Sanyo dps46819
  • slickrickybobby89
    • Jul 2016
    • 87
    • america
    Sanyo dps46819
    Hey guys I'm working on a sanyo model # dps46819, the issue im having is distorted picture, i think the term is "solarized" i have visually inspected all components and boards, i have tested the power supply to rule it out, all voltages are correct. I cleaned and reset all conections on the set, and resoldered the ground on the tcon connector, and the problem still persists. It is solarized even when the menu is pulled up. Im wondering if anyone might be able to point out which chip would be responsible for causing this issue.
  • cliff_hootarski
    • Jul 2006
    • 411
    Re: Sanyo dps46819
    1st picture, left side, AS15, 48 pin chip.
    • slickrickybobby89
      • Jul 2016
      • 87
      • america
      Re: Sanyo dps46819
      Forgot to mention this is an intermittent problem, after the set is on for about 15 mins sometimes the screen will go back to normal, but will return to solarized after a couple minutes. There is also a buzzing noise coming throught the speakers, i figured it was related to the solarization issue.
      • slickrickybobby89
        • Jul 2016
        • 87
        • america
        Re: Sanyo dps46819
        Is there a method of testing this to verify? Thank you for your quick response cliff_hootarski. Very much appreciated.
        • cliff_hootarski
          • Jul 2006
          • 411
          Re: Sanyo dps46819
          Pictures of the "solarization"?
          Try freeze spray on that AS15 to see if it changes.
          • cliff_hootarski
            • Jul 2006
            • 411
            Re: Sanyo dps46819
            Record the voltages on the "VG"(anything labeled VGxx) test points beneath the AS15 chip
            when the picture is bad vs good. Let us know the values. In table form, ie
            VG01 - xx Volts
            VG02 - xx Volts
            and so on.
              Re: Sanyo dps46819
              I can see the GAMMA DC Voltage test points VG1, ... VG22 but I cannot see ALL of them on the board, some may be under the stickers.
              • slickrickybobby89
                • Jul 2016
                • 87
                • america
                Re: Sanyo dps46819
                Sorry had to reassymble the set lol.
                • slickrickybobby89
                  • Jul 2016
                  • 87
                  • america
                  Re: Sanyo dps46819
                  I have to figure out how to fire this set up with the back removed, i cannot access the t-con board with everything hooked up.
                  • cliff_hootarski
                    • Jul 2006
                    • 411
                    Re: Sanyo dps46819
                    That does look like a classic gamma chip fault.
                    • slickrickybobby89
                      • Jul 2016
                      • 87
                      • america
                      Re: Sanyo dps46819
                      Vg1 15.32
                      Vg2 11.47-11.61
                      Vg4 10.47
                      Vg6 10.23
                      Vg8 10.21
                      Vg10 8.76
                      Vg12 1.707
                      Vg13 7.53
                      Vg15 1.16
                      Vg17 5.27
                      Vg19 14.73
                      Vg21 13.56
                      Vghc 26.81
                      Vgl 5.992
                      Vgma 15.35
                      The chip in question is also extremely hot to the touch, and freeze spray seems to have no affect on its performance.
                      • cliff_hootarski
                        • Jul 2006
                        • 411
                        Re: Sanyo dps46819
                        Bad.
                        • slickrickybobby89
                          • Jul 2016
                          • 87
                          • america
                          Re: Sanyo dps46819
                          Thanks a million, i will report back once i get a replacement board, my soldering skills are good, but i don't think i could pull that chip off. Thanks cliff and budm, I hope to learn more from you in the future.
                          • slickrickybobby89
                            • Jul 2016
                            • 87
                            • america
                            Re: Sanyo dps46819
                            Can i ask how you can tell from those values that its bad? I ask so if i run into the problem again on another set i might be able to test it myself and know without having to ask again.
                            • cliff_hootarski
                              • Jul 2006
                              • 411
                              Re: Sanyo dps46819
                              The voltages should be linear. Decreasing (or increasing) little by little.
                              Vg1 15.32
                              Vg2 11.47-11.61
                              Vg4 10.47
                              Vg6 10.23
                              Vg8 10.21
                              Vg10 8.76
                              Vg12 1.707 BAD
                              Vg13 7.53
                              Vg15 1.16 BAD
                              Vg17 5.27 BAD
                              Vg19 14.73
                              Vg21 13.56
                              Vghc 26.81
                              Vgl 5.992
                              Vgma 15.35
                              • slickrickybobby89
                                • Jul 2016
                                • 87
                                • america
                                Re: Sanyo dps46819
                                Ok, i understand that now thanks alot man.
                                • dick_barton
                                  • Aug 2015
                                  • 6643
                                  • Wales
                                  Re: Sanyo dps46819
                                  Put your values into this spreadsheet.
                                  https://www.badcaps.net/forum/showth...ht=gamma+excel
                                  • slickrickybobby89
                                    • Jul 2016
                                    • 87
                                    • america
                                    Re: Sanyo dps46819
                                    This set is repaired, thanks for the help guys, it was the t-con board.
                                    • noledud
                                      • Dec 2013
                                      • 413
                                      • united kingdom
                                      Re: Sanyo dps46819
                                      To any others who have this problem, instead of buying the full TCON that could be expensive i just used an AS15 repair service off ebay. There are a few people offering it and can sometimes be cheaper.
                                      • hmendez86
                                        • Jun 2015
                                        • 344
                                        • united states
                                        Re: Sanyo dps46819
                                        To my recommendation change the t-con chips some times fails even if there are new...and t-con it self it might have other components in short...it's better a new t-con which in this case the problem.
                                        • petobongo
                                          TV LG 26LV2500 color issue, solarized image
                                          by petobongo
                                          Hi, i have a LG 26LV2500 , i turned on the TV and the colors are awful, most likely solarized issue, already replaced the flex cable between board and TCON and did a reset, none of that worked.
                                          The mainboard is a EAX64280803.
                                          Can someone help me?
                                          Thank you in advance.
                                          03-28-2023, 12:11 PM
                                        • rounin
                                          MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
                                          by rounin
                                          🛠 Original Issue
                                          ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
                                          04-19-2025, 01:18 AM
                                        • ugamazing
                                          by ugamazing
                                          12-17-2024, 07:05 PM
                                        • shahnld
                                          Lenovo legion 5 pro startup issue
                                          by shahnld
                                          Good day Experts
                                          I have a lenovo Legion pro 5 16ACH6H with AMD RYZEN 7 5800H and RTX3070,.
                                          A weird issue has troubled me. If i power on off the laptop 20 times then only power LED will lit but no fan spin no display. At this stage gpu, vram. DDR voltage. 5v 3.3v 1.8v and the rest are present and cpu core is stuck at 0.84v.
                                          And sometimes lets say the 21st time it will boot perfectly and there is image and everything is working perfectly and at this stage i see cpu core...
                                          08-24-2025, 12:31 PM
                                        • ahmarzo
                                          Acer laptop battery draining issue
                                          by ahmarzo
                                          Have a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
                                          Help me to diagnose this issue as there is no shortage in the inputs MOSFET
                                          08-02-2025, 06:39 AM
