Panasonic SC Board - BAD 30F131 IGBTs
  • flocko
    • Nov 2012
    • 1121
    #61
    Re: Panasonic SC Board - BAD 30F131 IGBTs
    Strange I have used These Fairchild IGBTs in over 12 Panasonic board repairs over the last few weeks.and not had a problem. This is one I am repairing for a member on here. Could it be the other components you are useing or your technique
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      #62
      Is there any member in my country that wants to fix 2 for me? Lol
      • MICROTECHSERVICE
        • Jun 2016
        • 36
        • United Kingdom
        #63
        hi flocko i repair roughly 20 to 30 units a week all parts i use are mostly panasonic direct orignals other i sourced and are good only gt30f131 i get from various sources but now i go n choice get them direct from panasonic i just dont like selling my kits that have out of spec parts or fake,just not fair on techs spending time replacing bits then loud bang, back to oyur point i will give it another go on tnpa 5335 uses 3 gt30f131 on 1 bank se if it does the job thanks again flocko
        • flocko
          • Nov 2012
          • 1121
          #64
          That is not a problem, 20-30 units a week that is a lot of boards, that would be 120 30f131 IGBTs on there own that is a lot, and with your kits as well. I can see why you are looking for other parts to replace them. Hope it all works out for you
          • Moreno83
            • Jun 2014
            • 2008
            • The Netherlands
            #65
            Just repaired a 42VT30 yesterday and replaced all parts with the replacement parts and it worked perfectly. Got 6 blinks after repair , forgot to replace the IC , working as it should work.
            GT30 also works with same parts. ( I got them from mouser ).
            • MICROTECHSERVICE
              • Jun 2016
              • 36
              • United Kingdom
              #66
              fairchild mosfets do work lads must be something on the sn board but it did the trick slight underated mosfet i will wait till panasonic 30f131 get exausted then i will use these thanks a lot everyone
              • Moreno83
                • Jun 2014
                • 2008
                • The Netherlands
                #67
                Good job! Could have been a soldering issue that blew the board? Saw some sc boards lately that came from a uk seller from eBay. Don't know the name but the soldering looks awful to be honest.
                If you sell a reworked board , the board must look like "new" and not with IGBT's that are half soldered on the board or to much tin on the outside.
                • tvtimmy
                  • Mar 2015
                  • 1160
                  • usa
                  #68
                  My 30 pack of FGD4536TM for $15 finally showed up (19 day wait). They fixed both SC boards for my tc-p50s30's. They work great, run cooler, and are easy to solder on. Pretty good results for my first surface mount repair!
                  • tw2005
                    • Oct 2011
                    • 6458
                    Source of parts was? Cheap price.
                    • tvtimmy
                      • Mar 2015
                      • 1160
                      • usa
                      #70
                      The igbt's dont have the tm suffex after them. Here is the place on ebay. monitor-09(14490)
                      99.4% Positive Feedback
                      Member since 2009
                      • tw2005
                        • Oct 2011
                        • 6458
                        Member since 2009
                        the TM is not stamped on it, if they're working that's a good start
                        • Moreno83
                          • Jun 2014
                          • 2008
                          • The Netherlands
                          #72
                          I ordered also the FGD4536TM from China and got them at home. Was afraid to use them. Will try them on my next repair this teusday. Got 20 for $7
                          Look visually ok!
                          • tvtimmy
                            • Mar 2015
                            • 1160
                            • usa
                            #73
                            What else can FGD4536TM be subbed for?
                            Also, what will work in place of DG301,DG302.....
                            Last edited by tvtimmy; 09-19-2016, 04:12 PM. Reason: Forgot to put part number in
                            • tw2005
                              • Oct 2011
                              • 6458
                              Why not try them and see or even try a RJP30H2.
                              By the way. I tried yet another chinese source on Ebay and same deal the 30F131 blew taking out the RJP30H2. Contacted seller who said they'd refund if I destroyed them with images. Also said strange no one else had issue but I say strange I use real parts and my repair is good.
                              Looking at these ones I thought they may be ok but the outside surface is scratched up to disguise them. Another thing I have noticed is with the metal tab on the cut corners the originals have an exposed portion of copper where all these bad ones are tinned.
                              The RJP30H2 I got seem original and had no issues there and the cut corners have exposed copper like the originals.
                              • tvtimmy
                                • Mar 2015
                                • 1160
                                • usa
                                #75
                                I know they work for 30f131 ,I use them, and love them. I was just wondering if they will substitute for other bits.
                                Also , what can be used in place of th DG301, 302, etc.......
                                • tw2005
                                  • Oct 2011
                                  • 6458
                                  Like I said, try them or RJP30H2. I just look at the ratings and give them a go.
                                  • tvtimmy
                                    • Mar 2015
                                    • 1160
                                    • usa
                                    #77
                                    I ordered some RJP30H2 from ebay and guess what......they are fake too.
                                    • tw2005
                                      • Oct 2011
                                      • 6458
                                      Did they fail? Any pictures particularly the cut corners of the metal tab
                                      • tvtimmy
                                        • Mar 2015
                                        • 1160
                                        • usa
                                        #79
                                        I will put up a pic tomorrow. The ones I installed failed. I checked the ones I had left in diode mode, every combination of legs, and they all read O.L. (open).
                                        Maybe I should avoid the "Deals", in country and abroad, and pay the crazy high prices for a few and see how they work.
                                        I have more "bits" that I have ordered as well that were shit. I will post pics of them as well.
                                        • tw2005
                                          • Oct 2011
                                          • 6458
                                          The ones I've been getting of a Chinese ebayer have been fine and ive been keeping the originals and they look legit under magnification. The same was not the case for the Toshiba bits.
                                          • m1ch43lzm
                                            by m1ch43lzm
                                            05-12-2025, 08:37 PM
                                            by sam_sam_sam
                                            After all of...
                                            07-13-2024, 08:14 PM
                                          • canadaboy25
                                            Panasonic TC-P54VT25 No image. A or D board?
                                            by canadaboy25
                                            I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
                                            The panel is primed as there is a slight glow from the entire panel. This means the problem should be logic related. The service manual also confirms this and recommends replacing the A or the D board.
                                            I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
                                            01-17-2021, 01:06 AM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
