RUNTK 5351TP No Picture Failure
  • ReeceyBurger123
    Never Give Up !
    • May 2014
    • 7325
    • Britain
    Got a 32" Samsung Smart Led Tv here a UE32F5300, the fault is so no picture backlight working but Lcd is not being driven. Uppon some testing and removing cables I was able to diagnose that the Tcon is at fault and the Lcd and motherboard are working ok.
    I found that on this Tcon IC200 which is a ISL9860 a QFN type DC-DC converter Ic. This chip is getting input voltages but is not outputting anything about 6MV at most. Its also burning hot so im guessing this is failed.
    Has anyone else seen this before on these Tcons ? Will replacing the IC likely fix this board ? I want to try and fix it as another board is £50 and I don't want to be spending that much but I know QFN is very hard to solder.
    Re: RUNTK 5351TP No Picture Failure
    None of the outputs showing any low resistance (due to bad loads)?
    • ReeceyBurger123
      Never Give Up !
      • May 2014
      • 7325
      • Britain
      No bud, the output of it tests fine across the Ic not so good. Certain its the Ic mate.
      • flocko
        • Nov 2012
        • 1121
        I reported these Sharp T.Con failing over a year ago on this model, and yes its is the IC replacing it will fix the problem
        • ReeceyBurger123
          Never Give Up !
          • May 2014
          • 7325
          • Britain
          Ahh cool, you got the link please flocky ?
          • flocko
            • Nov 2012
            • 1121
            I dont know were it is sorry? i think some of the older post have been lost with the last site update, could well have been 2-3years ago thinking about it. I repaired one and remember the ICs were very hard to get seated right, then someone got hold of some new boards that were selling on ebay for about £60-70 so used them after to save me the problem of fitting the ICs. not had one in for a very long time. Try replacing the IC worth a shot if i could do it you should be able to
            • victor_cj
              • May 2015
              • 90
              • Romania
              I fixed this model UE32F5300 with RUNTK 5351TP many times, i had ISL98602IRAAZ faulty or ISL98602IRAAZ and KL5T3067 faulty, but there have been cases like the one in the link: http://www.elforum.ro/topic/114908-d...e32f5500awxxh/
              use google translate it is in Romanian.
              The art of fighting without fighting
              • ReeceyBurger123
                Never Give Up !
                • May 2014
                • 7325
                • Britain
                The first part of any repair is to remove the faulty part. Used hot air and heated under the Pcb due to small SMD caps and resistors on the top, they could have been blown off by the air. Chip now desoldered just to wait on the new one.
                • ReeceyBurger123
                  Never Give Up !
                  • May 2014
                  • 7325
                  • Britain
                  Ok thanks
                    How many minutes did it take you to remove that IC? Very clean job! and at only 330c?
                    • ReeceyBurger123
                      Never Give Up !
                      • May 2014
                      • 7325
                      • Britain
                      Cheers Bud, also yes 330c for about 2mins or so. I used some generic gel flux and heated from the bottom of the board. I then manipulated it with tweezers after heating for a min, when it it moved I knew the solder was molten and lifted the Ic off being careful not to knock the little Smd parts.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        I will not be cleaning the solder off any of the pads and will be reusing it for the replacement Ic as the solder left is perfect for the replacement.
                        • ReeceyBurger123
                          Never Give Up !
                          • May 2014
                          • 7325
                          • Britain
                          You ever worked on QFN bud ?
                            No, but last week I replaced the AS19 with exposed pad, I heat up the area at 200c for about 2 minutes and then turn up the heat to 390~400c then the IC just slipped off. The hard one are the one with exposed pad.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              They are easy IMO, to put the new one on place Ic on top. Heat then the solder on the centre pads aligns the Ic perfect then solder the pins. I always use hot air to take AS15's off. QFN is going to be hard as no area for solder iron to make contact, but I will give it a shot only lost £1 on it so far.
                              • flocko
                                • Nov 2012
                                • 1121
                                That is just how i did it, lots of flux when you replace it, the ICs I got from China I think 5 for £3.00 were dull looking on the back (pads) so I cleaned them up to be a bit more solder friendly,and the use of a digital microscope also helps,I did mark the four corners before I removed the IC. I had a look though yesterday to see if I still had any of the ICs left. but think I remember giving them to a mate to repair a set he had in for a customer. anyway good luck with it. I am sure we will hear how it goes
                                • ReeceyBurger123
                                  Never Give Up !
                                  • May 2014
                                  • 7325
                                  • Britain
                                  Cheers mate, will keep you updated when it comes
                                  • angel-boy
                                    • 550
                                    • Romania
                                    i have a RUNTK 5351TP , i change the IC200, ISL, but still no image, the fuse is good, any ideea ?
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      The main processor can also fail, this is bga soldered.
                                      • angel-boy
                                        • 550
                                        • Romania
                                        and i should reball it ? i will try
                                        • Tr0ll
                                          by Tr0ll
                                          Original T-con:
                                          First replacement T-con:
                                          10-07-2023, 07:48 PM
                                        • npielawski
                                          MacBook Pro late 2016 (820-00239) with multiple failure modes.
                                          by npielawski
                                          I will just preface all this by saying that I have a fairly technical background but have never attempted SMD electronics diagnostics and repair before, I really like the idea and want to learn.
                                          I have a MacBook Pro late 2016 that died maybe four years ago. Over the course of 30 seconds, it got slower and stuttered, until it froze for a second and died. No click from the trackpad anymore, nothing. I started getting interested in electronics repair and decided to give it a shot, so I opened it, removed the battery (one cell was puffy), took out the motherboard and experimented with...
                                          10-15-2025, 01:53 AM
                                        • JJAAMM
                                          by JJAAMM
                                          Problem
                                          07-06-2023, 06:01 AM
                                        • TR103
                                          by TR103
                                          - it keeps rebooting
                                          01-22-2025, 04:12 PM
                                        • Mgiffune
                                          by Mgiffune
                                          06-09-2024, 10:28 AM
