Re: Curtis 3227A no Audio Issues
Can you read the schematic? You also need to understand how that IC functions when it used in SE (Single Ended mode) and why it needs the DC blocking/coupling cap.
The output pin of the power amplifer will sitting at 1/2 of the supply VCC, so if the power supply is 24VDC, then the output pin will be at 12V.
As you see, if you hook up the speaker directly to the output pin of the IC, then you will be applying 12V to the speaker which you will damage the IC and the speaker, that is why you need the DC blocking/coupling cap between the output of the amplify and the speaker.
if the has leakage resistance or shorted out then the cap will no longer block the DC to the speaker.
If you trace out the + speaker wire to see if it is connected to one end of the cap, and another end of the cap goes back to the amplifier output or not. See PDF page 19 FIGURE 32 as a guide.
you need to look at the spec sheet of the IC, then trace out the connection from the output pin of the amplifier all the way to the speaker connector.
BTW, if you have 12VDC on the speaker terminal with the speaker connected then you have heard loud popping sound form the speakers.
You should check the speakers if they are still OK.
Notes: the amplifier in your TV is the Class D amplifier, the example below is the Linear amplifier but the outputs for both type of the amplifier with single power supply will have DC at the output, the DC blocking cap is also part of the high pass filter, see PDF page 14.
http://reviseomatic.org/help/e-a-amp...Amplifiers.php
