I have a LG 55lm6700 when I press power turns on like normal with a steady backlight. I have no onscreen display , pic , or sound. Below are the boards.
Lg 55LM6700 steady backlight no on screen display, pic, or sound
Tags: None
Re: Lg 55LM6700 steady backlight no on screen display, pic, or sound
Do you know the history of this TV?
It uses one of those tab bonding board on the bottom edge of the panel which gets damaged when people spray cleaning fluid on the screen.
Fuse on the T-CON has 12VdC on both ends with ref. to GND?Never stop learning
http://www.badcaps.net/forum/showthread.php?t=24809 -
I don't know any history I got it from a guy at a recycling centerComment
TV has no tcon, 2 cables go straight from main boardComment
It's got two cables going to two small boards on bottom of panel are those tcon or is there a separate one.Comment
Those are the boards.
What is the LCD panel model so we can look up the spec sheet for it?Last edited by budm; 06-17-2016, 08:37 PM.Never stop learning
check to see if you get VDD at both LVDS cables to the LCD panel, you can try probing them on the main board side, at least one of those pin should show 16Vdc (typ.)Attached FilesNever stop learning
Well bad news guys I didn't follow instructions and tried probing at panel pins and shorted something. I have lines in picture now vertically everywhere. I guess this panel is toast.Comment
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by AudezeI have a 2019 75" x950g, and while playing a movie, the screen suddenly went dark in a weird way, where it faded towards one corner into being fully black. Now the TV turns on, and the backlight comes on, but there is nothing displayed except black. Sound still comes through the TV speakers, and i have tried doing a hard reset using the volume - and power buttons while plugging the display back in, but it did not fix it. I can confirm that pressing buttons on my remote is still doing "something" because I'm hearing sound still, even though the screen is black.
Does... -
I also had corrosion/oxidation on the... -
by totofGood morning.
I have a problem with my LG Smart 43UF640V TV. It starts, the backlight comes on but nothing is displayed on the screen and there is no sound.
I thought it was a TCon problem and ran various tests. If I disconnect one or the other of the cables from the tcon to the panel then the screen is white on the side where the cable is disconnected and black on the other side. If the two cables are disconnected the screen is completely black.
In the 4 configurations I measure exactly the same voltages on the tcon card (model V15 43UHD TM120 Ver0.4) :
HVDD : 7,28... -
by frannyjunkSo I have this Hisense tv where the backlight does not come on. But when it is turned on, when I shine a flashlight on the screen, I can clearly see the splash screen then it turns off. I looked at the mainboard and was expecting to see bulged capacitors, but they all look fine. I unplugged the backlight from the mainboard, and get the same symptoms (i.e. no backlight, dark splash screen then just a black screen). Is this just a backlight issues? Do Hisense tvs turn off by itself if the backlights are unplugged or are bad? Or is this a mainboard issue?
TIA. - Loading...
