Vizio SV422XVT - Standby light, no image, no sound.
  • What?
    • Aug 2010
    • 82
    Re: Vizio SV422XVT - Standby light, no image, no sound.
    I have checked ShopJimmy, ebay, the internet in general and no-one has this main board in stock or the only 2 sites I found it on wanted $180 american, go figure. So I am down to fix it myself or toss it, what a waste.
    • dick_barton
      • Aug 2015
      • 6642
      • Wales
      Originally posted by What?
      Holy Cow, I just found one of the resistors while I was cleaning up my work station. Actual reading is 110 ohms, that must be R50, but I have no way of knowing, sorry.
      Which two resistors did you lose. What numbers were they.
      You have R50 as 110 ohms and R48 as 94.8 ohms in an earlier post.
      • What?
        • Aug 2010
        • 82
        dick-barton, I lost R48 and R50 in the process of modifying the resistor network for the U7 voltage regulator replacement so it would work. The original VR was adjustable and the replacement I had on hand was a fixed output VR so the resistors had to be removed in order for the replacement VR to work correctly. Since the modification worked I don't need the resistors. Thanks for your response, this forum is awesome!
        • What?
          • Aug 2010
          • 82
          The TV has been plugged in for about an hour, I touched every IC on the board with a bare finger. The chips range from cold to very warm, none were HOT.
          • What?
            • Aug 2010
            • 82
            Well, budm, according to your troubleshooting guide, I guess the next step is to look for bad diodes and transistors in the DC/DC section on the main board.
            • What?
              • Aug 2010
              • 82
              I am not having much luck finding bad diodes or transistors, but, I found this big smd and if I looked up the numbers correctly it is a schottky barrier rectifier. I tested this with a Simpson 260 analog meter set on 10k ohms and I got a full swing of the needle with the probes in either direction. Red to cathode and black to anode or red to anode and black to cathode got the same dead short reading. Doesn't that mean a bad diode, even for a schottky? There is 1.28 vdc at cathode to gnd and 0.004 vdc anode to gnd.
              D155
              S020F
              SM540C
              • dick_barton
                • Aug 2015
                • 6642
                • Wales
                #27
                Without lifting the diode to check or having the circuit diagram, it could be that the diode is across a low value resistor or an inductor.
                • What?
                  • Aug 2010
                  • 82
                  BTW, for what ever it's worth, I am getting 2.18 vdc at all the switches and when I push the button the 2.18 goes through.
                  • What?
                    • Aug 2010
                    • 82
                    Ok, I will have to remove it and retest. I should have known that.
                    Thanks dick_barton.
                    • dick_barton
                      • Aug 2015
                      • 6642
                      • Wales
                      #30
                      Here's some info on that set.
                        Looking at the pictures of the board from SJ: http://www.shopjimmy.com/vizio-3642-...r-sv422xvt.htm
                        That D155 looks to be for the Buck converter circuit consisting of D155, L3, C25, U2.
                        What resistance do you get using lower Ohm scale.
                        • What?
                          • Aug 2010
                          • 82
                          Thanks!! dick_barton
                          • What?
                            • Aug 2010
                            • 82
                            budm,
                            At Rx1K = 275 ohms and 250 ohms
                            a reading on my Fluke digital is 290 and 298 ohms
                            • What?
                              • Aug 2010
                              • 82
                              budm, you amaze me, all I see on this board is a bunch of components but you look at a picture and tell me what different sections are for. You must have a lot of time on these boards.
                                Can you read the P/N of U2?
                                  BTW, check the resistance of D154 to see what you get, it is about the same setup as D155.
                                  • What?
                                    • Aug 2010
                                    • 82
                                    U2 is a DC/DC step-down regulator:
                                    M021
                                    G5684
                                    http://pdf1.alldatasheet.com/datashe...GMT/G5684.html
                                    • What?
                                      • Aug 2010
                                      • 82
                                      D154 : Simpson @ Rx100: Red on cathode 400 ohms, red on anode 70 ohms.
                                      Fluke set @ ohms: Red on cathode 468 ohms, red on anode 332 ohms
                                      • What?
                                        • Aug 2010
                                        • 82
                                        I was looking at the troubleshooting chart dick_barton sent to me, on the DC-DC converter trouble page at a check item that says "U5, U7 U88, U89 voltage is about 3.3v"
                                        U5 is 3.3v, I just made U7 2.5v (oops), U88 and U89 are both 0V
                                        Checking U50 because the chart said the voltage should be 1.2v with power on I got pins 1 thru 4 (source and gates) were 5v and pins 5 thru 8 (drains) were unstable dropping slowly from 5.12v to 0.745v jumping back up to 5.12v and dropping again over and over. U50 is a dual mosfet IC P06B03LVG
                                        • What?
                                          • Aug 2010
                                          • 82
                                          Budm,
                                          I don't think anything was damaged by the overvoltage on U7, I traced where U7 goes and it looks like it only goes to the ethernet connector, unless there are layers in the middle of this board. Then that would mean U7 has nothing to do with powering up this main board.
                                          • fharris1977
                                            Vizio D50u-D1 Dead Set No Standby
                                            by fharris1977
                                            Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                            12-28-2023, 10:25 AM
                                          • p-top
                                            Vizio, E60u-D3, no standby light, no ps_on
                                            by p-top
                                            Have vizio E60u-D3. No standby light. Have searched and read all D??u-D3 posts. posts with same symtoms fixed by new power supply, one guy needed back lights also.
                                            main boards are kinda spendy and, out of stock alot of places. i would like to fix my board.
                                            PS voltages
                                            1 VSNS -2mV
                                            2-5 LED-OUT -2mV
                                            6-10 GND -2mV
                                            11 +16VS 16.29V
                                            12 AC-DET 3.929V
                                            13PS-ON -3mV
                                            14 +16VS 16.29V
                                            15 +16VS 16.29V...
                                            11-27-2023, 10:44 AM
                                          • x_orange90_x
                                            Vizio E550i-A0 no power, no standby light
                                            by x_orange90_x
                                            I have a Vizio E550i-A0 that will not power on. It also does not display the standby light in the corner. I disconnected the main board cable to see if the backlights would light but they did not (maybe this is normal for this set?). I checked the voltages on the plug and they all read in mV or 0, so there's no voltage there. The fuses are ok, and the voltages of the 450v caps read about 160v. I see no visual damage on either the power supply or main board. I have read online that the main board is usually the culprit in this model, but not getting backlights with the main disconnected makes me...
                                            11-20-2023, 09:49 AM
                                          • SS454
                                            vizio e650i-a2 backlight flashes then turns off
                                            by SS454
                                            vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
                                            panel: au optronics T650HVN05.4
                                            72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
                                            link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
                                            Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
                                            https://www.shopjimmy.com/vizio-56-0...-power-supply/
                                            Vizio 55.75J01.001G (91.75J10.004G) Main Board...
                                            08-20-2020, 03:57 PM
                                          • tvguy12012012120
                                            by tvguy12012012120
                                            02-07-2025, 05:13 PM
