Vizio VP422 won't turn on.
  • dick_barton
    • Aug 2015
    • 6642
    • Wales
    Re: Vizio VP422 won't turn on.
    Hello Budm, I think I may have things backwards. Re-reading the posts #9 the PS_ON is 4.8V when the mainboard is disconnected.
    It may have to be taken low not high as I've suggested to activate the other supplies.
    Your thoughts please.
    • Malachi
      • Dec 2015
      • 1077
      • Usa
      Both fuses were good when I first started, that's the first thing I always check. It was the only thing I knew how to do when I started doing this.
      Now F8201 is blown.
      I just replaced it.
        I think so too that is the case for these Plasma power supply board is active low for PS-ON, and active HIGH for Vs I believe. I think there are many threads for this board on B.C.
        https://www.badcaps.net/forum/search...archid=6381299
        Blown fuse is then another problem to solve.
        • Malachi
          • Dec 2015
          • 1077
          • Usa
          Originally posted by budm
          Did you hear the two relays click when using the resistor to force on?
          You also need command signals on the CN8002: VS_ON, RELAY_S???
          I get 5.1v on those 2 budm.
            https://www.badcaps.net/forum/showth...o+VP422HDTV10A
            Post 9.
            • Malachi
              • Dec 2015
              • 1077
              • Usa
              #26
              I guess it's time to take the psu out and check the voltage on the caps that dick suggested?
                See post 25.
                • Malachi
                  • Dec 2015
                  • 1077
                  • Usa
                  #28
                  I read that thread budm but my Vizio logo never turns white.
                  I did a forum search before posting. I also get a lot less Voltage reading than others with the same model in other threads?
                  Did I do the resister thing wrong?
                  • Malachi
                    • Dec 2015
                    • 1077
                    • Usa
                    #29
                    Bad Ysus?
                    • Malachi
                      • Dec 2015
                      • 1077
                      • Usa
                      #30
                      See post 9 of that thread? I don't have any of those voltages.
                      I can't turn the tv on, so voltages stay the same.
                      • Malachi
                        • Dec 2015
                        • 1077
                        • Usa
                        #31
                        Originally posted by dick_barton
                        So there's definately no change when you connect 5VSB to PS_ON.
                        What is the voltage across the large capacitors C8103 & C8104. Its on the hot side of the mains supply so be very careful. Use your meter set to 600V and measure across the two pins of each of the capacitors.
                        I took the psu out of the tv. Laying upside down on a piece of cardboard. Plugged it in and measured each capacitor, voltage steadily climbing. After a few minutes I had less than 0.2V. Unless I'm reading my meter wrong.
                        • Malachi
                          • Dec 2015
                          • 1077
                          • Usa
                          #32
                          The capacitance is about 446uf on each, in circuit.
                          Fuse F8201 blew again.
                          • dick_barton
                            • Aug 2015
                            • 6642
                            • Wales
                            #33
                            That explains why you had no voltage on the caps. Why is the fuse is blowing? Can you see anything amiss on the board because that was not your original problem.
                            • Malachi
                              • Dec 2015
                              • 1077
                              • Usa
                              #34
                              I couldn't tell anything visually unusual.
                              • Malachi
                                • Dec 2015
                                • 1077
                                • Usa
                                #35
                                Receey, help me diagnose this psu before I start throwing parts at it.
                                What would make the fuse blow.
                                Also what kind of fuses are these? It's 4a 250v. I know there are slow blow and fast blow.
                                How do you tell the difference?
                                • Malachi
                                  • Dec 2015
                                  • 1077
                                  • Usa
                                  #36
                                  I checked some of the 3 legged components that are screwed to the heat sinks. With my meter in diode mode.
                                  With the diodes, when I touch the two outer legs the meter beeps. When touching the middle one and an outside one, it doesn't beep.
                                  I also tested other 3 legged ones I'm not sure what they are called.
                                  They are labeled Q8101, Q8102, Q8103, Q8201 and Q8202 none of them beep. This is all in circuit.
                                    That fuse feeds many parts.
                                    http://www.shopjimmy.com/vizio-0940-...-pdp42-09.htm#
                                    Pictures provided by shopjimmy.
                                    • Malachi
                                      • Dec 2015
                                      • 1077
                                      • Usa
                                      #38
                                      But I can't keep replacing them with out figuring out why the blow.
                                      I had already checked shopjimmy. It's the first place I go.
                                      What kind of fuse is that that I listed? I can buy a dozen. Lol
                                      I did trace where the fuse goes to in the back but don't really know what to look for.
                                        'But I can't keep replacing them with out figuring out why the blow.'
                                        But you already find the shorted out components? Which one?
                                        'They are labeled Q8191, Q8102, Q8103, Q8201 and Q8202 none of them beep"
                                        BTW, the meter will beep even if the resistance is as high as 100 Ohms on some meter. That is why I use Ohm mode to look for shorts or very low Ohm reading.
                                        • Malachi
                                          • Dec 2015
                                          • 1077
                                          • Usa
                                          #40
                                          So that means they are shorted?
                                          What are those? Can I buy them from digikey?
                                          • Mulp
                                            VIZIO M65-C1 Does Not Turn On
                                            by Mulp
                                            Hi All,
                                            I am having an issue with my Vizio M65-C1 where it does not turn on. When I plug it in the stand by light on bottom left of screen turns on (white) then fades away. If I press the power button it turn back on and then fades until it is super dim.
                                            When I remove cover, there are no illuminated leds on the main board, I've seen others with a red/blue led that turns on.
                                            I've done some research and what is interesting is my voltages all seem slightly different from other people. For example +5/3.5v is 3.48V when on which is different from others on here....
                                            01-13-2024, 09:57 PM
                                          • Noah Glasse
                                            LG 50PK590 - three clicks and steady red light, won't turn on.
                                            by Noah Glasse
                                            I've got a LG 50PK590 plasma TV which upon plugging in will click three times and the red LED in the corner will come on and stay on, the TV however doesn't come on (no humming, sound, video, etc.) and using the touch controls or the remote does nothing. On exceptionally odd occasions, the TV will come on and work normally when plugged in and will last about 5 minutes before going back to off and unresponsive.
                                            I've got the back off of it and none of the caps stand out as visibly buggered, I've also tested the three resistors in the corner of the power board which...
                                            02-24-2025, 07:23 AM
                                          • pajdek
                                            Lenovo Y700-17ISK turn on and off
                                            by pajdek
                                            Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                            09-20-2023, 02:49 AM
                                          • RdeveLabs
                                            MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                            by RdeveLabs
                                            To all the members here...
                                            Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                            So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                            05-05-2025, 04:59 AM
                                          • robante15
                                            Acer Aspire 4520 won't turn on after reboot
                                            by robante15
                                            Hello, I have an Acer Aspire 4520 from a couple of decades ago and I want to repair it solely for nostalgia.
                                            It happens that when I turn it on after having been disconnected for a long time, it turns on without problems, it tells me that the BIOS has been reset and that it will load the factory settings, if I tell it to continue, the computer turns on and everything works fine.
                                            The moment I turn it off and want to turn it back on a second time, or restart it and try to start it again, it no longer gives an image, and it no longer responds.
                                            If I remove the...
                                            04-06-2024, 06:50 PM
