LG 42ln578v-ze problems
  • jmh474
    • Aug 2016
    • 46
    Im starting up my own electronics repair business fixing tv, laptops and such like on the side as well as working as an electrician's mate, im not advertising im just asking for help please, as iv been handed a tv and im a little stumped.
    The TV comes on fine but i have no sound or picture, the back light comes on!
    Iv check all the output V on the main board and there fine, power going to where it should be.
    So im thinking its the T-con board but i was under the impression that if thats the case the TV go's into like a self protect mode and wont turn on.
    Any help would be grate thanks
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: LG 42ln578v-ze problems
    So you are getting 5Vdc st-by voltage on the Power Bd??
    • jmh474
      • Aug 2016
      • 46
      yes
      • Andrew F. Ali
        • Jan 2014
        • 2450
        • Trinidad & Tobago
        Look on the T-CON Bd and see if you can find the Fuse. Check if you have 5-12Vdc on each side of the Fuse.
          Pictures of the board, T-CON board? 12VDC on the T-CON fuse.
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            On P201 do you have the following voltages
            24V
            12V
            3.5V
            Pwr_ON = ??
            DRV_ON = ??
            PDIM =? ?
            • jmh474
              • Aug 2016
              • 46
              yes voltage at both sides of the fuse
              https://www.badcaps.net/forum/attach...1&d=1471375104
              • Diah
                • Feb 2013
                • 6438
                you wrote that you don't have sound too, T-CON had nothings to do here.. check 24V from the main board side exist or not, if yes main boards faults if no 24v power boards fault
                • jmh474
                  • Aug 2016
                  • 46
                  24V
                  12V
                  3.5V
                  Pwr_ON = ??
                  DRV_ON = ??
                  PDIM =? ?
                  and what voltage do you have at the led output connector P801 which says 157V on the board for 42" set
                  P201 yes all voltages are read right
                  P801 is only 70v but back light is on and working fine
                  • dick_barton
                    • Aug 2015
                    • 6643
                    • Wales
                    Pwr_On, DRV_ON, PDIM ??????Can you tell us what they measure
                    • jmh474
                      • Aug 2016
                      • 46
                      never listen to customers lol there is sound just checked
                      • jmh474
                        • Aug 2016
                        • 46
                        sorry what is
                        Pwr_ON
                        DVR_ON
                        PDIM
                        • dick_barton
                          • Aug 2015
                          • 6643
                          • Wales
                          They are shown on the circuit board. Connection P201.
                          P_On Power On
                          PDIM Led dimming
                          DRV_ON Not sure
                          • jmh474
                            • Aug 2016
                            • 46
                            Using a bright light can you see a picture or the menu on the screen if you look very carefully.
                            back light is working i can see the light from the back holes in the tv
                              So you have SOUND, you have backlights but no pictures on the screen, 12V is present on the SMD fuse of the T-CON board.
                              So next thing to do is to have one ribbon cable between the T-CON and the LCD panel connected one at a time to see what you get.
                              • Diah
                                • Feb 2013
                                • 6438
                                i see LOL then you are close .. waiting your answer on budm test . remain black or there white screen some how.. lol
                                • jmh474
                                  • Aug 2016
                                  • 46
                                  ok so iv disconnected each ribbon cable
                                  (looking at the back of the TV)
                                  right ribbon disconnected still blank screen
                                  left ribbon disconnected half screen white with other half black and purple lines
                                  • Diah
                                    • Feb 2013
                                    • 6438
                                    go deep to the panel taps and check if there water damage or burn before you go to change T-CON
                                      If you look at the T-CON board, you can see bare copper pads for test points that you need to test some DCV readings, the picture is not clear enough for me to read the label for each one of those test points.
                                      • jmh474
                                        • Aug 2016
                                        • 46
                                        is that any better
                                        no burn or water damage
                                        • jean luc ferre
                                          laptop hp g72 b52sf screen problems
                                          by jean luc ferre
                                          on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
                                          the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
                                          i verified the driver of the péripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
                                          i don't understand the reasons of the white stripe at the bottom of the screen below the task...
                                          06-07-2025, 03:27 PM
                                        • Hondaman
                                          USB problems?
                                          by Hondaman
                                          Recently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
                                          (I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
                                          I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...
                                          08-12-2024, 03:26 PM
                                        • clabr
                                          Lenovo 11e problems (any sata hdds are not recognized, sleep battery drain)
                                          by clabr
                                          Need help to solve some problems with this laptop.
                                          After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
                                          After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
                                          Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
                                          Before this had happened I observed some other problems:
                                          When I tried replacing original mecanical HDD with a SSD HDD could not get them...
                                          12-02-2021, 08:09 AM
                                        • jean luc ferre
                                          display screen problems after changing motherboard
                                          by jean luc ferre
                                          First on my laptop i had a motherboard with a pentium 6100 processor. Installing w11 i was blocked on the 23h2 version...impossibility to upgrade toward 24h2 because the SSE4.2 functionnality of the cpu was missing. About displaying and screen looking all was perfect.
                                          I changed of motherboard with an intel I3 processor...and now i don't find the previous aspects of the displaying.
                                          Now i have a veiled screen and pixels are missing though the graphics parameters have not changed.
                                          Desinstalling and reloading the drivers in the same time on the graphic card (intel hd...
                                          09-11-2025, 10:28 AM
                                        • rumpumpel1
                                          Lenovo X13-Yoga Gen 1: hibernation problems
                                          by rumpumpel1
                                          I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...
                                          11-03-2024, 12:31 AM
