Tips or tricks to identify cracked LCD panels on dead units?
  • sattech200
    • Aug 2012
    • 59
    Anyone have any tips on spotting cracked LCD panels on units that wont power up?
    I recently bought a lot of a couple dozen flat screens and discovered there were more cracked displays then I was originally able to see, which is ok, I am still money ahead.
    Now I have a handful of units sitting here that are dead due to power supply or mainboard issues. Starting to second guess myself weather to sink the money into them for replacement parts only to find out I have more cracked panels.
    About the only tip I know is to look at them very carefully at all sorts of different angles using various bright lighting.
    Just wondering if there were any other tricks I could use to spot them?
  • CapLeaker
    Leaking Member
    • Dec 2014
    • 8327
    Re: Tips or tricks to identify cracked LCD panels on dead units?
    Force the PSU to turn on the backlights?
    • comptek
      • Aug 2013
      • 606
      • uk
      1) get them in daylight ......... sunlight is better you will see patches where its broken sometimes a camera flash shows them up
      2) look to see what else theyre selling, boards and working tv's steer clear theyve had a go at it and knows the screen is damaged
      3) look for chips on the screen
      4) vertical lines on screen cant be seen until you get the unit working
      the above have saved me money
      • AJ847.63e
        LGA 1700 Socket Replacement Tips & Tricks
        by AJ847.63e
        Hi All,
        Just wanted to see if I can get some advice on techniques and equipment I should use to try replace the socket on a Gigabyte H610M h v2ddr4 I have.
        I was planning on using a heat mat I have that's used for phone, tablet screens, as a base heater than use hot air with a square nozzle on top. Yes I should get a proper preheater but I'm not in the position to go spend 300+ bucks on something I will use every 6 months if I'm lucky. Next expense I need to get is a decent programmer like the RT809H but again it would get used infrequently so hard to justify.
        07-24-2025, 06:57 PM
      • eccerr0r
        Sell or Shim Solar panels?
        by eccerr0r
        Well, due to my grid tie inverter not accepting high voltages, and the fact that the lions in my solar panels are 36V (72-cell) I think I need to stick with 72-cell.
        However I have a few smaller panels that are 36, 32, and two 30-cell. The 36 and 32 together run at 75% efficiency (and subtract more with additional inefficiencies) when running in parallel with the 72-cell panels. The kicker is that the two 30s... generate 0% power when connected in parallel(!)
        So now what to do with these small panels?
        I could sell them...
        Or I could shim them....
        03-29-2025, 01:07 AM
      • Prott
        Soldering flex cable - tips & tricks
        by Prott
        Hello fellow badcappers,
        I have to solder a MacBook (A1708) screen flex - one of the two data flexes got slightly torn (2 broken traces). I've seen some videos on youtube where people scrub the coating and then simply apply flux and solder to the exposed copper traces (and then run a jumper wire). However no matter what I try the copper does not take the solder at all - the more flux I add the more it actually stays only on the iron itself.
        I am practicing on a spare flex cable and it's gettiing quite annoying - to a point I am actually thinking I have to be doing something...
        10-04-2023, 06:25 AM
      • SapientLion
        2004/05 AGP GPUs: Repair Tips and Tricks
        by SapientLion
        Hello, everyone!
        This is my first actual post on this forum. I don't know anyone here nor have any knowledge on proper etiquette that is supposed to be applied here... So, bear with me and my mistakes. I'll try my best. Regardless, here's my story.
        A few days ago, i discovered and managed to purchase two AGP x8 GPUs (ASUS Extreme N6600 [NVIDIA GeForce 6600] and ASUS AX1650PRO AGP [ATI Radeon X1650 Pro] ), from a trusted seller, for dirt cheap, which were released way back in 2004/05. They were primarily used for graphics design and 3D modelling. As far as know,...
        06-28-2023, 05:35 PM
      • estabilito
        Tips geting oxidized when using wick
        by estabilito
        Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
        i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
        Temperature: 350-365celsius
        station: jbc cd-2bqe
        Wick: edsyn
        flux: warton hf rework jelly
        Do you have any tips?...
        04-12-2025, 11:55 AM
