Hey guys I'm working on a sanyo model # dps46819, the issue im having is distorted picture, i think the term is "solarized" i have visually inspected all components and boards, i have tested the power supply to rule it out, all voltages are correct. I cleaned and reset all conections on the set, and resoldered the ground on the tcon connector, and the problem still persists. It is solarized even when the menu is pulled up. Im wondering if anyone might be able to point out which chip would be responsible for causing this issue.
Sanyo dps46819
Tags: None
Re: Sanyo dps46819
Forgot to mention this is an intermittent problem, after the set is on for about 15 mins sometimes the screen will go back to normal, but will return to solarized after a couple minutes. There is also a buzzing noise coming throught the speakers, i figured it was related to the solarization issue.Comment
Re: Sanyo dps46819
Is there a method of testing this to verify? Thank you for your quick response cliff_hootarski. Very much appreciated.Comment
Re: Sanyo dps46819
Pictures of the "solarization"?
Try freeze spray on that AS15 to see if it changes.Comment
Re: Sanyo dps46819
Record the voltages on the "VG"(anything labeled VGxx) test points beneath the AS15 chip
when the picture is bad vs good. Let us know the values. In table form, ie
VG01 - xx Volts
VG02 - xx Volts
and so on.Last edited by cliff_hootarski; 07-27-2016, 03:07 PM.Comment
Re: Sanyo dps46819
I can see the GAMMA DC Voltage test points VG1, ... VG22 but I cannot see ALL of them on the board, some may be under the stickers.Never stop learning
Re: Sanyo dps46819
I have to figure out how to fire this set up with the back removed, i cannot access the t-con board with everything hooked up.Comment
Re: Sanyo dps46819
Vg1 15.32
Vg2 11.47-11.61
Vg4 10.47
Vg6 10.23
Vg8 10.21
Vg10 8.76
Vg12 1.707
Vg13 7.53
Vg15 1.16
Vg17 5.27
Vg19 14.73
Vg21 13.56
Vghc 26.81
Vgl 5.992
Vgma 15.35
The chip in question is also extremely hot to the touch, and freeze spray seems to have no affect on its performance.Comment
Re: Sanyo dps46819
Thanks a million, i will report back once i get a replacement board, my soldering skills are good, but i don't think i could pull that chip off. Thanks cliff and budm, I hope to learn more from you in the future.Comment
Re: Sanyo dps46819
Can i ask how you can tell from those values that its bad? I ask so if i run into the problem again on another set i might be able to test it myself and know without having to ask again.Comment
Re: Sanyo dps46819
The voltages should be linear. Decreasing (or increasing) little by little.
Vg1 15.32
Vg2 11.47-11.61
Vg4 10.47
Vg6 10.23
Vg8 10.21
Vg10 8.76
Vg12 1.707 BAD
Vg13 7.53
Vg15 1.16 BAD
Vg17 5.27 BAD
Vg19 14.73
Vg21 13.56
Vghc 26.81
Vgl 5.992
Vgma 15.35Comment
Re: Sanyo dps46819
Put your values into this spreadsheet.
https://www.badcaps.net/forum/showth...ht=gamma+excelWilling to help but I'm no expert.Comment
by petobongoHi, i have a LG 26LV2500 , i turned on the TV and the colors are awful, most likely solarized issue, already replaced the flex cable between board and TCON and did a reset, none of that worked.
The mainboard is a EAX64280803.
Can someone help me?
Thank you in advance. -
by rouninHi everyone,
🛠 Original Issue
⚠️ New Problem: One USB-C Port Only Works in One Orientation... -
by ugamazingI have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre... -
by ahmarzoHave a acer laptop ex215-22 with motherboard part no daz8emb18a0 the issue is the battery gets drain overnight upto 25-30 percent even when switched off / shutdown.even after ssd is removed and laptop off with button the battery keeps draining.i have updated the bios but same issue have tried another new battery and the charging works fine only issue is battery is discharging when connected to motherboard in off condition.
Help me to diagnose this issue as there is no shortage in the inputs MOSFET -
by elmarkHP Pavilion 15-CW1002UA
S/N 5CD0251CBC
P/N 7KE54EA
Hello guys!
I have a strange issue with my laptop keyboard and I'm lost trying to detect what's wrong - the KB9028Q-C or the keyboard itself.
It powers on OK and has no other issues except the following:- CAPS LOCK does not work at all
- Fn button toggles Flight Mode
- When I press 't' or '5', it produces 't5', and when I press 'y' or '6', it produces 'y6'
- (with SHIFT pressed: 't%' and 'y^' respectively)
but when I press and hold...06-27-2025, 01:10 AM - Loading...
