Sceptre 409BV-FHDU8HJ1L02 dead
  • bigmatt0211
    • Dec 2015
    • 44
    Re: Sceptre 409BV-FHDU8HJ1L02 dead
    Alright - the BLon when the tv is off is 2 mV, when I turn it on, the voltage is 3.39v
    The Adj voltage, when the screen is off, is 3 mV, when I turned it on, it jumped to 4.57V, but then dropped and stayed at 1.27V.
      Are you still getting only about 160VDC on the main cap? If you do, then the PFC Voltage booster is not working.
      • bigmatt0211
        • Dec 2015
        • 44
        The main cap registered 160V off, 391V on
        • bigmatt0211
          • Dec 2015
          • 44
          Does that still imply the PFC Voltage booster is not working?
            PFC Voltage booster is working.
            • bigmatt0211
              • Dec 2015
              • 44
              Well that's good news then.
              Alright, where else should I look to figure this out?
              • CapLeaker
                Leaking Member
                • 8050
                Measure between pins VBL+ and VBL- on the connector where the LED backlights are connected. You may need to use the Min/Max feature on the DMM if you have this.
                I am thinking you got a bad LED in the backlights.
                  Can we see the whole back side of the TV showing ALL the boards?
                  I believe the inverter board for the CCFL is INSIDE the panel.
                  • CapLeaker
                    Leaking Member
                    • 8050
                    Oh! There I go... I had for some reason the impression that this was a LED TV!
                    Probably bad secondary on one of the inverter transformers.
                    • bigmatt0211
                      • Dec 2015
                      • 44
                      Here is a picture of the whole back. The individual boards can be seen in one of the first posts, but if you'd like, I can take additional ones.
                      Between VBL +/-, there is 0V registered with me turning it on and off.
                      • CapLeaker
                        Leaking Member
                        • 8050
                        Well... you have to get at that inverter board on the left.
                        • bigmatt0211
                          • Dec 2015
                          • 44
                          So for this inverter transformer, is that something I can get to and successfully fix?
                          • bigmatt0211
                            • Dec 2015
                            • 44
                            Ah ok. working on it now, pics to come
                            • bigmatt0211
                              • Dec 2015
                              • 44
                              Here is that board on the inside
                              • CapLeaker
                                Leaking Member
                                • 8050
                                You can compare the secondary's on each transformer that they are within 3%. DMM in ohm setting.
                                • bigmatt0211
                                  • Dec 2015
                                  • 44
                                  I am not sure how to test for this. There are 4 connections on those transformers, which ones are the secondary?
                                  • bigmatt0211
                                    • Dec 2015
                                    • 44
                                    It seems pins 1 and 3 are connected, but I can't find what 2 and 4 connect to.
                                    • vinceroger69
                                      • Mar 2012
                                      • 6714
                                      #38
                                      is there any numbers on the transformers we maybe able to get a pinout etc
                                      • bigmatt0211
                                        • Dec 2015
                                        • 44
                                        There are some numbers/letters:
                                        t51.8292.291
                                        b2f 1235
                                        00 4 C A 5
                                        • CapLeaker
                                          Leaking Member
                                          • 8050
                                          a new inverter board is $14. You gonna need one anyway if one of these transformers is bad.
                                          • double_DD
                                            How can I be sure that my EC chip is dead?
                                            by double_DD
                                            As the title suggests, how can I be sure that my EC chip is really dead?
                                            I've recently gotten into this hobby of laptop repairs, and have successfully brought back to life a couple with some easy fixes, mostly shorted caps.
                                            Now I'm working on HP Probook 455 G8, that had some "devil" run around on 3V line, burning a bunch of stuff. Luckily I have a dead 455G7 (for spare parts) so I managed to fix it (swapped burned parts) to a point that it will charge (both on barrel jack and usb-c), but it doesn't want to turn on. There is a 3V3 on a keyboard...
                                            03-12-2025, 07:47 AM
                                          • disorder
                                            ps5 edm-033 dead after hdmi/usb ports destroyed
                                            by disorder
                                            hello guys,
                                            i need help to repair a edm-033 ps2
                                            history : as always hdmi port and usb ports destroyed after unplugged
                                            after change them, ps5 dead too : 1 beep, no blue light. after inspection 1.8v power was shorted, and because of dead panasonic chip. after remove it : no short anymore
                                            so i changed it
                                            now i have got 5v stby,, 3.3v stby, 3.3v power, 1.8v power and no short on them
                                            but the ps5 is dead again : 1 beep, near 10 seconds with power lines and then off, no blue light ...
                                            i don't see any projection of liquid metal on pcb.
                                            01-14-2025, 12:48 PM
                                          • Beton
                                            Finding a dead short component
                                            by Beton
                                            Hi guys!
                                            I searched for the term "dead short" in the forum but no specific thread came up however if I'm just blind and couldn't see the thread talking about this please forward me to that direction.
                                            So my problem is I don't know how to find the source of a dead shorted voltage rail. Dead short = ~0 ohm resistance.
                                            I have two VGAs (HD 4850 and HD 4870), both dead shorted to ground on the memory rail. I have the boardview file for the 4870 and the memory rail consists around ~7892346 capacitors...
                                            I have a bench PSU and if I try to inject voltage the voltage...
                                            12-10-2021, 01:05 PM
                                          • zunasthegreat
                                            Chieftec GPS-450-AA with dead 20N60C3
                                            by zunasthegreat
                                            Hello everyone hope all doing well!
                                            I have this PSU (GPS450-AA delta oem) around for like 4-5 years and I had it recapped early 2020 or 2021 with mostly UCC KY and Nichicon PW's. The bulk was and still is fine, the original Ltec's were bloated and empty. The previous issue was some major coil whine noise and at times random shutdowns when going idle. Today it started tripping the mains breaker and I think I have dead APFC mosfets (20N60C3). Right now upon checking I have the Q1 and Q3 FETs dead so far and I guess those are responsible for the PFC circuit. The only thing I care is If there...
                                            09-01-2024, 07:12 PM
                                          • FiguringITout
                                            MSI Raider GE75 - Not posting, probable dead CPU
                                            by FiguringITout
                                            Hello, today I'm working on this lovely MSI Raider GE75 gaming laptop which I bought to flip. Unfortunately, I believe the CPU is toast but I wanted a second opinion before I chucked it into my spare parts bin. I will not have most tools with me today as I'm away from my workbench but I have the basics (a good multimeter, a horrible iron, a solid screwdriver, and my trusty thermal cam). I do not have the original 230w charger, but I have a Dell 180w which was sold with the device and reportedly "worked fine for them".
                                            Specs: I7-10750H, RTX 2060, 32GB RAM (unknown manufacturer)...
                                            07-25-2024, 07:27 AM
