Panasonic SC Board - BAD 30F131 IGBTs
+ More Options
Posts
  • N9ZN-Extra
    • Apr 2014
    • 22
    Re: Panasonic SC Board - BAD 30F131 IGBTs
    Originally posted by tw2005
    Here's a package comparison between the FGD4536 (Dpak) & 30F131 (D2pak)
    Where did the image go? DG301 and 30F131 both are in question here.
    I wonder which PCB(s) is/are available as great LOW-COST doner board(s) for both of these IGBT's, any ideas?
    • Moreno83
      • Jun 2014
      • 2008
      • The Netherlands
      #142
      Just get a few SS boards. They have all the parts needed.
      • tvtimmy
        • Mar 2015
        • 1160
        • usa
        #143
        He could also use FGD4536 for both.
        • Whippet
          • Nov 2023
          Hi. I have a Panasonic Plasma 55" VT30, that has blown GT30F131 components on the SC PCB, Pt No: TNPA5335 BA. It was repaired once previously and has worked for over two years. Now they have popped again. Note: The PCB mounting screws were still tight at PCB removal. It seems that the GT30F131 are no longer available and also that the FGD4536TM substitutes are also no longer available.
          What is the currently available substitute component for the original GT30F131, that are not fake and good quality?
          I can obtain IGB50N65S5 from a local electronics supplier, for reasonable price, but can anyone comment on suitability as replacement for GT30F131?
          This is a really nice panel and I don't want to dispose it into landfill.
          Thanks in advance for any assistance.
          Cheers
          • Tinysprings
            • Jul 2024
            • France
            #145
            Hello Whippet, I would wonder about max switching frequency rated @20kHz max.
            Don't know switching freq of panel drive, but has to be at a few hundred kHz.
            Best
            • Tynan Dill
              by Tynan Dill
              Assuming...
              11-22-2024, 01:46 PM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
              After all of...
              07-13-2024, 08:14 PM
            • canadaboy25
              Panasonic TC-P54VT25 No image. A or D board?
              by canadaboy25
              I have a Panasonic TC-P54VT25 that will power on and prime the display but there is no image at all.
              I have tried to get the TV to display the test sequence but I have been unable to and I don't even know if this TV has a test sequence or not. I tried following tom66's instructions in post #3 on this thread https://www.badcaps.net/forum/showthread.php?t=26790. There was...
              01-17-2021, 01:06 AM
            • stecos
              Panasonic Plasma main board repair (ST30 GT30 VT30 ST50 GT50 VT50),LED with 3 blincks
              by stecos
              Hi everyone!
              I happened several times, in the search for help from the web, to consult this very interesting forum.
              So I decided to sign up and I intend to participate actively by making available my knowledge and experience on the subject, I'm a new user but at the same time I'm old in the sense that I have 4 decades of experience in repairing and designing electronics but above all I'm a great passionate about the subject.
              Having said that I come to the gist of my post on the forum as the title suggests.
              For my passion for technology I'm now collecting several...
              11-28-2022, 11:39 AM
