Curtis 3227A no Audio Issues
  • mike123333
    • Oct 2011
    • 196
    Hello, I acquired a Curtis 3227A LCD that has video and no audio. I ran through the basic voltage testing and capacitor evaluation with my ESR meter and did not find anything obvious. I was wondering what could be the issue with this type of symptom? I will have photos of the main board and power supply when the server is not as busy..
    Thanks Mike
  • mike123333
    • Oct 2011
    • 196
    Re: Curtis 3227A no Audio Issues
    Here are the photos..
    • CapLeaker
      Leaking Member
      • 8136
      Audio ic bad? Something stuck inside the headphone jack?
      • mike123333
        • Oct 2011
        • 196
        Hello Capleaker - Thanks for the response, is that what typically goes bad with the audio portion of the board is the ic? how does one go about checking if it is bad or not?
        • dick_barton
          • Aug 2015
          • 6642
          • Wales
          What are U10 & U21.
          As CapLeaker suggests there may be a problem with the headphone socket otherwise you may not have the correct voltage supply for the Audio Amplifier.
          • mike123333
            • Oct 2011
            • 196
            Hello, when you say what are U10 and U21, are you referring that these IC's are possibly the problem child?
            • Diah
              • Feb 2013
              • 6362
              did you take look at menu Audio setting if the sound out put set on intern speaker?
              • martino
                Not so "senior"
                • Aug 2013
                • 997
                • canada
                I would first check in the menu,to see if tv speakers are disabled?
                Then try and see if you get sound out of the headphone jack.
                U17 and U18 look like voltage regulators,guessing U17 regulates the power for U21 which is your audio driver IC.
                You can find specs on U17/18 and see if they are correct in voltage output.
                BTW,what happened to Ca16,it looks like it got messed with.
                Proud owner of dozens of broken TV's and many,many,many boards.
                Our website and passion:http://hollenhundshepherds.com/
                  Do you get sound at the RCA AUDIO LINE OUT?
                  As MATINO indicated, check the setting also.
                  • dick_barton
                    • Aug 2015
                    • 6642
                    • Wales
                    What part number is printed on each
                    • mike123333
                      • Oct 2011
                      • 196
                      I did look for the obvious as to whether the internal speakers were on or off, everything was good from there. There is no head phone jack so I cannot test that. I am presently using the rca audio jack to run from a dvd player.
                      As for the IC chips U16 and U17 ( that is the correct number on the boards) one is a 7808 and the other is 7805 , 7808 is outputting an 8 volt and the 7805 is at 5 v so both of them are good.
                      CA16 I had to take it out to test it offline with my ESR meter and had difficulties putting it back into the holes so I soldered it from the top.
                      As for U10 the number on IC is MSB1501-LF, A7MFR39C and U21 is TPA3124D2, O4TGA
                        The TV has RCA Red and White audio outputs, did you try that? If you get the sound there then that will partially eliminate problem in the pre-amp section.
                        • dick_barton
                          • Aug 2015
                          • 6642
                          • Wales
                          What is the supply voltage on Pins 1, 3, 10, 12, 19 & 20 on the TPA3124D2 audio amplifier.
                          • mike123333
                            • Oct 2011
                            • 196
                            Hi Budm, yes I did try that and nothing happens.
                            • mike123333
                              • Oct 2011
                              • 196
                              All the voltages are reading 23.55 VDC
                                Since you are NOT getting any audio at the pre-amplify RCA line out which the circuit is BEFORE the power amplifier section then the problem cannot be in the power amp section.
                                • mike123333
                                  • Oct 2011
                                  • 196
                                  I was do more troubleshooting and have a question, if you can see in the picture the 2 large capacitors next to the speaker plugs. when I check the voltage from ground to the speaker plugs I get 12-13V, even if I check across the neg and pos leads of the plugs. If I check the capacitors from ground to + of capacitor I get the same voltage, however if I check the voltage across the capacitor leads it is ~0.7V. If I check the resistance of the ground to the neg lead of the caps I do not get continuity, does this sound correct?or should there be a ground continuity to the neg side of the caps? hopefully you can follow what I am asking
                                  • mike123333
                                    • Oct 2011
                                    • 196
                                    forgot to mention, the voltage of the caps from gnd to either lead of the cap is measuring at 12-13V, so its not only the positive lead of the cap its also the neg
                                      If you look at how the amplify is setup in the spec sheet of the IC, you will see that there is DC BLOCKING/COUPLING cap between the output pin of the IC and the positive pin of the speaker. So the DCV on one side of that coupling cap that is connected to the output pin should be = 1/2 of the VCC supplied to the IC, the other side of the cap that is connected to the speaker + wire should be 0VDC, you should check the DCV the two legs of the speaker (speaker has to be connected to the connector).
