Emerson LF501EM4F turn on then off.
  • SLK001
    • May 2014
    • 264
    Re: Emerson LF501EM4F turn on then off.
    Take a power supply dialed to 3 volts. Clip a short piece of thin wire (~24 ga) to each lead and slide the wire under the lens, making contact on each end of the LED. You will have to guess on which side is positive and negative and what is the orientation of the diode. However, finding that is pretty easy and quick. Once one diode lights up, proceed down the strip, marking all those that do NOT light up.
      Be careful when testing LED without current limiter power supply if you apply the Voltage to wrong terminal of the LED that has internal protection diode.
      https://www.badcaps.net/forum/showth...996#post656996
      You can see what happen by having Amp meter connected in series with power source.
      • SLK001
        • May 2014
        • 264
        You can probe for which terminal is which by using your ohmmeter. Touch one lead to the (+) terminal on the connector and use the other to find out which side of the LED is the anode.
        Since there may be a protection diode on the chip, you are looking for a zero voltage drop (or close to it).
        • erickeri1234
          • May 2013
          • 98
          • usa
          #64
          Well I do know one strip of L.E.D'S are bad do I really need to test them?
          I did find a set on ebay. But they are Samsung and mine are LG. but I would change them all out to the Samsung one's. The auction does say they are from LF501EM4F.
          Would I have a problem if I changed them all?
          • SLK001
            • May 2014
            • 264
            You have to match the polarity of the LED you select with the polarity of the pad. Samsung LEDs are mostly CATHODE on the large pad. LG LEDs are mostly ANODE on the large pad.
            If you don't want to attempt a component level repair, then just buy the strips. I will probably cost you ~$60. If you attempt a component repair, the LEDs will cost you <$10.
            It's up to you.
            • erickeri1234
              • May 2013
              • 98
              • usa
              #66
              O i can repair the LEDS! I didn't know Ithat was possible. Yes most definitely repair it.
              • SLK001
                • May 2014
                • 264
                Is the photo from your set? If so, how did you get it to light?
                Since the LED string is a series circuit, the LED marked "B" would have had to shorted out - a rare occurance.
                Anyway, use a hair dryer to soften the glue on the lens, then slide a slot screwdriver under the lens and pop it off. Remove as much of the glue as you can while it is still soft.
                Take good high resolution photos of the LED and post them here.
                • erickeri1234
                  • May 2013
                  • 98
                  • usa
                  #68
                  Yea the photo is from my set. Sometimes it doesn't come on I have to unplug and plug it back in for it to come on. When I does 10 or 15 seconds later that one led will light up too. But I do have to unplug one of the other good strip for it to work if not the lights go crazy on off on off on off.
                  • erickeri1234
                    • May 2013
                    • 98
                    • usa
                    #69
                    I'm guessing the black stuff is the glue!
                    But I got it off.
                    Here is a picture
                    • SLK001
                      • May 2014
                      • 264
                      Measure the LED's dimensions with a set of calipers (in MM) while still on the board. It looks like the big pad is going to be an ANODE. They look like LG 100LM series.
                      It's best to remove the LED with two soldering irons. Do you have two?
                      First, use the hair dryer to heat the board to around 150F. Apply excess 63/37 solder to the two pads, then, with one iron on one side and one iron on the other side, melt the solder and using the two irons as one, slide the LED off the pad and onto the white area. Take a GOOD picture once this is completed.
                        This is how I remove the old LEDs:
                        https://www.badcaps.net/forum/showth...053#post657053
                        • Trent
                          • May 2016
                          Just started having this same issue. The logo, the long start, the speakers popping abrupt shutdown...
                          Thanks for taking pictures! About to open mine up.
                          • CapLeaker
                            Leaking Member
                            • Dec 2014
                            • 8326
                            good luck!
                            • dick_barton
                              • Aug 2015
                              • 6643
                              • Wales
                              #74
                              Originally posted by budm
                              Very neat way to remove them. I'll have to remember this method.
