RUNTK 5351TP No Picture Failure
  • jondoe
    • Nov 2016
    • 547
    Re: RUNTK 5351TP No Picture Failure
    I did try a temp sensor in the air flow, it was almost correct, but only very close to the exit of the nozzle, it dropped off quite quickly a cm or two away from the very tip.
    • Dannyx
      CertifiedAxhole
      • Aug 2016
      • 3912
      #62
      Of course that also depends of the station, the nozzle and other factors. The flux you're using also determines the ease with which an IC comes loose....some require significant heating before they finally break free, at least that's what I noticed through trial and error.
      Wattevah...
      • GEORGIO1980
        • Jan 2014
        • 7
        • 88836632859
        #63
        Hello,waking up this thread.
        i have the same board replaced Ic200 it works now but i have horizontal lines anyone can help???
        vgruk pharmacy
        • imran333
          • Apr 2012
          • 48
          • uk
          #64
          I got similar problem no picture but sound and backlight on and I replaced ISL986021RAAZ but still no luck, and I got 12v but all the rest of voltages are missing and next step I’ll try is disconnect from screen and check voltages, but hope someone can give me some advice ?
          • WhiteWolfHellas
            • Jun 2019
            • 95
            • Greece
            #65
            Hello, I replaced the ISL9860 and the TV works now. Should I change anything else on the board or is it ok to assemble the set and return to the customer?
            • Dannyx
              CertifiedAxhole
              • Aug 2016
              • 3912
              #66
              Well you got hella lucky. Good job. I'd keep it under testing for at least 1 full day....at least that's how I would personally do it - don't know about your terms and relationships with the customer...
              Wattevah...
              • WhiteWolfHellas
                • Jun 2019
                • 95
                • Greece
                #67
                Why do you mean I got hella lucky? A full day running? I got the TV running for almost 2 hours and it's OK.
                I also have another 40" Samsung that I replaced the ISL9860 and I kept for myself and it's been working for 2 years now.
                • Dannyx
                  CertifiedAxhole
                  • Aug 2016
                  • 3912
                  #68
                  I wasn't as lucky to get it going by replacing the ISL unfortunately, so that's why Depending on how impatient the client was to get it back, I too would sometimes let stuff run for only a few hours and very rarely had issues. Sometimes something like a backlight LED would die again, but that's about all I can remember....
                  Wattevah...
                  • WhiteWolfHellas
                    • Jun 2019
                    • 95
                    • Greece
                    #69
                    In my opinion, it is the easiest ic I have ever replaced. Way easier than ΤΗΕ AS15.
                    Anyway, the TV has been on for several hours since yesterday and no problem so far.
                    • Dannyx
                      CertifiedAxhole
                      • Aug 2016
                      • 3912
                      #70
                      Good job
                      Wattevah...
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
                      • TR103
                        by TR103
                        - it keeps rebooting
                        01-22-2025, 04:12 PM
                      • Mgiffune
                        by Mgiffune
                        06-09-2024, 10:28 AM
                      • CyberPhoenix
                        Issue with picture quality of Sony bravia TV
                        by CyberPhoenix
                        Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                        01-22-2024, 02:08 AM
