Sony KDL-65W850A Dead
  • kevinm34232
    • May 2012
    • 1884
    Re: Sony KDL-65W850A Dead
    Originally posted by Diah
    1- the red Line you need to separate the solder between the pad and the middle chassis pad
    2- the blue area with shave plate clean it and add solder to it on both side, after you fit the 7x3 LED at its place just heat the solders from both side, i suggest you to use soldering iron head thin one such 0.5mm or less, then you are fine.
    Hi I'm not quite understanding what you're saying, probably due to translation.. Can you tell me what you're trying to explain again?
    • kevinm34232
      • May 2012
      • 1884
      These are so much bigger LOL. I got the one on the end to work, not sure about ones in the middle though..
      • kevinm34232
        • May 2012
        • 1884
        BTW I had trouble removing the LEDs without damage to the board, and using a hot air station I melted the lens slightly on this one, what temps are you using?
        • kevinm34232
          • May 2012
          • 1884
          Here's the problem, the pad on the bottom of the LED would overlap the + pad..
          I found some 6mmx3mm from China, it should help a little, but it will probably be another week or so.. I hope I remember how to put this TV back together!
          • kevinm34232
            • May 2012
            • 1884
            Well I finally got the correct LEDs and replaced the bad ones. They now all light up with the tester. But still same problem, TV flashes backlight LEDs for a split second then goes out, flashing continuous green/orange on the front LED. (a code I cannot find a descritption for)
            Now I'm wondering if it is a main board problem, considering the original one was bad. Is it possible this main board is bad, or an eeprom issue??
            • CapLeaker
              Leaking Member
              • Dec 2014
              • 8327
              if you measure each LED string, what voltages do you get?
              • Diah
                • Feb 2013
                • 6436
                i suspect your replacement MB. check it again same serial compare all No and letters.. its may belong to different size.
                • kevinm34232
                  • May 2012
                  • 1884
                  Each string is right around 70V. When one was out, it would be around 65-66V.
                  • kevinm34232
                    • May 2012
                    • 1884
                    Can anyone identify the NAND Flash or EEPROM that I can try swapping from the old board? Both boards have A1957649A on sticker.
                    • anmol
                      • Mar 2012
                      • 73
                      • India
                      #150
                      IC 1100 29F8G08ABACA is NAND Flash
                      It flashed from green to amber over and over again.
                      what about error of panel_id ?
                      WBR
                      • kevinm34232
                        • May 2012
                        • 1884
                        Yea I just saw that in the SM
                        Error of panel ID:
                        Green Blinking
                        Orange
                        Blinking
                        Blinking:0.5sec On / 0.5sec
                        Off
                        So main board may be from different panel? Will swap of IC1100 fix this?
                        • anmol
                          • Mar 2012
                          • 73
                          • India
                          #152
                          Error of panel ID:
                          Green Blinking
                          Orange
                          Blinking
                          Off
                          first try in service menu if there is panel id change option.
                          if you can not enter service menu, then try to update software with pen drive,
                          Regards.
                          • kevinm34232
                            • May 2012
                            • 1884
                            I don't think it will work, it clicks off in 1/2 a second then will not turn back on til unplugged. I am not sure I can find the software either.
                            Will switching that IC work if not?
                            • Diah
                              • Feb 2013
                              • 6436
                              i suspect your replacement MB..... its may belong to different size.
                              you cant put the TV in stand by mode?
                              if it refuse to go stand by then you are not able to edit service menu.
                              best way to try changed the IC. give try, but at end you need also to rewrite the firmware
                              • kevinm34232
                                • May 2012
                                • 1884
                                I can get it in standby mode, but once I hit power it it flashes and goes to the flashing green/orange. What's the procedure for getting to the service menu?
                                • Diah
                                  • Feb 2013
                                  • 6436
                                  from stand by mode -
                                  service mode... Press “i+ (info)”, “5”, “Volume +” then power on
                                  first try to inter from stand by mode Self Diagnosis Display -Press “i+ (info)”, “5”, “Volume-” then “power on
                                  • anmol
                                    • Mar 2012
                                    • 73
                                    • India
                                    #157
                                    look at page 245 service manual.
