TV LG 26LV2500 color issue, solarized image
  • petobongo
    • Jun 2014
    • Portugal
    Hi, i have a LG 26LV2500 , i turned on the TV and the colors are awful, most likely solarized issue, already replaced the flex cable between board and TCON and did a reset, none of that worked.
    The mainboard is a EAX64280803.
    Can someone help me?
    Thank you in advance.
  • petehall347
    • Jan 2015
    • 4439
    Re: TV LG 26LV2500 color issue, solarized image
    chip on tcon board .. freeze it to prove
    • petehall347
      • Jan 2015
      • 4439
      should have said the gamma ic chip
      • remmurdmd
        Vizio E65-E1 strange image issue
        by remmurdmd
        Hi everyone. First new thread here. I picked up a TV on the side of the road. It appears to function correctly with the exception of an image issue I'm unable to describe. I've searched for “double picture” and “double image” all over the web and all I get is repair videos for when the picture is blurry and the connections are getting interference between the display panels and the t-con board. I believe this is a t-con board issue, but I haven't found anything telling me conclusively that this is where my issue is. I'd appreciate any assistance you can provide. I live a pretty busy life...
        10-02-2022, 09:12 PM
      • Ancient1
        Strange LG TV issue : Image vertical lines in black screen
        by Ancient1
        Hi
        Asking for a friend.
        I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
        but here its the opposite !
        TV has new T-con = same issue
        A missing panel voltage would have global effect
        So , what should one do ? how can I find where the fault is ?
        Thanks !...
        02-05-2025, 03:37 PM
        HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
        This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
        09-12-2024, 02:20 PM
      • Jaime Morillo
        Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
        by Jaime Morillo
        Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
        The TV was stuck on the logo and I couldn't access the update menu.
        I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
        The image result was good, but the image is inverted.
        The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
        Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
        08-18-2025, 11:38 AM
      • reach7458
        philips 37pf8404 solarized image (changed as15f already)
        by reach7458
        I got here an philips 37pf8404 with a solarized image. image one
        First guess its a bad as15f. so I replaced it with another. Same issues
        So I replaced it again with a rm5101. Same issues
        Problem is that is projecting a solarized image irregularly. When I pull the hdmi cable and put it back all is okay for a undetermined time. It also helps if I change the input from one hdmi port and back.
        One thing thats weird and I don't remember if it was the case with the previous tvs I repaired.
        When the image is solarized it doesn't affect...
        08-03-2020, 08:27 AM
