Element Elchw321 will not turn on
  • CapLeaker
    Leaking Member
    • 8070
    Re: Element Elchw321 will not turn on
    look for bad solders. try forcing the psu, or make sure BLon is there.
    • zape
      • Jul 2017
      • 176
      SW ON signal is persent, and I see no bad joints.
      Circled is the FET I replaced.
      Do you think it must match the one below?
      Which characteristics are important to match?
      • zape
        • Jul 2017
        • 176
        FAN7313 17 pin = 3.9v which means BCT/FT Fault-Voltage
        Any ideas how to troubleshoot this?
        I ordered original FETs already
        • R_J
          • 9535
          If the fets don't operate, I would think the ic detects a fault, likely SCP. It thinks there is a short circuit killing the voltage, so it shuts down.
          • CapLeaker
            Leaking Member
            • 8070
            If the original FET was shorted to the gate, look at the gate drive circuit.
            • zape
              • Jul 2017
              • 176
              Gate drive circuit looks OK
              And it turns on sometimes, the problem is intermittent.
              • zape
                • Jul 2017
                • 176
                It definitely detects a fault, which is indicated by high voltage on pin 17 (3.9v) When the backlight works it reads 1.2v
                How to narrow it down to the root cause?
                • CapLeaker
                  Leaking Member
                  • 8070
                  If I understand this correctly, most of the time the backlight on the TV does not turn on at all, but sometimes you have backlight. Do they stay on as long as you want or do they turn off by themselves after a while?
                  • zape
                    • Jul 2017
                    • 176
                    Yes, sometimes the backlight work just fine.
                    I didn't wait long, but it stayed for about two minutes. I also power cycled the TV several times in a row and it would also turn on every time.
                    But sometimes it would not turn on at all. I was not able to find any correlation yet and yes I did check visually for cracked solder joints and was not able to locate any.
                    I also verified that there are no significantly dark spots on the screen - the backlight seem to work OK when it turns on
                    • Unspun01
                      • Jun 2011
                      • 333
                      V803 and V804 appear to be working together as two halves of a resonant converter. If one failed (V803), you should replace with the same matching transistor (FDPF7N50U) , or replace BOTH V803 & V804 together with a PAIR of matching specs transistors.
                      There is a possibility that you are triggering protection because the gate driving circuitry is driving the two different transistors identically, but the transistors are performing differently and protection doesn't like it.
                      If you already replaced V803 with a 2SK3569, then I suggest you replace V804 with a 2SK3569 also (and keep the other FDPF7N50U for spare). These two transistors V803 and V804 should function as a pair, and should be matching specs.
                      also, double-check the diodes in your gate driving circuits. The fact that you accidentally triggered something by simply touching your probe leads means you may have a damaged component, or bad solder joint.
                      • zape
                        • Jul 2017
                        • 176
                        Yeah... I guess I'll wait for original FDPF7N50U to come and see if it fixes the problem.
                        • zape
                          • Jul 2017
                          • 176
                          FDPF7N50U fixed it
                          Thanks you all for your input
                          • R_J
                            • 9535
                            That's good to here, so it was just a mismatch of the two fets that caused the problem. Likely the different on resistance
                            • Unspun01
                              • Jun 2011
                              • 333
                              Glad to hear you fixed it.
                              • pajdek
                                Lenovo Y700-17ISK turn on and off
                                by pajdek
                                Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                09-20-2023, 02:49 AM
                              • RdeveLabs
                                MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                by RdeveLabs
                                To all the members here...
                                Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                05-05-2025, 04:59 AM
                              • robante15
                                Acer Aspire 4520 won't turn on after reboot
                                by robante15
                                Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                If I remove the...
                                04-06-2024, 06:50 PM
                              • masoksian
                                Dell latitude e7470 not turn on .power buton on off and Run Power problem
                                by masoksian
                                I am dealing with the problem of turning on and off my Dell e7470 notebook.
                                The battery charge light is solid white, I press the button, the power indicator and the light on the button are solid for 1-2 seconds and immediately turn off.
                                The system does not turn on, there is no post.
                                I removed the RAMs and changed them, changed the battery, RTC battery, AC adapter, removed them and waited, tried again, it does not turn on.
                                The problem continues in the same way.
                                I tried to turn on the Fn key, nothing came to the screen....
                                02-15-2025, 12:08 PM
                              • dqtech
                                lenovo x240 nm-a091 wont turn on
                                by dqtech
                                i got this laptop with no power issue....i flashed the bios and laptop can turn on and use normally....but when i shut it down and rest for few minute (2-3 minutes), it wont turn on....i have to flash bios again...any idea what is the problem?...when i shutdown and suddenly press power button to turn on, it will turn on normally....problem happen when i rest the laptop 2-3 minutes after shutdown, it will not turn on....i need to flash bios again
                                board number VIUX1 NM-A091 REV:1.0...
                                02-07-2024, 01:57 AM
