 55 inch QE55LS03RAU Standby Light only
    by ChristianBr01
    I got a Samsung The Frame 55 inch TV for free from uncle cause it is not turning on anymore. I am in the second year of training as an electrician so I have knowledge already but I am far away from to be a pro.
    The TV has Standby but ist not turning on. A Friend of mine owns a 50 inch Frame TV so I checked the One Connect Box and the One Connect Cable there. Both are good and working normally. I have opened the TV case and measured some voltages on the Board.
    What I already found is that the 12.8V are not an the connector to the main board connector to the power...
    04-23-2025, 01:48 AM
  • bunting78
    Vizio D650i-B2 wont trun on and no standby light
    by bunting78
    First off i want to say hello, as i am new and happy to be in the presence of people that know much more than me in these situations. I have searched through quite a few threads and not found and issue just like the one i am having. I just acquired a Vizio D650i-B2 that I was told just quit turning on and has no standby light. Going through some light diag last night i found that the set has a steady standby 5v at the power board connector. without removing any of the boards yet there is no obvious signs of burning, bloating, or cracking on anything that i see. I unplugged the IR board as i saw...
    09-23-2021, 08:53 AM
  • fharris1977
    Vizio D50u-D1 Dead Set No Standby
    by fharris1977
    Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
    12-28-2023, 10:25 AM
