VIZIO SV420M stuck in standby
  • slickrickybobby89
    • Jul 2016
    • 87
    • america
    Im working on a VIZIO model SV420M, according to my buddy it just quit working and never had any warning signs before it failed. I opened it up and when plugged in it has 5.1v standby voltage, but when the power button is pressed the power supply doesn't fire up. Can anyone point out some possible problem areas for me to check? When i force the power supply on all voltages are present, so i think this may be a main board issue. Thanks for any and all help.
  • slickrickybobby89
    • Jul 2016
    • 87
    • america
    Re: VIZIO SV420M stuck in standby
    Heres the board in question.
    • CapLeaker
      Leaking Member
      • 8352
      Check if the main board returns PSon on the PSU. No PSon = main board problem.
      These sets are known for bad voltage regulators on the main board. So check those if they are putting proper voltages out.
      • slickrickybobby89
        • Jul 2016
        • 87
        • america
        It doesno ruturn 5v to power supply, is there a specific component or set of components that i should look at?
        • CapLeaker
          Leaking Member
          • 8352
          I can't see what like U6 or U3 is. Anyhow, get the numbers off them, get the spec sheet so you can see the pin out and post the stuff here which regulator, the number printed on the regulator and the 3 pin names you measured (in, out, adj).
          • dick_barton
            • Aug 2015
            • 6643
            • Wales
            Disconnect the main board from the power supply and power up and see if the backlights come on and what other voltages you have on the connector.
            If you only have 5V standby then connect that to P_On(Power ON, On_OFF) using a 1K resistor, switch back on and check the voltages again on the connector.
            As Capleaker said you have a few 117 devices on the board that could be checked out and also a couple of white smd fuses you could check for continuity.
            • slickrickybobby89
              • Jul 2016
              • 87
              • america
              I have removed the main from the circuit, jumped 5v standby to inverter on and ps on simultaneously and the backlight fired, and i recied 12v at the premarked 12v rail. I did not test the backlights voltage as it is functioning, taking test and dicks advice im testing the components around u6 and u3, there are 2 different types looking up the first one for testing purposes i found the datasheet and was looking for reference voltages and found this page. Can i assume that is the voltages i should see at the pins for these 2 components?
              • slickrickybobby89
                • Jul 2016
                • 87
                • america
                The white smd fuses are good.
                • slickrickybobby89
                  • Jul 2016
                  • 87
                  • america
                  I cannot identify the components in u2 u4 u6 and u7 they are all the same, and appear to have 1117 966 D11 printed on them
                  • johnboy1313
                    • Nov 2012
                    • 1959
                    Those are 1117 voltage regulators.
                      https://www.badcaps.net/forum/showth...999#post300999
                      • dick_barton
                        • Aug 2015
                        • 6643
                        • Wales
                        Were the backlight flickering or steady?
                        Can you give the readings on the pins of each of the regulators.
                        • slickrickybobby89
                          • Jul 2016
                          • 87
                          • america
                          H
                          • slickrickybobby89
                            • Jul 2016
                            • 87
                            • america
                            Gnd/adj 4.3 mv
                            Out 1.42v
                            In 3.29v
                            Gnd/adj 2.07v
                            Out 3.32v
                            In 5.012v
                            Gnd/adj 6.91v
                            Out 8.17
                            In 12.20v
                            Gnd/adj 2.05v
                            Out 3.305
                            In 5.86v
                            • slickrickybobby89
                              • Jul 2016
                              • 87
                              • america
                              Gnd -1 mv
                              Out 3.29v
                              In 4.99v
                              Gnd 2.048v
                              Out 3.29v
                              In -4.2v
                              • slickrickybobby89
                                • Jul 2016
                                • 87
                                • america
                                The screen was stable when i jumped the power supply, it appears to be on, without an image.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Gnd/adj 4.3 mv
                                  Out 1.42v
                                  In 3.29v
                                  VOUT is normally GND/ADJ +1.25V which for the others (2, 3 & 4) is correct.
                                  I would expect this to be 1.25V out
                                  • slickrickybobby89
                                    • Jul 2016
                                    • 87
                                    • america
                                    I did also notice that the bga chip on this set gets smoldering hot even though the set can't power on. Is this a sign that there might be a bga issue?
                                    • slickrickybobby89
                                      • Jul 2016
                                      • 87
                                      • america
                                      My friend decided to buy the board istead of repairing, but i'm asking for future reference, i always assumed that such a chip should be inactive untill the set is booted. Its the chip under the cooling fin in the pic.
                                      • dick_barton
                                        • Aug 2015
                                        • 6643
                                        • Wales
                                        Quite possible that the bga chip has gone north. If it's that hot it may have lost some of it's connections to the main board which is one of the problems that is discussed quite often on the forum.
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • PNI E.
                                          Samsung ue55tu7170u not turn on and no standby led main bn9650990e
                                          by PNI E.
                                          Hi guys, I’m back here my friend give me her tv, that doesn’t turn on and no standby red led. When u plug in the cord the red led of one two second is on, then turn off. If you push the power button or the remote the red led blinks but nothing happen. I give u some photo with voltage, don’t look the fuse….because I blow it for mistake nd I dint have the right replace so I just put it for test the tv. The standby voltage should be 11,88 volt on the diode, but I have 13 volts. I put in the photo the different volts I test and there are someone negative…I don’t know if it s normal. On...
                                          03-17-2025, 04:23 AM
                                        • x_orange90_x
                                          Vizio V555-G1 stuck on wallpaper; now stuck on V logo
                                          by x_orange90_x
                                          I just got this tv today and it's getting stuck on the wallpaper. When I first power it on it goes to the V logo, then a black screen for about 15 seconds, then a Chromecast error for just a few seconds, and then finally to a wallpaper. It stays frozen on this wallpaper and does not respond to anything on the remote besides power on/off. Likewise the buttons on the tv do nothing either (besides power). I did the "reset" by holding the volume down and input buttons together for 10 seconds. It showed a message at the top of the screen saying it was Wiping Data and would restart soon. After...
                                          12-28-2023, 06:26 AM
                                        • cheeky2
                                          by cheeky2
                                          05-25-2024, 03:27 AM
