Sony KDL-65W850A Dead
  • Diah
    • Feb 2013
    • 6437
    Re: Sony KDL-65W850A Dead
    Originally posted by kevinm34232
    How do you know the size, I measured around 5mmx2mm
    yours measured wrong. do as you like.
    • anmol
      • Mar 2012
      • 73
      • India
      #122
      Right, main board problem first, but I replaced main board and had new problem with TV turning on then back off with flashing standby LED, but not a blink code or anything described in the SM. It flashed from green to amber over and over again.
      this is system software error
      when you replace main board you need to upgrade software
      try this.
      https://esupport.sony.com/US/p/model...d#/downloadTab
      Regards.
      • vinceroger69
        • Mar 2012
        • 6714
        • uk
        #123
        i cant find anything smd size wise that matches your measurements maybe get a cheap pair of digital calipers (ive just got a cheap ebay set ideal for measuring stuff like this.)
        • anmol
          • Mar 2012
          • 73
          • India
          #124
          try this.
          Regards.
          Sorry, some writing mistake by me.
          • Diah
            • Feb 2013
            • 6437
            i dont think its so complex issue to buy such stuff if he dont agree on my LEd type statement.. ... Metric primary School Rule enough too..LOL
            the long measurements should be done at the base as there are 2 pin at sides, and the wide from the top, this LED at this post are 7020 LOL
            • kevinm34232
              • May 2012
              • 1884
              I asked how you know the size of these LEDs that's all..
              • Diah
                • Feb 2013
                • 6437
                i see how do i know this size... before you has seen this strip for first time, i had changed all LEDs in total at 2 and half hours.
                • kevinm34232
                  • May 2012
                  • 1884
                  OK I have ordered some of these (the 7030 in 260mA, is that OK?)
                  http://www.aliexpress.com/snapshot/7...75837294490041
                  Next question. The LED strip is attached to a massive aluminum heatsink.. Making it difficult to remove a single LED. There are no screws holding it in.. What kind of adhesive are they using?
                  • Diah
                    • Feb 2013
                    • 6437
                    this seller i dont know and seem no one bought from him, use the one i listed as you can see the feedback of buyer.. and i do had 3 time ordered from them
                    if you are going only to replace the defect one, leave the strip at its place, just cut the defect one with cuter and clean the rest with yours soldering iron.
                    if you want to replace all you need to take the strip out its glued on the metal base. with glue film same to use Mobile Phone to glue screen thin double side glue film.
                    other tips, when you take out led, and clean it place, with shave plate make the base color print out and place solder at it from both side, then place your new LED as it most.. and with Iron just heat the soldering try dont touch the LED sides. this is best methode as you still have space between each LEDs
                    • kevinm34232
                      • May 2012
                      • 1884
                      Not sure exactly what you mean, place solder on the pad on the outside edges of the where the LED would sit? Then heat up the solder when you put the LED in between?
                      I feel like the giant heatsink is the problem, I tried applying hot air on the bad LED with Kapton tape around the others, and I could not get it to come off without damaging the LED and possibly the board...
                      I will try what you said.
                      • kevinm34232
                        • May 2012
                        • 1884
                        Welp the 7030 is way too big... It's more like 5cm x 2cm... But can't find that size..
                        • kevinm34232
                          • May 2012
                          • 1884
                          Diah, do you know where I can get these LEDs?
                          • Diah
                            • Feb 2013
                            • 6437
                            there are no 5x2 LED, i wounder why its look yours different 6x2 !!!
                            however you dont need to worry as you still can use 7x3. take look on the photo
                            1- the red Line you need to separate the solder between the pad and the middle chassis pad
                            2- the blue area with shave plate clean it and add solder to it on both side, after you fit the 7x3 LED at its place just heat the solders from both side, i suggest you to use soldering iron head thin one such 0.5mm or less, then you are fine.
                            other photo of here i have KDL 65W95 you can see the LED 7x2 and beside it 7x3.
                            • kevinm34232
                              • May 2012
                              • 1884
                              I just measured with a digital caliper and they are indeed 5x2.. The actual LED case without the metal ends is around 4.6mm x 2mm.
                              • Diah
                                • Feb 2013
                                • 6437
                                interesting information thank you,,, so which brand of Panel bulid at yours set? ?
                                • Diah
                                  • Feb 2013
                                  • 6437
                                  could you listed the serial prints code of the strips to figure it thanks.
                                  • kevinm34232
                                    • May 2012
                                    • 1884
                                    I was unable to find anything from these #s..
                                      What is the LCD panel model number?
                                      • kevinm34232
                                        • May 2012
                                        • 1884
                                        Panel # SYV6532
                                        • Diah
                                          • Feb 2013
                                          • 6437
                                          Panel # SYV6532
                                          hmm AUO Panel. and the labels on the strips really look like just in house Ref use only, i searched over all and there are no 5x2 even at RGB LEDs. i suggest marking for us the defects LED on the strips and let Diy it best way to put on 7x3 as the first LED on the photo i marked it with color you will not face problem at it.
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mrsith
                                            Sony KDL-55W755C - Dead
                                            by mrsith
                                            Hello again lifesavers.
                                            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                            11-28-2022, 12:42 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