                              • Trent
                                • May 2016
                                Well crap. Same symptoms - but after the painful effort of taking mine apart - all the LEDs work and are super bright. My issue is somewhere else.
                                I accidentally ripped the left-most ribbon off the LCD screen when removing it too. I'm officially in too deep. I plan to take pictures and start a different thread when I get things back together.
                                I read online that dark spots on PCB boards are common around resistors that put out a lot of heat - but I'm guessing that the power board needs to be replaced. All the capacitors look fine- but without pictures - I don't expect many replies. I'll get updates as soon as I can find a decent camera.
                                • hmendez86
                                  • Jun 2015
                                  • 344
                                  • united states
                                  #76
                                  did you replace the leds, all of them. i had the same problem i replace all leds strips and it works u need a old led tv get somes strips of leds and try to install them. your problem is there but you need to figure it out how to plug new leds from other tv.
                                  • waakye
                                    ASUS ROG G750JM turns with no image and turn it's off within 7 seconds
                                    by waakye
                                    I was giving this ASUS ROG G750JM that exhibit the following behavior:
                                    When you press the power button, the computer turns with no image and turn it's off within 7 seconds. The battery charges when I connect the AC power. I tried flashing the bios with the uSB method and pressing Ctrl + Home and I can see the bios upgrade on external monitor.
                                    My issue is the laptop doesn't stay on for a long time and turn itself off.
                                    Any lead on how to resolve this will be appreciated.
                                    I cannot boot in windows and no liquid damage.
                                    Thanks in advance.
                                    09-13-2024, 08:10 PM
                                  • gabrielA7
                                    IMAC A1418 / MB: 820-00430-a / does not turn on, Lights 3 of the 4 LEDs and turns off.
                                    by gabrielA7
                                    Does not turn on, lights 3 of the 4 LEDs and turns off and stays like this, presses the power and repeats.
                                    I saw that the room LED lights up only when the screen is connected, so quiet.
                                    We have all the power supplies, even processor, 1.8V
                                    One thing I found strange, it has a very low resistance in the Vcore is giving 1 Ohm , work with notes and such, I know that this is normal in some processors but with this resistance only take video card so found it strange.
                                    I suspect that there may be some leak in the processor.
                                    Anyway, when I press the power, it...
                                    10-29-2024, 06:48 AM
                                  • pajdek
                                    Lenovo Y700-17ISK turn on and off
                                    by pajdek
                                    Hello, i have some issues with my laptop Lenovo Y700-17ISK (motherboard BY511 NM-A541), it started when i turn on the laptop, but the lcd wont turn on, i then connected it via hdmi to tv and screen was ok. So i thought maybe lcd stripe is faulty, i removed the bottom cover, disconnected main battery, reset the cmos by disconnecting battery for 1 min, then slighty move the lcd stripe. Conncted power supply and tuned on my laptop, the lcd turn on, it started to load os, then it turn off, after a second it turn on, then after like 3 seconds turn off again, and so on. Removed power supply, waited...
                                    09-20-2023, 02:49 AM
                                  • JohnML1975
                                    Falcon FF32S53 turns off by itself then will not turn back on unless you wait
                                    by JohnML1975
                                    Dear Forum members
                                    I searched for a forum on this model TV and could not find so thought I would start a thread on this model and make
                                    I will upload some photos and share my trouble shooting steps so far
                                    07-20-2025, 12:28 AM
                                  • RdeveLabs
                                    MSI GF63 THIN 11UCX (MS-16R6) LAPTOP WON'T TURN ON AFTER RESTARTING
                                    by RdeveLabs
                                    To all the members here...
                                    Let me tell you a little bit about what happened to my laptop (MSI GF63 THIN 11UCX model: MS-16R6) that “maybe” you know how to solve this problem.
                                    So before this problem happened, my laptop was running smoothly. When I wanted to restart my laptop, it looked fine at first. But after I waited for this restart process to take a long time, until finally I panicked (because the restart process did not finish plus the laptop screen only showed a black screen), I immediately pressed and held the power button to force the laptop to turn off. But...
                                    05-05-2025, 04:59 AM