                                    Regards.
                                    • kevinm34232
                                      • May 2012
                                      • 1884
                                      By standby condition, they mean just plugged in to power but TV off correct?
                                      • Diah
                                        • Feb 2013
                                        • 6436
                                        yes
                                        • kevinm34232
                                          • May 2012
                                          • 1884
                                          Unfortunately the panel is all taken apart, I want to make sure what's wrong before reassembling... Would swapping that IC resolve a panel ID error? Is there also an eeprom IC that could be the problem?
                                          • thstuff
                                            Sony OLED XR-77A80J - Initially dead, now 4 Flashes
                                            by thstuff
                                            A) TV initially dead
                                            B) On a hunch of a locked up Google OS, plugged in a USB memory stick with latest FW and plugged it in. It booted into the update screen, completed the update and restarted to Home screen.
                                            C) Was able to perform a Reset from Settings menu and completed out of box configuration.
                                            D) Ran a 4K screen saver demo for about 6 hours, then turned it off for the day. Did not notice any stripes, dead zones or other artifacts in the image.
                                            E) Powered back on and it now runs for a few minutes before relay clicks, screen goes blank, Main Board Red Digital Optical...
                                            12-26-2024, 09:10 PM
                                          • bohaboha
                                            SONY KDL-46R473A ALMOST DEAD NO STB
                                            by bohaboha
                                            Hello to everyone in this wonderful forum.
                                            I have this SONY LCD TV KDL_46R473a
                                            PSU GL5 APS350 :1-888-122- 12
                                            MAINBOARD FY13_EU IP-012C101-4010
                                            black screen ,no STB no life almost death.
                                            on PS all the required volts are present 394V on the main cap and those on cold side 12.41V,3.45 and 3.45 are on
                                            Also 3,5,and 12v are on.
                                            nothing happens if i disconnect the PSU from the mainboard as on Samsung because here i think the mainboard gives the signal to the ps.
                                            don't know what to do next all suggestions and advice are very welcome​...
                                            04-24-2025, 04:40 PM
                                          • Talyn
                                            Sony 55W905 dead
                                            by Talyn
                                            My Sony W905 started to turn itself off an on every few minutes and blinking 8 times red in standby. A few minutes later the tv was completely dead.
                                            I can only hear the click of the PSU when attaching/detaching the power cable. No standby LED.
                                            Any advice? Thanks!
                                            04-15-2024, 08:14 AM
                                          • mrsith
                                            Sony KDL-55W755C - Dead
                                            by mrsith
                                            Hello again lifesavers.
                                            I have a KDL-55W755c that came in dead - not even standby light going on. Tested the power supply - all correct. Tested the output pins on the Led driver board (in which the power cord plugs in) - all seemed fine.
                                            I got a service manual for this model and tested the DC/DC converter by checking voltages on selected components. Every voltage was present where it should be. Service manual says that in this case a "Muffin" replacement is needed. This is the moment where I got stuck as I wasn't able to Google my way through it - till this day I...
                                            11-28-2022, 12:42 PM
                                          • Carlos#2003%
                                            Schematic de una Sony VAIO PCG-41217u, Sony VPCSB45FL (MBX-237), 1p-0117j01-a012 mbx-237.
                                            by Carlos#2003%
                                            Buenas mi nombre es carlos me uni al foro porque estoy buscando el schematic de una sony vaio pcg-41217u otras formas de escribirlo son 1p-0117j01-a012 mbx-237 numero de placa revision 1.2 o Sony VPCSB (MBX-237), en fin me gustaria y ayudaria un monton si alguien me puede dar dichi svhematic para hacer las mediciones de una laptop de la mencionada anteriormente(Sony VAIO PCG-41217U) con el fin de repararla dejo de funcionar solo prende el led de la bateria al pulsar el boton de power el disco empiesa a hacer ruido de actividad pero los leds del frontas no reflejan acividad y no enciende la pantalla....
                                            02-15-2024, 07:52 PM
