Help me identify this capacito/resistor
  • Trueburton
    • Jun 2016
    • 49
    Attached is a MC201 board from Panny TH50PZ85U. Circled in red is the item i need help with. It dislodged itself during soldering and was lost. Need to replace but not sure what to replace it with. Any help is appreciated.
    PS dont mind the poor soldering of the ceramic capacitor on the left, It has been cleaned up since.
  • Trueburton
    • Jun 2016
    • 49
    Re: Help me identify this capacito/resistor
    Anyone?
    • vinceroger69
      • Mar 2012
      • 6714
      Not sure if you have tried but maybe try what i suggested in your other thread have look on ebay theres a few compays who repair these mc201 mc301 and send them a question and ask them for the value and size they can only say no to you no harm in asking or even try the company you got your repair kits from they may have a board they can check for you etc.
      • Trueburton
        • Jun 2016
        • 49
        No luck yet with that, thanks though
          • 31072
          get a datasheet for the chip, the circuit is probably close to the example you often get in the datasheet
          • R_J
            • 9553
            Check on that power supply board for another module, I know some of the panasonic power supplies did use two
            I just checked the manual and that board only has the one, Must have been thinking of a different power board
            Looks like its off pin 19 SD shut-down input but does notr list a value for the resistor
            • Trueburton
              • Jun 2016
              • 49
              There has to be somewhere it is listed or way to check it. Isn't there?
              • Trueburton
                • Jun 2016
                • 49
                Here is a better picture. I have searched for a datasheet but cannot find anything on this. Please help.
                • fzabkar
                  • Mar 2009
                  • 772
                  What are the part markings on the IC?
                  Edit: Is this it?
                  • jiroy
                    • Jun 2016
                    • 2416
                    • Lebanon
                    Yes , it is ..
                    • Trueburton
                      • Jun 2016
                      • 49
                      That's for the IC but not for the main board it's attached to unless I'm reading it wrong
                      • sordids999
                        • May 2013
                        • 2155
                        http://www.ebay.co.uk/itm/Panasonic-...MAAOSwstxU7M9T
                        • Trueburton
                          • Jun 2016
                          • 49
                          Are you suggesting I buy a new board?
                            • 31072
                            what about the part you knocked off that you didnt circle?
                            • Trueburton
                              • Jun 2016
                              • 49
                              uh oh, where?
                              keep in mind, this is the 201 chip, The 301 is the one im missing parts for. Just easier to show locations on this one.
                                • 31072
                                here
                                • vinceroger69
                                  • Mar 2012
                                  • 6714
                                  stj i think your circle is where the original 1uf cap should be ive done two of these set now i solder the cap onto the pcb pads after removal of the old smd one it looks like hes soldered the new one on to the ic legs but in the top red circle is something missing?
                                  • fzabkar
                                    • Mar 2009
                                    • 772
                                    There is an application diagram in the datasheet. Why don't you spend a little time to trace your circuit? Then we may be able to calculate the value of the missing component.
                                    • Trueburton
                                      • Jun 2016
                                      • 49
                                      I'm sorry but im not exactly sure how to do that. Any help?
                                      • Trueburton
                                        • Jun 2016
                                        • 49
                                        Also, I'm not sure if it is a diode, resistor, or capacitor. Too small for any markings how can i find out?
                                        • gica69
                                          Need help to identify and to locate a 0.33 ohms fusible resistor for power supply
                                          by gica69
                                          I have a quad charger that is split into 4 separate sections and one section doesn’t charge anymore. I have located what I think is a thermistor and on the shrink tube it says 125 degrees C. I cut the shrink tube and it's a 33 ohms resistor. It measures a little less than 1/2 inch in length. I am including pictures of it. Please help me identify it. So, it should test at 0.4ohms and probably go up in resistance with the rise in temp. On the board it clearly says R for resistor. But it has to be a special one.
                                          Resistor shows orange range silver gold and green lines.
                                          Thanks in adv...
                                          07-21-2025, 09:49 PM
                                        • jinu_j
                                          by jinu_j
                                          Hi
                                          05-03-2025, 10:51 PM
                                        • mikey5791
                                          Need help to replace burned resistor in 350w atx psu
                                          by mikey5791
                                          Hi to all forum members,
                                          Got this faulty 350 watt atx psu dirt cheap from a local online seller as i am keen to use it as a learning tool to repair faulty power supply.
                                          The faulty part is quite obvious from the burn area near the 16pin KA7500 BD pwm. The fuse is still intact with good continuity.
                                          Upon power on ac, there is 5vdc standby power on cathode of diode D14 and about 10vdc on cathode of diode D13.(This should be the aux power to generate the 12v and 5v rail.)
                                          Initially i replace the two burned resistors near my marked red arrow to 200 ohm resistor...
                                          12-26-2024, 04:55 AM
                                        • MidnightRoller
                                          Can a resistor lose resistance after hot air?
                                          by MidnightRoller
                                          I am curious if a 0402 resistor could go from 43 ohm to 0. In electronics class and my experience a resistor can degrade and gain resistance all the way up to not being able to conduct at all. I have never heard of a resistor decreasing in resistance and becoming 0 ohm or a dead short… that's not the direction they fail… or so I thought.
                                          I was attempting to remove a wson8 chip on an iMac motherboard and it required a lot of heat, on one side of the chip were 3 0402 resistors that were very close. I popped the chip out unintentionally out of the tweezers and sent those resistors...
                                          02-02-2022, 11:46 PM
                                        • sikocan
                                          Identify resistor R802 PS4 Pro PSU
                                          by sikocan
                                          Hi team, can you help identify value of this resistor. From a PS4 Pro. PCB board model: N300A004L. Location of resistor is R802 as pictured....
                                          11-01-2022, 07:33 PM
