Sony KDL 46Z5100 Blinking Red Light After Lightning
  • Biglurr54
    • Aug 2016
    • US
    I have a Sony KDL46Z5100 that we were watching and lightning struck near by and the tv turned off. Everything else in the house was fine including the Ac's which were running. The cable, phone, and internet all went down and i was told by the repairman that a coax cable in the basement fried.
    When i plug the tv in i hear a relay click and the green indicator led lights for a second then it goes to a red light the blinks 3 times. The screen never powers up.
    I downloaded the service manual for the set and it says replace the BU board for 3x blinking red light.
    How interchangeable are the BU boards? My BU board is 1-879-224-12 there is another number that is A-1671-683-A.
    I found a 1-879-224-12 board but it has A-1671-682-A - Will this work?
    I search of KDL-46z5100 also shows BU board 1-879-224-14. Will that board work? Im willing to put some money into saving the tv but i dont want to throw money away with out knowing the part will at least be the right one!
    I have found many 1-879-224-14 boards they have different A-1671-68X-X numbers. Do the second set of numbers count towards compatibility?
    Thank you for your help in advanced!
  • tiki66
    • Jul 2016
    • 63
    • Croatia
    Re: Sony KDL 46Z5100 Blinking Red Light After Lightning
    Tricky, I would try to find exact board from the same model because sometimes you have to flash software again and I'm not very sure if you can find it and flash it without visiting service centre
      http://www.shopjimmy.com/catalogsear...ny+KDL+46Z5100
      I would contact shopjimmy.
      • YasaCh
        Sony kdl 40p5500 red light keeps blinking 3 times
        by YasaCh
        Hello...
        my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
        i opened the back cover no sign of damage on the powery suply or motherboard
        when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
        another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
        07-07-2025, 11:53 AM
      • asher_pa
        SONY KDL-55W905A 4 Blinking Red light
        by asher_pa
        My SONY TV (KDL-55W905A) started with '4 Blinking Red light' problem, my TV DO show picture for 3 Sec and turning screen off and start blinking - all factory reset technics did not help.
        google it and found the problem can be the PSU.
        my PSU model is 1-888-119-11 , APS-344 , APS-344(CH)
        As I can see I have 2 option:
        1. I OD HAVE multimeter but unfortunately not much knowledge how to use it (but DO have good soldering skills) maybe some can point me from his personal experience which part need to be replaced?
        2....
        05-28-2021, 07:27 AM
      • Fergal22
        Samsung UE40F5300AK blinking red light
        by Fergal22
        I have the above tv that just shows a red light blinking twice 5 times, i have taken the back off and all the capacitors seem ok,
        When i disconnect the mainboard from the PSU all the led's light up blinking fast but as soon as i reconnect the mainboard back to the power supply i get the red light blinking again twice 5 times,
        I have attached pictures of the Mainboard, PSU and a small video (zipped) showing what happens when i disconnect the lead from the psu
        Any help would be appreciated...
        02-02-2023, 09:19 AM
      • brithepi2k
        Sony KD-65XE8596 no standby light
        by brithepi2k
        I’ve got a Sony KD-65XE8596 here that has no standby light coming on. I’ve tested the power board with the test meter, the TV needs 3.4 for the standby but only getting 2.4. Anything that I can change/check on the board to get it working? Pictures of the board are included.
        cheers...
        09-06-2025, 02:22 PM
      • shahnld
        Sony kdl 65xg9505 green amber blinking
        by shahnld
        Good Day.
        I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
        i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
        green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
        01-03-2024, 03:05 PM