                                      • mike123333
                                        • Oct 2011
                                        • 196
                                        I checked the voltage across the speakers with them plugged into the circuit. The left side starts at 12v and steadily drops down I stopped at 5v monitoring. The right side started at 3.6 and pretty much stayed there. These were measured across the speaker plugs. Could this be due to the output side of the IC is faulty?
                                        I don't quite understand your explaining on how the voltage is 1/2 from the DC blocking/coupling cap. I tried to follow it but don't quite understand. if you can elaborate on that. I would like to better understand. Thanks
                                        • samson7point1@yahoo.com
                                          Help troubleshooting an audio problem with an RCA SGT-250 CED Player
                                          by samson7point1@yahoo.com
                                          The Problem: This player has a toggle switch to select between Stereo, Mono R, and Mono L. Regardless of the setting it outputs the sound to both the L&R audio jacks. In the Mono R position, the audio output level is normal (from both the L and R audio output jacks), in the Stereo position the audio output is about half the volume, and in Mono L, it's about 3/4 the volume. Something about putting it into Stereo mode is causing the volume to drop significantly and I can't figure it out.
                                          The player processes the audio signal using two different reference frequencies. The "R"...
                                          04-30-2024, 11:22 AM
                                        • SoulFreeze
                                          Audio Issues - Realtek ALC3306 - Lenovo Slim Pro 7 14ARP8 - Type 83AX
                                          by SoulFreeze
                                          Hi, trying to troubleshoot some problems with this laptop I just finished repairing which had power issues (Burnt Buck converter - SY8883DFC shorted to ground).
                                          After repairing the above issue, I realized the following remaining problem,
                                          Sound only comes from bottom speakers, top palmrest speakers don't work. Neither does the headphone jack (static/buzzing).
                                          The computer recognizes headphones are connected and displays a popup in windows
                                          Sometimes, the computer will boot up and the sound will be working fine. However, if I run intensive programs and the computer...
                                          06-21-2025, 09:53 AM
                                        • i_am_patch
                                          Roland KR-3500/4500 Digital Piano. Crackling audio sound on all keys -Fixed
                                          by i_am_patch
                                          Hi All. I had a Roland KR-3500 Digital Piano (similar to the KR-4500) that exhibited a Crackling audio sound on all keys. After reading somewhere about someone with a similar issue who had replaced all the Electrolytic caps I decided to also go down that route. (Spoiler : It worked !) After some basic troubleshooting I determined that it could be noise feeding thru from the Keyboard scanning since the Demo tunes played back undistorted and the Audio amp / speakers were fine ( Inserted an Audio signal into the rear Audio input). After extracting the main board from the shield, I replaced 7 Capacitors...
                                          04-30-2024, 08:20 PM
                                        • MOSSEP
                                          Monitor Audio RSW12 - Green light but no audio
                                          by MOSSEP
                                          Hi
                                          Im hoping someone might be able to give me some idea of what may be wrong with my Monitor Audio RSW12 Sub.
                                          Ive owned it since new in around 2002, so would really like to keep it running if I can, it was the first ‘decent' bit of audio equipment I ever purchased and is a little sentimental.
                                          The issue I had was that it would power up with the red light, but sometimes the green light would not come on and I would get no bass from it. If the green light did come on though, I would get sound out of it.
                                          I have already tried replacing all of the...
                                          01-26-2025, 08:18 AM
                                        • grimacelord
                                          MacBook Air 2337 - Right I/O Board Audio IC - Alternative Replacement?
                                          by grimacelord
                                          I'm working on a MacBook Air A2337 that had liquid damage on the right I/O board. I ultrasonic cleaned the board and it all functions except the computer has no audio. I tried reballing the audio IC which is TAS5770AC0, but that did not restore audio. I could just replace the entire board, but I wanted to see if replacing the audio IC would fix it first. Mouser has a similar audio IC in stock which is TAS5770LC0YFFR, but I wasn't sure if it is compatible. I was just wondering if anyone knew if I could use the one from mouser as an acceptable replacement or if I need to purchase...
                                          12-11-2023, 11:13 AM
