Samsung UE55F9000ST
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Samsung UE55F9000ST
    Looking to repair a current Samsung Smart 4K 3D HDTV I currently purchased, Sorry i dont have any history, thought I would take the gamble. Anyway couple of questions first.
    Make : Samsung
    Model number is : UE55F9000ST
    Does anyone have this or any experience with the type of tv that requires a One Connect box, if so, if the One connect isnt connected to the TV does anything appear on the screen at all?
    At the moment all I get is a white/blueish screen the little white light (ON indicator) at the front is on and the standby button changes from red to blue or green (will need to double check again)
    So seems the TV is powering up in some way, I just don't know if it should boot up with the Samsung Logo on screen or a splash screen of some sort, don't want to fork out £300 on the One Connect unless I know the TV is doing what it should be doing.
    Thanks in advance
    Stephen
  • StephenU
    • Dec 2013
    • 230
    • United Kingdom
    Re: Samsung UE55F9000ST
    Here is a pic with the TV powered up no One Connect.
    Got tv opened and found a blown fuse (F1) on the what I think is the TCon and replaced but no difference.
    Any pointers would be much appreciated on this one as always guys.
    Stephen
    • StephenU
      • Dec 2013
      • 230
      • United Kingdom
      Pic of F1 which is a 125v / 7A
      I replaced with a 125V / 3A
      • Moreno83
        • Jun 2014
        • 2008
        • The Netherlands
        This looks like a T-con problem , it can cause a white screen.
        Can you provide pictures from the boards?
        • dick_barton
          • Aug 2015
          • 6643
          • Wales
          If it's a 7Amp fuse being replaced with a 3Amp fuse I'm surprised it hasn't blown open circuit.
          • StephenU
            • Dec 2013
            • 230
            • United Kingdom
            Sure i will get it back open tonight and give it the all over, and get some decent pics posted.
            only thing i had in the spares tray i'm affraid, will check it again tonight once opened see how it is.
            Thanks for the input guys.
            Stephen
            • mmartell
              • Oct 2013
              • 3189
              Something happened to pop the fuse in the first place so go over the tcon thoroughly.
              • StephenU
                • Dec 2013
                • 230
                • United Kingdom
                Thanks mmartell, I will do.
                • StephenU
                  • Dec 2013
                  • 230
                  • United Kingdom
                  T-Con board PN's are -
                  VD_5565EU22BC6LV0.1
                  LJ94-29145F
                  • flocko
                    • Nov 2012
                    • 1121
                    good luck finding one of them?
                    • StephenU
                      • Dec 2013
                      • 230
                      • United Kingdom
                      Thanks flocko.!
                        I can be bad panel (shorted TFT driver ICs) that caused the fuse to blow and it may take out your new T-CON too, you should try having one cable between the T-CON and the LCD panel connected one at a time to see what you get.
                        • StephenU
                          • Dec 2013
                          • 230
                          • United Kingdom
                          Have the tv stripped down at the minute, fuse had blown again. Will try your method budm and let you know. I did try unplugging the right hand side panel cable , no difference and also done vice versa with left, same outcome. ( from the bn94-06576a board that sits above tcon.) cables in pic attached. Also a tcon going by the part number.
                          Stephen
                          • StephenU
                            • Dec 2013
                            • 230
                            • United Kingdom
                            Removed all 4 ribbons and replaced one at a time, same white screen, also removed all and tried with same outcome again. Any other suggestions would be appreciated.
                            Stephen
                            • Diah
                              • Feb 2013
                              • 6435
                              SAM 4K panel had on both side left and right side ribbon taps easily moved round to get damage, you need to remove the LCD bezel to check them.
                              • StephenU
                                • Dec 2013
                                • 230
                                • United Kingdom
                                Didn't notice any damage to ribbons around the inner bezel, I am going to replace the blown fuse again, now have 5A ones then disconnect everything connected too the tcon board, i will replace one thing at a time and check fuse after plugging a ribbon/connector etc in,(powering down and back on after each instance) this should surely narrow it down to which board the fault lyes?
                                TIA
                                • Chrissygizmo
                                  by Chrissygizmo
                                  02-10-2025, 12:33 AM
                                • Chrissygizmo
                                  samsung galaxy ao2s very temperamental after screen replaced
                                  by Chrissygizmo
                                  Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                                  Ive eventually managed to get it on and working but it's very temperamental...
                                  The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                                  05-26-2024, 12:05 AM
                                • JunkmanJimbo
                                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                                  by JunkmanJimbo
                                  Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                                  No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                                  Please help. Thanks in advance!
                                  08-12-2025, 11:45 AM
                                • Kiberge
                                  Samsung LH82QENELGC/EN Help needed - Static line on screen
                                  by Kiberge
                                  HI guys!
                                  I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                                  I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                                  the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                                  This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                                  04-22-2024, 11:28 AM
                                • KYBOSH
                                  Trying to Save - Samsung 65" The Frame (QN65LS03B) with no signs of life (One Connect Box)
                                  by KYBOSH
                                  I picked this one up today.
                                  Previous owner says no signs of life.
                                  TV looks immaculate and its a 2022 model year so I thought maybe the one connect cable was damaged.
                                  Got it home and put it on the Kill-A-Watt power meter and it was completely dead.
                                  The TV model is QN65LS03BAFXZA - version: CB06
                                  The One Connect Box BN44-01066D / BN96-54788Q / BN39-02470A.
                                  I immediately remembered EazyBone's Samsung The Frame TV no power....One Connect thread and am preparing myself to tear the One Connect open and hunt for dead parts.
                                  Will keep you all...
                                  04-05-2025, 08:32 PM
