Lg 55LM6700 steady backlight no on screen display, pic, or sound
  • snake91876
    • Feb 2013
    • 236
    I have a LG 55lm6700 when I press power turns on like normal with a steady backlight. I have no onscreen display , pic , or sound. Below are the boards.
    Re: Lg 55LM6700 steady backlight no on screen display, pic, or sound
    Do you know the history of this TV?
    It uses one of those tab bonding board on the bottom edge of the panel which gets damaged when people spray cleaning fluid on the screen.
    Fuse on the T-CON has 12VdC on both ends with ref. to GND?
    • snake91876
      • Feb 2013
      • 236
      I don't know any history I got it from a guy at a recycling center
      • snake91876
        • Feb 2013
        • 236
        TV has no tcon, 2 cables go straight from main board
          LCD panel with integrated T-CON then, so you will have to get the metal bezel of the LCD panel off to get to the T-CON to check the fuse.
          • snake91876
            • Feb 2013
            • 236
            It's got two cables going to two small boards on bottom of panel are those tcon or is there a separate one.
              Those are the boards.
              What is the LCD panel model so we can look up the spec sheet for it?
              • snake91876
                • Feb 2013
                • 236
                Here's pic of panel sticker
                  check to see if you get VDD at both LVDS cables to the LCD panel, you can try probing them on the main board side, at least one of those pin should show 16Vdc (typ.)
                  • jabase
                    • Jun 2016
                    • 7
                    scope the lines of the LVDS to see if there is video going to the panel. That will tell you if you have panel or main board issue..
                    • snake91876
                      • Feb 2013
                      • 236
                      Well bad news guys I didn't follow instructions and tried probing at panel pins and shorted something. I have lines in picture now vertically everywhere. I guess this panel is toast.
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • Audeze
                        Sony XBR-75X950G seems dead with a black screen but backlight and sound is working and no blinking red lights
                        by Audeze
                        I have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
                        Does...
                        10-06-2024, 08:54 PM
                      • HTR-Informatique
                        by HTR-Informatique
                        02-09-2025, 06:51 AM
                      • totof
                        LG 43UF640V backlight good but black screen and no sound
                        by totof
                        Good morning.
                        I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
                        I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
                        In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
                        HVDD : 7,28...
                        04-13-2024, 11:37 PM
                      • frannyjunk
                        Hisense 40H4F no backlight but turns off after splash screen
                        by frannyjunk
                        So I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
                        TIA.
                        09-24-2025, 10:59 AM
